Phantom2 Posted May 31, 2020 Share Posted May 31, 2020 (edited) I´ll play with this one; It´s the all (not so ) new kit from Revell, and It will be in the early green/brown day-scheme, and I will use some resin bits/corrections/decals, some more needed then others. It´s not a lot of parts in this kit so I will throw in some more, lots of resin bits, here´s what I will use; I´ll present the parts in the tread when I use them. Revells kits usually goes together nicely but new parts can cause a bit of work, we will se how it all fits. I don´t like Revell´s decals very much. so the first I did was to buy new ones and this sheet from extradecals was perfect! Here You get six nice options; I want a machine in the classic green/brown over sky or sky blue, I hanen´t decided yet but I like P-8044 "EB o J", but that may be a little too late, maybe N3093 "QJ o W" will fit BoB better.. The decals from Extradacals are perfectly printed as always and the quality is top notch. More to come soon! Tally Ho, Chaps! Stefan Edited May 31, 2020 by Phantom2 Alain Gadbois, Derek B, Trak-Tor and 9 others 12 Link to comment Share on other sites More sharing options...
Brad-M Posted June 1, 2020 Share Posted June 1, 2020 Wonder why the squadron codes were after the roundel? Link to comment Share on other sites More sharing options...
MikeMaben Posted June 1, 2020 Share Posted June 1, 2020 You can find many examples of both Brad. Link to comment Share on other sites More sharing options...
Brad-M Posted June 1, 2020 Share Posted June 1, 2020 I suppose. Just looks strange to me. Link to comment Share on other sites More sharing options...
Fanes Posted June 1, 2020 Share Posted June 1, 2020 Nice choice! Since I plan to do QJ o W in the distant future one advice: you might want to get replacement prop and spinner. The Revell part looks like something in between the Jablo and the Rotol part. Link to comment Share on other sites More sharing options...
Phantom2 Posted June 1, 2020 Author Share Posted June 1, 2020 1 hour ago, Fanes said: Nice choice! Since I plan to do QJ o W in the distant future one advice: you might want to get replacement prop and spinner. The Revell part looks like something in between the Jablo and the Rotol part. Tanks for the heads up, Fanes! I´ll look into that... Stefan Link to comment Share on other sites More sharing options...
dennismcc Posted June 1, 2020 Share Posted June 1, 2020 (edited) Nice choice I built one of those a few years ago and used the Barracuda stuff on it, it went really well and I was most pleased with it, apart from the prop and spinner. Cheers Dennis Edited June 21, 2020 by dennismcc Link to comment Share on other sites More sharing options...
Greif8 Posted June 1, 2020 Share Posted June 1, 2020 Great choice Stefan! I built this kit a few years ago using most of the Barracuda AM you show in your picture to backdate the aircraft of a Mark Ia and was happy with the result. No. 616 Squadron flew out of Kenley during some of the heaviest fighting during the battle in August and September so that is an excellent choice to build. Ernest Link to comment Share on other sites More sharing options...
Dpgsbody55 Posted June 2, 2020 Share Posted June 2, 2020 Nice choice. One small thing. Just be aware that with early Spitfires built by Supermarine, their idea of standard RAF sky type S was a little more blue than most others. Cheers, Michael Link to comment Share on other sites More sharing options...
Phantom2 Posted June 2, 2020 Author Share Posted June 2, 2020 Thanks guys! Ernest, that makes it for me, I´ll do "The Virgin" from 616 Sqn.! I have most of the Barracuda stuff and I plan on robbing the correct prop from a PCM Hurricane (that kit have all props included; Watts, Rotol, and DeHavilland), if it fits.... Stefan Greif8 1 Link to comment Share on other sites More sharing options...
Greif8 Posted June 2, 2020 Share Posted June 2, 2020 1 hour ago, Phantom2 said: Thanks guys! Ernest, that makes it for me, I´ll do "The Virgin" from 616 Sqn.! I have most of the Barracuda stuff and I plan on robbing the correct prop from a PCM Hurricane (that kit have all props included; Watts, Rotol, and DeHavilland), if it fits.... Stefan I am sure you have a great time building the kit Stefan. I know I will enjoy watching! Ernest Link to comment Share on other sites More sharing options...
Phantom2 Posted June 21, 2020 Author Share Posted June 21, 2020 (edited) Hi all! ”Everyone” knows you´ll always start with the cockpit, but NOPE! I´ll start with the wings! Revell have made several errors and simplified too much, incorrect shapes on the coolers, cheated with the intake/outlet ramps to the large cooler and the wings have metal ailerons, not fabric as it should be. Barracudacast saves us with this little set; Here you´ll find everything to fix the errors in the wings, new coolers and fabric ailerons. Here You can see that the wing surface is flat where it should have a slightly recessed duct. First I chain-drill along the perimeter with a 1mm drill-bit… Then It´s some carving and cutting until you get a nice hole… The cooler waits in front of the wing…. The plastic are scaringly soft and It´s very easy to remove too much, tread easily! Barracuda´s parts are a drop-fit, as usual… I glued the cooler from the inside and used generously with CA, I´ll take no chances getting the parts loose! A test-fit of the top wing parts showed that I had to remove a little plastic here too. More to come soon... Stefan Edited June 21, 2020 by Phantom2 Alain Gadbois, Pete Roberts, RLWP and 8 others 11 Link to comment Share on other sites More sharing options...
Greif8 Posted June 21, 2020 Share Posted June 21, 2020 Looking good Stefan. I know I sweat a bit while making those cuts in the wings! Ernest Link to comment Share on other sites More sharing options...
dennismcc Posted June 21, 2020 Share Posted June 21, 2020 Looking good, I very nearly chickened out when it came to the wing corrections but in the end it worked out fine, and looked great, the only problem I had was with the ailerons, one was a bit short. Cheers Dennis Link to comment Share on other sites More sharing options...
Phantom2 Posted June 21, 2020 Author Share Posted June 21, 2020 (edited) Thanks guys! I have built lots of short-run kits so I´m quite used to cutting and slicing in the kits I build. But I understand, It´s not fun cutting up a new kit the first thing you do, but it´s a necessary evil in this case. In this case the very soft plastic makes it even more scary as It´s very easy to cut away too much. Cheers! Stefan . Edited June 21, 2020 by Phantom2 Link to comment Share on other sites More sharing options...
