Greif8 Posted June 16, 2020 Share Posted June 16, 2020 9 hours ago, RLWP said: Those canvas wheel well liners I made a paper template Used it to cut a piece of thin brass sheet: Embossed it with a few simple tools and stuck it in place: Not perfect, they'll look fine tucked up underneath the aeroplane with some paint Richard Good thinking and execution Richard. Unfortunately I don't have a template or I would try the same thing, it looks like I'll be waitin a few weeks for the replace parts from Dragon. Ernest Link to comment Share on other sites More sharing options...
RLWP Posted June 16, 2020 Author Share Posted June 16, 2020 Yes, I forgot to photograph that bit too. I cut a strip of paper, slipped it into the wheel well and rubbed a pencil along the edge of the opening. You can't do it all in one go, so I did the straight bit first, stuck the template in with a bit of tape, and then continued around doing the same. Mark, cut, tape until you end up where you started Richard Link to comment Share on other sites More sharing options...
RLWP Posted June 16, 2020 Author Share Posted June 16, 2020 Here you go. A wheel well and a strip of paper: Hold the paper in place and rub a pencil around the edge: Cut and tape that bit and carry on: It worked on the Bf 109 , the edge against the upper wing skin is almost straight. this Spitfire well would need a bit more work because the walls are conical I'd send you my template, it's unlikely to fit a kit from a different manufacturer Embossing the brass: Three lines, two for the fastening cords and one in the middle for the zip: Turn it over and push in dents for the eyelets: This is impressionism rather than true accuracy. Somewhere out there will be a drawing of the original part for someone to make a PE part from Richard Alain Gadbois, Greif8 and Gazzas 2 1 Link to comment Share on other sites More sharing options...
Greif8 Posted June 16, 2020 Share Posted June 16, 2020 2 hours ago, RLWP said: Here you go. A wheel well and a strip of paper: Hold the paper in place and rub a pencil around the edge: Cut and tape that bit and carry on: It worked on the Bf 109 , the edge against the upper wing skin is almost straight. this Spitfire well would need a bit more work because the walls are conical I'd send you my template, it's unlikely to fit a kit from a different manufacturer Embossing the brass: Three lines, two for the fastening cords and one in the middle for the zip: Turn it over and push in dents for the eyelets: This is impressionism rather than true accuracy. Somewhere out there will be a drawing of the original part for someone to make a PE part from Richard Thank you Richard! Ernest RLWP and BradG 2 Link to comment Share on other sites More sharing options...
RLWP Posted June 16, 2020 Author Share Posted June 16, 2020 The radiator cowls are nice, but not well faired to the wing: So I sanded down the underside: It took a bit more of after that picture, much better This is the Weekend edition, the Profilpack has a PE radiator grille. So I scribed some brass sheet: Again, this is impressionism, it will look like mesh if you peer up the inlet And I cut away the outlet on the cowl for the moving part: I doubt you will be able to see that grille at all! Richard Gazzas, MikeMaben, BradG and 2 others 5 Link to comment Share on other sites More sharing options...
Gazzas Posted June 16, 2020 Share Posted June 16, 2020 That's some inspiring brass work, Richard. I'd have never thought of doing the radiators that way. I have some brass sheet that would be way too think, but I do have some aluminium flashing sheet which is quite thin. I'll try it on that. Link to comment Share on other sites More sharing options...
Greif8 Posted June 18, 2020 Share Posted June 18, 2020 Very nice work with the brass Richard. I am going to try your technique for the wheel well canvas tonight, we will see how it goes! Ernest Ernest Link to comment Share on other sites More sharing options...
RLWP Posted June 20, 2020 Author Share Posted June 20, 2020 I have made my best guess on the camera location, based on the picture and the framing: There is a fairing to fit over that The seat and back board are now fitted too: The back board is going to need filling around the edge to make the flat back board Richard Alain Gadbois, BradG, scvrobeson and 1 other 4 Link to comment Share on other sites More sharing options...
thierry laurent Posted June 21, 2020 Share Posted June 21, 2020 On 6/16/2020 at 10:05 AM, RLWP said: Yes, I forgot to photograph that bit too. I cut a strip of paper, slipped it into the wheel well and rubbed a pencil along the edge of the opening. You can't do it all in one go, so I did the straight bit first, stuck the template in with a bit of tape, and then continued around doing the same. Mark, cut, tape until you end up where you started Richard Try doing the same thing with masking tape. You will find this is far easier. Simply decrease a little bit the sticking power of the glue beforehand. Stick and remove your tape strip on a glass two or three times before putting it in the well. This will also help in cutting the part from the metal sheet. Link to comment Share on other sites More sharing options...
dodgem37 Posted June 21, 2020 Share Posted June 21, 2020 Good show, Richard. Definitely, use tape. From the Bf109K-4 build found in my signature. Sincerely, Mark scvrobeson, Sepp and BradG 3 Link to comment Share on other sites More sharing options...
RLWP Posted June 21, 2020 Author Share Posted June 21, 2020 3 hours ago, thierry laurent said: Try doing the same thing with masking tape. You will find this is far easier. Simply decrease a little bit the sticking power of the glue beforehand. Stick and remove your tape strip on a glass two or three times before putting it in the well. This will also help in cutting the part from the metal sheet. I'll bear that in mind next time, thank you Richard Link to comment Share on other sites More sharing options...
Greif8 Posted June 21, 2020 Share Posted June 21, 2020 The camera fairing and lens looks great Richard and I think your placement is logical and plausible. Ernest Link to comment Share on other sites More sharing options...
RLWP Posted June 21, 2020 Author Share Posted June 21, 2020 52 minutes ago, Greif8 said: The camera fairing and lens looks great Richard and I think your placement is logical and plausible. Ernest The fairing is about right along the fuselage, and might be right for width. It's likely the fairing contained a sliding door to cover the lens, so the lens had to be towards one end if I put the lens towards the front, then the fuselage frame would have had to be cut. Putting it at the back puts the lens between the frames which makes more sense to me Richard Link to comment Share on other sites More sharing options...
Greif8 Posted June 21, 2020 Share Posted June 21, 2020 3 hours ago, RLWP said: The fairing is about right along the fuselage, and might be right for width. It's likely the fairing contained a sliding door to cover the lens, so the lens had to be towards one end if I put the lens towards the front, then the fuselage frame would have had to be cut. Putting it at the back puts the lens between the frames which makes more sense to me Richard That makes perfect sense to me Richard. I had never given the photo recon 109's much thought until your build. Thinking about it, the most logical location for a camera would be near, or even co-located with the radio gear; and your placement is very very close to that. Ernest Link to comment Share on other sites More sharing options...
RLWP Posted June 21, 2020 Author Share Posted June 21, 2020 19 minutes ago, Greif8 said: That makes perfect sense to me Richard. I had never given the photo recon 109's much thought until your build. Thinking about it, the most logical location for a camera would be near, or even co-located with the radio gear; and your placement is very very close to that. Ernest From what I have read, it replaced some of the radio gear. As you say, the radio was placed just above my fairing Richard Link to comment Share on other sites More sharing options...
