LSP_K2 Posted May 18, 2020 Author Share Posted May 18, 2020 Bow machine gun armored cover now given some cast texture. After a teeny bit of buffing with Scotch-Brite, it should look just fine (I hope). Smokey, Greg W and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
LSP_Ray Posted May 19, 2020 Share Posted May 19, 2020 23 hours ago, LSP_K2 said: I've got a marvelous picture of LSP_Ray standing in front of a Tiger II, and it's also missing every other tooth on the sprocket, for whatever that's worth. This one?: Actually, that is my daughter and son-in-law. I am behind the camera. Also have the other side: Close-up of the tracks: F-4Phanwell, BiggTim, LSP_K2 and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_Ray Posted May 19, 2020 Share Posted May 19, 2020 Here are a trio of photos of Bovington's JagdTiger, but I believe it is a Porsche variant?: Smokey, F-4Phanwell, BiggTim and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 19, 2020 Author Share Posted May 19, 2020 Yes, that Jadtiger is definitely Porsche, and with an 18 tooth sprocket. The photo I'm referring to, has you standing in front of the left hand drive sprocket, reaching up toward the barrel. BiggTim 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted May 19, 2020 Share Posted May 19, 2020 Didn't find that one. LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 19, 2020 Author Share Posted May 19, 2020 All 18 torsion bars and connectors now cleaned up and installed. Now the remainder of the engine flanking area guts can be added, which may take a few days. I’m fairly confident that the engine cooling fans and deflectors/diffusers will be able to be observed through the engine deck, at least to some minor degree, so these will be suitably painted. Engine, residing as it does in its own middle compartment, will not be visible from the exterior at all, so will simply not be installed. Oh, and a word to the wise; not all of the torsion bars automatically line up like I’d assumed they would, so great care will need to be taken to keep them all at the same distance from the ground, at least for the way I’ll be having mine sitting. Greg W, Iain and Smokey 3 Link to comment Share on other sites More sharing options...
LSP_Ray Posted May 19, 2020 Share Posted May 19, 2020 I was wondering if that was what those two parts were for that you couldn't fit, as guides to getting everything lined up? Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 19, 2020 Author Share Posted May 19, 2020 1 hour ago, LSP_Ray said: I was wondering if that was what those two parts were for that you couldn't fit, as guides to getting everything lined up? Not really, as they just have round holes that would in no way hold any particular position, unless glued tight. I think the real issue is a combination of the somewhat loose hex fittings on either end of the bar, combined with actual torsion that can be imparted on the bars themselves, as well as the two different diameters of the swing arm end fittings, which if all glued in place solidly with the bottoms touching the desk or whatever, would make every other road wheel higher than the flanking road wheels. LSP_Ray 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 19, 2020 Author Share Posted May 19, 2020 I decided to determine what, if anything, might really be visible below the cooling deflectors/diffusers, especially with the debris screens in place (the diffusers themselves are just peppered with ejector pin depressions, and I don’t want to deal with them unless it’s absolutely necessary). I have to hand it to Trumpeter here, debris screens fit wonderfully, not quite perfect, but still very, very good. Once I paint the cooling area guts, I’ll have a much better understanding of what truly needs to be done. Out2gtcha, Greg W, LSP_Ray and 1 other 4 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 19, 2020 Share Posted May 19, 2020 Very cool Kev....................Seems like you could almost put another screen or black panel under the debris screen to nearly hide everything under it. LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 19, 2020 Author Share Posted May 19, 2020 Sure enough I put two pair of road wheels together incorrectly, so I'll now need to saw those apart and re-glue. Darn it. Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 19, 2020 Author Share Posted May 19, 2020 14 minutes ago, Out2gtcha said: Very cool Kev....................Seems like you could almost put another screen or black panel under the debris screen to nearly hide everything under it. Much of what's there I actually do want to see, the cooling fans in particular. I just don't want to have such a good view that I see a ton of ejector pin marks in there (which I seriously doubt will be the case). If they do turn out to be visible at all, I'll just have to fill and sand them all out. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Dart_Schatten Posted May 19, 2020 Share Posted May 19, 2020 Good day! It's wery interesting blog! I've got the same kit. I've started it in past year, but it "stuck". I was lucky to bought turned metal barrel for my "JagdT". I'll try to find some pics with my JagdT. Sorry for my poor English. Regards, Sergey Budyansky. Out2gtcha, LSP_K2 and Smokey 3 Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 19, 2020 Author Share Posted May 19, 2020 27 minutes ago, Dart_Schatten said: Good day! It's wery interesting blog! I've got the same kit. I've started it in past year, but it "stuck". I was lucky to bought turned metal barrel for my "JagdT". I'll try to find some pics with my JagdT. Sorry for my poor English. Regards, Sergey Budyansky. Does the replacement barrel have the correct rifling in it? That's the only way I'd even consider a replacement. Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 19, 2020 Author Share Posted May 19, 2020 With this photo I've tried to illustrate that the fan blades will show, but it's very difficult (almost impossible) to capture. Needless to say, with the surrounding upper areas yellow-brown and the fan blades themselves a metallic color, which I believe they were, they'll be visible. The radiators will not, and I've yet to verify if the baffles will be. mustang1989, LSP_Ray, scvrobeson and 2 others 5 Link to comment Share on other sites More sharing options...
