spyrosjzmichos Posted April 14, 2020 Author Share Posted April 14, 2020 2 hours ago, Uncarina said: I am loving the work here! What did you use for the anti static strips for the nose? Cheers, Tom Thanks Tom! I used stretched sprue for the anti static strips (now I finally know what they are ). Stretched as thin as possible and lightly sanded. Uncarina 1 Link to comment Share on other sites More sharing options...
CZPetrP Posted April 14, 2020 Share Posted April 14, 2020 (edited) 3 hours ago, spyrosjzmichos said: Hi Petr. Thanks for the input! Can I ask which CMK set you took the cannon from? I don't mind replacing the kit's cannon but concerned about the current delivery times due to the ongoing situation... Lovely details with your work by the way! Halo, I have to say, it is good your Job. I used this: https://www.specialhobby.eu/finalni-produkty-na-prodej/produkty-na-e-shopu/vlastni-vyrobky/cmk-kits/f-104g-starfighter-gun-bay-set-for-has.html But there are more companies. Simply, wulcan. Yes COVID is now an obstacle. And thank you for the praise. Much success in building. Cheers Petr Edited April 14, 2020 by CZPetrP correction Seversky 1 Link to comment Share on other sites More sharing options...
PeterOlsen Posted April 14, 2020 Share Posted April 14, 2020 Hi Petr, Beautiful work on the cockpit and the gun, I'm looking forward to more. All the best, Cheers, Peter Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted May 15, 2020 Author Share Posted May 15, 2020 Hi all! Finally, back to modelling after a major house move! Quite a bit progress since the last update. I joined the cockpit section with the main fuselage body and then glued the lower wing section in place. Fit was ok for the most part but required a bit of work where the wing meets the intakes. I replaced the kit's exhausts with Eduard's resin set. While the set has excellent detail I was disappointed at how badly engineered some parts were. Y ou're supposed to install spar between the exhaust tubes to help them remain aligned but the sockets were undersized. In addition, the PE parts were just too big to fit into the tubes. Eventually I decided not use these. I also spent some time detailing the wheel wells with plastic and lead wire. More updates to come soon! Grunticus, Lenny320, Seversky and 18 others 21 Link to comment Share on other sites More sharing options...
themongoose Posted May 15, 2020 Share Posted May 15, 2020 Just a beautiful job so far. I’m really in love with the work you’ve done on the gun. That is gonna be a highlight of your model! spyrosjzmichos 1 Link to comment Share on other sites More sharing options...
Uncarina Posted May 16, 2020 Share Posted May 16, 2020 It is so great to see this come together. Can’t wait for paint! Cheers, Tom spyrosjzmichos 1 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted May 17, 2020 Author Share Posted May 17, 2020 On 5/16/2020 at 2:56 AM, themongoose said: Just a beautiful job so far. I’m really in love with the work you’ve done on the gun. That is gonna be a highlight of your model! Thank you! It's a pity I can't expose more of the gun assembly. Unfortunately, even on the real thing it's difficult to see much due to way the nose is designed. On 5/16/2020 at 4:17 AM, Uncarina said: It is so great to see this come together. Can’t wait for paint! Cheers, Tom Thank you Tom! Link to comment Share on other sites More sharing options...
crobinsonh Posted May 17, 2020 Share Posted May 17, 2020 Very nice work on the detailing. Like many kits I started the same model with the Wolfpack conversion set. I nearly finished the cockpit and sanding and filling raised panels and some panel lines that should not be there - at that point I ran out of mojo! You on the other hand are doing a spectacular job and I will follow with great interest. spyrosjzmichos 1 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted May 17, 2020 Author Share Posted May 17, 2020 26 minutes ago, crobinsonh said: Very nice work on the detailing. Like many kits I started the same model with the Wolfpack conversion set. I nearly finished the cockpit and sanding and filling raised panels and some panel lines that should not be there - at that point I ran out of mojo! You on the other hand are doing a spectacular job and I will follow with great interest. Thank you so much for your kind words! I can totally understand the mojo issue. Has happened to me several times and it involved some pricey kits unfortunately. It's quite painful but once it hits it's difficult to get over it. If there's something motivating me about this build is the camo itself as I really want one in my collection. By the way, how were you able to find the Wolfpack conversion??? I have been searching for it forever and even mailed Wolfpack directly but had no success so far... Dutch Man 1 Link to comment Share on other sites More sharing options...
PeterOlsen Posted May 17, 2020 Share Posted May 17, 2020 Hey, it’s great to see you back ! I hope your models made it safely through the move. We just did the shifting house thing last Christmas , it can be really stressful. Lovely work and I wish you all the best for the rest of the build , Cheers, Pete spyrosjzmichos 1 Link to comment Share on other sites More sharing options...
crobinsonh Posted May 17, 2020 Share Posted May 17, 2020 3 hours ago, spyrosjzmichos said: Thank you so much for your kind words! I can totally understand the mojo issue. Has happened to me several times and it involved some pricey kits unfortunately. It's quite painful but once it hits it's difficult to get over it. If there's something motivating me about this build is the camo itself as I really want one in my collection. By the way, how were you able to find the Wolfpack conversion??? I have been searching for it forever and even mailed Wolfpack directly but had no success so far... Hi, I actually bought the set when it first came out many years ago. I did start a WIP here but I have checked and it seems to have vanished into the ether. This was the set I bought this reference when I was in Japan I have these spare resin modifications for the wing tips and fin top which came with some Zotz decals for the Kai from years ago Where are you based in the world? scvrobeson, AlbertD, Vandy 1 VX 4 and 2 others 5 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted May 17, 2020 Author Share Posted May 17, 2020 2 hours ago, crobinsonh said: Hi, I actually bought the set when it first came out many years ago. I did start a WIP here but I have checked and it seems to have vanished into the ether. This was the set I bought this reference when I was in Japan I have these spare resin modifications for the wing tips and fin top which came with some Zotz decals for the Kai from years ago Where are you based in the world? I'm so jealous you manage to get the set! I've come across rumours Wolfpack is considering a re-release but that's that. I'm actually based in Dubai, UAE. Link to comment Share on other sites More sharing options...
crobinsonh Posted May 17, 2020 Share Posted May 17, 2020 If you want the resin parts and would like to take a look at the book I can look at shipping them out to you? spyrosjzmichos 1 Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted May 17, 2020 Author Share Posted May 17, 2020 1 hour ago, crobinsonh said: If you want the resin parts and would like to take a look at the book I can look at shipping them out to you? Sending you PM! Link to comment Share on other sites More sharing options...
spyrosjzmichos Posted May 17, 2020 Author Share Posted May 17, 2020 4 hours ago, PeterOlsen said: Hey, it’s great to see you back ! I hope your models made it safely through the move. We just did the shifting house thing last Christmas , it can be really stressful. Lovely work and I wish you all the best for the rest of the build , Cheers, Pete Thank you Pete! Oh my God! It was one stressful experience, especially as it was done amidst the lockdown. But managed to save most of my models! Link to comment Share on other sites More sharing options...
