Marcel111 Posted November 15, 2020 Share Posted November 15, 2020 Wow Chuck, the look and finish is just so real! Amazing work! Marcel chuck540z3 1 Link to comment Share on other sites More sharing options...
Squizzy 78 Posted November 15, 2020 Share Posted November 15, 2020 How did you get a blue back drop big enough to put behind the real aircraft?! Awesome paint and weathering, with step by step instructions, thanks Chuck. I’ve noticed that you haven’t used primer on your models for some time now Chuck, one question on that. Have you had any issues with the paint being sprayed on the kit coming out in slightly different shades over plastic to resin parts? For example, a replacement resin intake set that also replaces the fuselage sections around the intake? chuck540z3 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted November 15, 2020 Author Share Posted November 15, 2020 3 minutes ago, Squizzy said: I’ve noticed that you haven’t used primer on your models for some time now Chuck, one question on that. Have you had any issues with the paint being sprayed on the kit coming out in slightly different shades over plastic to resin parts? For example, a replacement resin intake set that also replaces the fuselage sections around the intake? Thank you sir. While I don't use a true primer, the gloss black I used as a base for the Alclad aluminum substitutes as one, which covers all plastic and resin as one dark shade. Recall, I started out with this, which is a pretty big contrast in base colors. The reason I don't use primers like Mr. Sufacer, etc., is that if the plastic is smooth enough, I don't need any more paint getting into fine detail like rivets. To me, if the model needs a primer to fill fine scratches and other flaws, you aren't doing it right. Get out the fine sandpaper and fix them! Also, when I use enamels and lacquers, including this new MRP paint, adhesion to plastic and resin is never an issue. I put a lot of masking tape on this model and other than a few small areas where I had applied hairspray, I had no lifting of paint. Cheers, Chuck Anthony in NZ, Squizzy 78, Rocat and 1 other 3 1 Link to comment Share on other sites More sharing options...
fastterry Posted November 16, 2020 Share Posted November 16, 2020 Boy Chuck, you're really making it hard on the next guy that wants to build a half decent Tempest! Superb work and along with your other builds will add up to an encyclopedia of how to build museum quality plastic kits. The salt fading demo is worth the price of admission alone. TRF chuck540z3 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted November 16, 2020 Share Posted November 16, 2020 GREAT! show, Chuck. Sincerely, Mark chuck540z3 1 Link to comment Share on other sites More sharing options...
Rocat Posted November 16, 2020 Share Posted November 16, 2020 Amazing results! Those MRP paints must be really good, and the same must be said for those GWH decals...but I think that YOU are making the real difference here chuck540z3 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted November 16, 2020 Share Posted November 16, 2020 A really Big Show going on here Chuck. The salt effect turned out marvelous. Thanks for sharing your fine examples with us. What’s next after the Tempest concludes? chuck540z3 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted November 16, 2020 Author Share Posted November 16, 2020 (edited) Thank you gentlemen for your kind comments! 40 minutes ago, Troy Molitor said: A really Big Show going on here Chuck. The salt effect turned out marvelous. Thanks for sharing your fine examples with us. What’s next after the Tempest concludes? Thanks Troy. Probably the Italeri CF-104, which checks off these boxes. Jet. I've done 2 props in a row and it's time for some kerosene. I've never built one before Lots of aftermarket available I can order everything online I think I can have fun with the bare metal finish There is one in our local museum for references It's Canadian, eh? Cheers, Chuck Edited November 16, 2020 by chuck540z3 Anthony in NZ, Neo, Rocat and 8 others 11 Link to comment Share on other sites More sharing options...
levier Posted November 16, 2020 Share Posted November 16, 2020 Following! chuck540z3 1 Link to comment Share on other sites More sharing options...
Thunnus Posted November 16, 2020 Share Posted November 16, 2020 The Tempest is looking excellent after the most recent weathering steps! chuck540z3 1 Link to comment Share on other sites More sharing options...
JayW Posted November 16, 2020 Share Posted November 16, 2020 Looking at the tip top of modelling proficiency here. I am not worthy. chuck540z3 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted November 16, 2020 Share Posted November 16, 2020 Nice choice. Looking forward to how you beat that natural metal finish into submission. The Canadian 104’s look awesome too. chuck540z3 1 Link to comment Share on other sites More sharing options...
Neo Posted November 16, 2020 Share Posted November 16, 2020 @chuck540z3 i discovered in disappointment that canuck models has closed and can no longer get their f104 decals that i was planning to use for the same cf-104 chuck540z3 1 Link to comment Share on other sites More sharing options...
chuck540z3 Posted November 18, 2020 Author Share Posted November 18, 2020 November 18/20 Short Update- as I play around with weathering, including the exhaust and propeller. Here are some pics of Pierre Clostermann’s Tempest and one other I stole from the ‘net. Note how the exhaust pattern is not behind the exhausts, but in an arc pattern above them due to airflow, then swinging down just under the bottom of the kill score sheet. It’s fairly dark too. And here's a good pic of the front of the propeller, showing wear and chipping on the gloss black spinner. So I tried to do something similar, and while I was at it, I spent an hour going over all the paint work with my airbrush, delicately spraying both light and dark highlights, similar to the Spitfire pics I’ve shown above. I think it looks a lot better now. Here’s a quick walkaround of just about everything. I also re-painted the bottom, but I’ll show that some other time after I have attached the landing gear. While you can see the chipping on the spinner, the prop blades didn't photograph very well, so you'll just have to take my word for it, that they are weathered as well. Lot's of subtle weathering here and there to come, like the exhaust stacks and the gun barrels. Cheers, Chuck LSP_Kevin, GMK, Starfighter and 24 others 27 Link to comment Share on other sites More sharing options...
nmayhew Posted November 19, 2020 Share Posted November 19, 2020 very eye catching re the exhaust stains, i have noticed in addition to the arc you describe, that there are sometimes stains in pretty much a straight line further back on the fuselage, aft of the cockpit and stretching almost the to Sky band these aren't there on every airframe, and am not that familiar with PC's bird, but let me know if you want pointers to a pic or two Kagemusha and chuck540z3 1 1 Link to comment Share on other sites More sharing options...
