Dave Roof 857 Posted June 3, 2020 Share Posted June 3, 2020 Coming later this June will be a correct centerline pylon for the Trumpeter AV-8B Harrier. Product number will be FL32-2008 Also in work are the following : FL32-2009 AN/ALQ-164 DECM Pod (used often during Desert Storm) FL32-2010 Correct Crossover fairing for the gun pack FL32-2011 Correct Wing pylons for the Trumpeter AV-8B Kagemusha, johncrow, Isar 30/07 and 5 others 8 Link to post Share on other sites
blackbetty 4,911 Posted June 3, 2020 Share Posted June 3, 2020 this would be for the non-night attack version? Link to post Share on other sites
ade rowlands 1,735 Posted June 3, 2020 Share Posted June 3, 2020 Will these work for the RAF GR.7/9? Link to post Share on other sites
Dave Roof 857 Posted June 3, 2020 Author Share Posted June 3, 2020 3 hours ago, blackbetty said: this would be for the non-night attack version? No, it's the same pylon on all three US variants. 3 hours ago, ade rowlands said: Will these work for the RAF GR.7/9? I would assume so. I honestly don't know if the RAF uses different pylons, but I don't believe they do. blackbetty 1 Link to post Share on other sites
ade rowlands 1,735 Posted June 3, 2020 Share Posted June 3, 2020 9 minutes ago, Dave Roof said: No, it's the same pylon on all three US variants. I would assume so. I honestly don't know if the RAF uses different pylons, but I don't believe they do. I’m reasonably sure myself that that generation of Harrier was a joint project so would also guess they are the same. Link to post Share on other sites
Piero 974 Posted June 15, 2020 Share Posted June 15, 2020 On 6/3/2020 at 7:57 AM, ade rowlands said: Will these work for the RAF GR.7/9? They were a little bit different... with reinforcement for bird-strike and to carry UK cluster bomb BL755 a little heavier than the US CBU Rockeye. Link to post Share on other sites
