Scale32 Posted February 4, 2021 Share Posted February 4, 2021 That EE cockpit sure is a nice bit of kit and you've done it justice with the paint. Have you seen the Aires version by any chance to compare? Cheers Bevan Thunnus 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 4, 2021 Share Posted February 4, 2021 Good show. What paints do you use? Thank you. Sincerely, Mark Thunnus 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 4, 2021 Share Posted February 4, 2021 Great work John, the cockpit looks very effective, realism wise. Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted February 4, 2021 Author Share Posted February 4, 2021 10 hours ago, Scale32 said: That EE cockpit sure is a nice bit of kit and you've done it justice with the paint. Have you seen the Aires version by any chance to compare? Cheers Bevan Thanks Bevan! I've built a few of these Hasegawa Dora kits and have used the Eagle Editions cockpit before. I would rank it as the best cockpit upgrade for the Dora, compared to the Aires and out of production MDC sets, which I've also used. The Aires set is more simplistic but the casting is finer and more uniform. But in the end, the cockpit gets engulfed within the fuselage with limited visibility into the area and the differences between the Aires and EE cockpits start to fade. Aires Eagle Editions 8 hours ago, dodgem37 said: Good show. What paints do you use? Thank you. Sincerely, Mark Thanks Mark! The RLM66 is Mr Hobby Aqueous. For the other primary colors used for the detail painting, I use my stash of Tamiya paints. 1 hour ago, Out2gtcha said: Great work John, the cockpit looks very effective, realism wise. Thanks Brian! Pretty straightforward stuff and I tried to not spend too much time on things that will go unseen. Most of these cockpit details will eventually get boxed in like this... nmayhew, Rivas, scvrobeson and 10 others 12 1 Link to comment Share on other sites More sharing options...
Thunderbolt Posted February 4, 2021 Share Posted February 4, 2021 Eagle's main advantage is the provision of the canopy rails. The hood over the IP is an excellent upgrade as well. I feel mixed about the rest. Thunnus 1 Link to comment Share on other sites More sharing options...
Jerry Crandall Posted February 5, 2021 Share Posted February 5, 2021 Keep in mind the back of the seat is armored iron so no silver highlights. Cheers, Jerry BiggTim, MikeMaben, fastterry and 5 others 6 2 Link to comment Share on other sites More sharing options...
brewer Posted February 5, 2021 Share Posted February 5, 2021 8 minutes ago, Jerry Crandall said: Keep in mind the back of the seat is armored iron so no silver highlights. Cheers, Jerry Good call, Jerry Landrotten Highlander, Sparzanza, Michael931080 and 11 others 14 Link to comment Share on other sites More sharing options...
Thunnus Posted February 5, 2021 Author Share Posted February 5, 2021 What do you do when Mr. Jerry Crandall says the seat back should have not silver-colored wear because it is armored? (a) Come up with a dismissive retort like, "Yeah right! Like you know what a real Focke-Wulf 190 seat looks like. Psssh!"? (b) Continue the build, pretending like you never saw the comment? Or (c) Wipe it and start over? Of course, with all due respect to Mr. Crandall's undeniable expertise in the matter, I chose (c). After I sprayed the seat with some appropriate shades, I thought I'd delve into the engine compartment and try to get the MG151 fitted. Here is that "cover" that I was talking about in the previous post. It has a hole drilled into it to accept the MG151. The stub of the MG151 barrel can be wedged into the hole. Since the gun protrudes past the resin bulkhead supplied in the Grey Matter resin set, I cut out a hole in it. In reality, the gun body goes all the way back into the front of the cockpit but since there is no visibility to that area, I am not going to cut a corresponding hole in the cockpit tub bulkhead. I'm just going to trim the gun body to allow the cockpit tub to fit. As you can see, the gun is visible but obscured. It will be even more obscured once I had additional pipes and wiring. I'll also have to add a chute for the expended ammo. If possible, I'll try and incorporate the resin ammo container as part of the chute. The real ammo containers in the D-13 were located above in the space where the D-9 cowl guns were. Rivas, Greg W, LSP_K2 and 17 others 19 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 5, 2021 Share Posted February 5, 2021 Good clean fun. Good show. Sincerely, Mark Thunnus 1 Link to comment Share on other sites More sharing options...
Scale32 Posted February 5, 2021 Share Posted February 5, 2021 It's just those extra little details....... Cheers Bevan Thunnus 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted February 5, 2021 Share Posted February 5, 2021 10 hours ago, Jerry Crandall said: Keep in mind the back of the seat is armored iron so no silver highlights. Cheers, Jerry Hi Jerry , were they all like that ? Thunnus 1 Link to comment Share on other sites More sharing options...
BiggTim Posted February 5, 2021 Share Posted February 5, 2021 15 hours ago, Jerry Crandall said: Keep in mind the back of the seat is armored iron so no silver highlights. Cheers, Jerry Wow, I never would have caught that detail. Very interesting, Jerry, thanks. Thunnus and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 5, 2021 Share Posted February 5, 2021 Great work John! That will look great under some paint. Kagemusha and Thunnus 2 Link to comment Share on other sites More sharing options...
Jerry Crandall Posted February 5, 2021 Share Posted February 5, 2021 Hi Mike, Yes, They all were constructed the same. Cheers, Jerry MikeMaben, Shiba, Thunnus and 1 other 3 1 Link to comment Share on other sites More sharing options...
Thunnus Posted February 6, 2021 Author Share Posted February 6, 2021 Thanks guys! The seat has been redone it using a base coat of Alclald Steel on the armored backrest and the Tamiya AS-12 silver for the frame of the bucket. Yes, I've chipped it again but there is very low contrast between the dark steel and the dark grey RLM 66. scvrobeson, Sparzanza, Rivas and 17 others 20 Link to comment Share on other sites More sharing options...
