Modeller 01 Posted March 9, 2020 Share Posted March 9, 2020 (edited) Hi folks, In this video I'm showing how to apply decals without a gloss varnish basecoat (for models with fine&shallow panel lines). I used older decal for demonstration purpose, best results are achieved with highest quality decals. I`ve been reading lately about applying decals over a `matt` surface. What`s your opinion about that? Cheers! Edited March 9, 2020 by Modeller 01 BiggTim 1 Link to comment Share on other sites More sharing options...
Woody V Posted March 10, 2020 Share Posted March 10, 2020 (edited) Ever tried using Aqua Gloss under a decal? Instead of a gloss coat or polished paint put a drop or more of Aqua Gloss on the model and then apply the decal, blot up any excess and apply a little setting solution. Nothing else needed. The decal will be sucked down into every detail. Might get the same result with any other gloss clear acrylic, but I haven't tried it. Edited March 10, 2020 by Archer Fine Transfers BiggTim and Modeller 01 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 10, 2020 Share Posted March 10, 2020 Ive used Future on decals (mainly just stencil type decals that have lots of clear carrier on them + text) that need to be applied to foil. In that case polishing is not possible as it destroys the grain of the foil, which is what generally gives the foil its realistic appearance. In that case I just put a drop of Future down where the decal should go, then press out with a warm damp cloth from there. Woody V, BiggTim and Modeller 01 3 Link to comment Share on other sites More sharing options...
