brewer Posted January 16, 2021 Share Posted January 16, 2021 7 minutes ago, Kais said: John, as you're building a D-13, recall there are no MG131s, there no MG131 ammo cans behind the engine on the firewall. Good luck! True, the single ejection port in the lower wing panel would have been for the motorkanone, and the ejection chutes for the upper cowl guns would not be there. I need to find some reference of what that would look like. Probably similar to the Ta152 Thunnus 1 Link to comment Share on other sites More sharing options...
jeroen_R90S Posted January 16, 2021 Share Posted January 16, 2021 Thanks for the pointer in using a punch set for instrument decals -just what I need for my Intruder. Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted January 20, 2021 Author Share Posted January 20, 2021 Returning to the wooden flaps... first, the recessed panel lines were filled. I used black CA so that I could still use the lines as a guide for placing the decals. Only two colors this time, white and off-white. I am going to use another wood decal pattern that has more grain detail. I like this a little better than the initial try and much better than the decals that Eagle Editions supplies. Greg W, LSP_Kevin, BiggTim and 12 others 15 Link to comment Share on other sites More sharing options...
scvrobeson Posted January 20, 2021 Share Posted January 20, 2021 That looks a lot better than the first attempt. These ones look a lot more natural. Great work Matt Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted January 20, 2021 Author Share Posted January 20, 2021 Thanks Matt! I think the major improvement was getting rid of those panel lines, which may not be very evident in the photos. Incremental improvement in the wood panel appearance but I'll take it. I like the visible grain patterns better. I did use the older wood decal for the central piece, which makes it stand out a bit. scvrobeson 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted January 20, 2021 Share Posted January 20, 2021 Looks like you may already have this pic of a restoration ... Looks a little 'redder' than yours. Somewhere between yours and Jerry's maybe ? Thunnus, Michael931080, Anthony in NZ and 5 others 8 Link to comment Share on other sites More sharing options...
scvrobeson Posted January 20, 2021 Share Posted January 20, 2021 Light coat of clear orange/red should be able to handle that nicely. Matt Thunnus 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted January 20, 2021 Share Posted January 20, 2021 How do we know Gosshawk Unlimited followed what FW did back in early 1945? We're looking at a restoration picture above. The material has to be spec'd to an original or better than what was original used. The varnish could be something completely different than what was used back in 1945. Case in point. How many Mustangs do you see with beautiful wooden varnished floors on Modern-day Mustang restorations? They never came out of North American that way in 45.... Thunnus, Jeff T and MikeMaben 3 Link to comment Share on other sites More sharing options...
Thunnus Posted January 21, 2021 Author Share Posted January 21, 2021 Sorry but I just have to laugh! I was initially typing a response like Troy's, saying that I was ok with the color and didn't feel a need to match the wood color that a restoration team came up with. But Matt's reply made me think that it would be an easy thing to tint the wood a little darker with a light spray of clear red. Which I've since done... But I agree with Troy that we really don't know what the wood flaps looked like on the operational D-13. Vincent K even suggested that they may have been covered by some sort of anti-fungal primer or linen. So unless I have a request for mahogany panels, I'm considering the wood flaps done. Uncarina, Harrison90, Scotsman and 9 others 12 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 21, 2021 Share Posted January 21, 2021 Just catching up with this one John, I think the decals look stellar! The effect works very well to my eye. Thunnus 1 Link to comment Share on other sites More sharing options...
Jerry Crandall Posted January 21, 2021 Share Posted January 21, 2021 Please read the comment by Karl-Heinz Ossenkop about the varnished flaps. Cheers, Jerry Thunnus 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted January 21, 2021 Share Posted January 21, 2021 Glad the light overspray of red helped. Plus, it should protect the decals with that added clear coat. Matt Thunnus and Uncarina 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted January 21, 2021 Share Posted January 21, 2021 My post was not an endorsement of any particular color but since Jerry has written books on the subject of LW color, I didn't think his product would be that far off color wise. Obviously a reddish tint would be the answer had John chosen that option. I agree with Troy that since there is no info on what type of wood was used or was it the same wood and color (fabric) treatment used on all wooden flaps, some leeway must be given under the rules . We like leeway anyway Troy Molitor and Thunnus 2 Link to comment Share on other sites More sharing options...
Beaconroot Posted January 23, 2021 Share Posted January 23, 2021 Really enjoy seeing your work John. Thanks for sharing. Jim Root Thunnus 1 Link to comment Share on other sites More sharing options...
Thunnus Posted February 4, 2021 Author Share Posted February 4, 2021 After taking a short break following the finish of the Me262B Nightfighter build, I've been trying to work up enough mojo to start this build back up. It's slow going but I've managed to make a little progress. First off, I've received the Aires 190D gun bay resin set. I think it must be one of Aires older products based on the color of the resin and visible yellowing of the packaging. I have no intention of using these in the wing root gun bays as designed but I thought it would be helpful to at least assemble one of the wing root stations to get a better understanding of how the MG151 is mounted. Surprisingly, the front end of gun body butts up against a solid wall. Although the gun barrels are provided, the set makes no provisions for their use. I guess they expect the modeler to drill the necessary holes. The back of the Jumo 213 has a cover, which I THINK is the location of the hollow space where a gun barrel would fit. D-9's had no gun in this location hence the cover, which is the black object above the large trunk of the supercharger. The Hasegawa kit depicts this cover and therefore gives me a point of reference as to where the MG151 can be mounted. As previously shown, the instrument panels have been painted and it was time to paint the rest of the cockpit. Pretty understated and, dare I say, boring? The Eagle Editions cockpit represents much more than will be visible from the cockpit opening. Everything behind and in front of the raised side panels will be obscured from sight. Here is the frontal hood with the upper instrument panel in place. The Revi 16B gun sight still needs to be painted and added. The upper areas of the sidewalls have been chipped. Really not much else will be see due to the raised side panels. None of the painted wiring runs will be visible as they will be blocked by the instrument panel and the seat. The starboard side panel is grafted from the Zoukei Mura Ta152H-1 kit to reflect the difference between the D-13 and D-9. One of the things I've been doing after the cockpit has been painted and given a flat coat is to go back with a fine brush and touch up the black areas with Future. The glossy Future will darken the black and provide more contrast and also give some surfaces a variance in sheen. Just something to break up the monotony of a sparse cockpit. The seat hasn't been given a flat coat yet. I'll do that after the HGW harnesses have been added. On the rear deck, I've pre-installed loops for the attachment of the shoulder harnesses. The top of loops have been left open so, in theory, I can just slip the shoulder straps onto the loops and close them with CA glue. TAG, D.B. Andrus, Sparzanza and 17 others 20 Link to comment Share on other sites More sharing options...
