James Rademaker Posted May 8, 2020 Share Posted May 8, 2020 I’m a new member and I’d like to ask for some painting advice on creating wing ID bands. My questions is regarding the raised line that is created when spraying the band color. How do you remove that raised line with out marring the original paint color. Do you sand it, and if so, what grit works best? Thanks, Jim Link to comment Share on other sites More sharing options...
thierry laurent Posted May 9, 2020 Share Posted May 9, 2020 You have that raised ridge if you spray towards the mask edge. If you spray in the opposite direction or right in the center of the colored stripe, you are minimizing that issue noticeably. If you still have one to remove, use very fine micromesh to sand it cautiously. Lothar 1 Link to comment Share on other sites More sharing options...
James Rademaker Posted May 9, 2020 Author Share Posted May 9, 2020 Thanks, I’ll try that. Jim Link to comment Share on other sites More sharing options...
Woody V Posted May 9, 2020 Share Posted May 9, 2020 Clear coat and sand with fine micro mesh. Old technique used on custom car paint jobs. Lothar and BiggTim 2 Link to comment Share on other sites More sharing options...
BiggTim Posted May 9, 2020 Share Posted May 9, 2020 (edited) 4 hours ago, Archer Fine Transfers said: Clear coat and sand with fine micro mesh. Old technique used on custom car paint jobs. x2. Exactly what I usually do. Since I use enamels paints, I actually WET sand it with 1200 or 1500 grit, then clearcoat again. Edited May 9, 2020 by BiggTim Woody V 1 Link to comment Share on other sites More sharing options...
James Rademaker Posted May 9, 2020 Author Share Posted May 9, 2020 Guys, many thanks for your replies. I appreciate your help. Jim Link to comment Share on other sites More sharing options...
Cheetah11 Posted May 9, 2020 Share Posted May 9, 2020 Hi Jim Try and use paint that covers well, then the ridge might not need sanding. For white I actually use Tamiya white primer which is dense after a light coat. Nick Link to comment Share on other sites More sharing options...
James Rademaker Posted May 9, 2020 Author Share Posted May 9, 2020 Thanks Nick, Jim Link to comment Share on other sites More sharing options...
