mozart Posted July 5, 2020 Author Share Posted July 5, 2020 The remaining scoops and protuberances have been fitted. I need to sort out the area below the coaming in the cockpit which had a little butchery applied earlier in the build, then I think a coat of primer might be in order! Landrotten Highlander, Starfighter, Anthony in NZ and 13 others 16 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted July 6, 2020 Share Posted July 6, 2020 Veeeeeery nice work sir! mozart 1 Link to comment Share on other sites More sharing options...
chrish Posted July 8, 2020 Share Posted July 8, 2020 Very nicely done Link to comment Share on other sites More sharing options...
mozart Posted July 8, 2020 Author Share Posted July 8, 2020 On 7/6/2020 at 10:24 AM, Anthony in NZ said: Veeeeeery nice work sir! 3 hours ago, chrish said: Very nicely done Thanks Anthony and Chris, I’m hoping to get some paint on her tomorrow, I guess the sequence is primer, black gloss and finally silver. Fanes, monthebiff and Anthony in NZ 3 Link to comment Share on other sites More sharing options...
monthebiff Posted July 8, 2020 Share Posted July 8, 2020 Have you thought about using Mr Surfacer 1500 Black surface primer at all Max, it lays down beautifully straight from the rattle can. Regards. Andy mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted July 8, 2020 Author Share Posted July 8, 2020 3 minutes ago, monthebiff said: Have you thought about using Mr Surfacer 1500 Black surface primer at all Max, it lays down beautifully straight from the rattle can. Regards. Andy No I haven't Andy, but if you recommend it then it's worth a try. Will this cut out the need for a gloss black coat or not? Link to comment Share on other sites More sharing options...
Subodai Posted July 8, 2020 Share Posted July 8, 2020 (edited) 5 minutes ago, mozart said: No I haven't Andy, but if you recommend it then it's worth a try. Will this cut out the need for a gloss black coat or not? My understanding of Mr Surfacer is it dries matt/silk so for NMF you'd need some kind of gloss over top of it. Possibly even a 2000 grit polished, compounded and shined gloss black for best NMF results. Saw something recently where a chap did a black gloss coat, but then did a levelling thinner flood coat to "reactivate" the black paint and make it smooth... Edited July 8, 2020 by Subodai mozart 1 Link to comment Share on other sites More sharing options...
mozart Posted July 8, 2020 Author Share Posted July 8, 2020 Well I've just had a look for availability and it seems to be sold out on most sites. One site had some at £10+ for a tin but then wanted £8+ for postage, too rich for me I'm afraid! Link to comment Share on other sites More sharing options...
monthebiff Posted July 8, 2020 Share Posted July 8, 2020 It dries semi gloss Max so you would still need a gloss black as well but it does give you an excellent base to work with. Regards. Andy mozart and Lothar 1 1 Link to comment Share on other sites More sharing options...
mozart Posted July 8, 2020 Author Share Posted July 8, 2020 (edited) 17 minutes ago, monthebiff said: It dries semi gloss Max so you would still need a gloss black as well but it does give you an excellent base to work with. Regards. Andy Thanks Andy. I use the MRP black primer which works pretty well so I'll probably stick with that for the moment. I'm going to test the whole process on the 1/48th Lightning first to get a feel for it all, including how the NMF reacts to masking tape etc. OK, a little further research and it seems the prices quoted were pretty general.......so I've ordered a tin Andy!! It says that there is no need for a further black "top coat" for metallics but a little experiment will soon prove whether this is true or not, watch this space! (I have a cunning plan.....) Edited July 8, 2020 by mozart Subodai and monthebiff 2 Link to comment Share on other sites More sharing options...
quang Posted July 8, 2020 Share Posted July 8, 2020 I don’t quite understand this current trend of using black undercoat for NMF. I tried black but cannot see any difference with the regular grey 1200 Surfacer. The only thing is that if you want a polished metal effect, your undercoat must be equally polished regardless of the colour. Of course YMMV Looking forward to seeing the result of your experiment. Cheers, Quang mozart 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted July 8, 2020 Share Posted July 8, 2020 Hi Quang. Some metal colors are actually slightly transparent and in that case using a gloss black layer improves the light reflection of the metal layer. I once saw a P-51 for which the modeller had used gloss black for the fuselage and a fine grey surfacer for the wings before spraying alclad. I was surprised by the intensity of the difference between both painted areas. Thierry Link to comment Share on other sites More sharing options...
mozart Posted July 8, 2020 Author Share Posted July 8, 2020 11 minutes ago, thierry laurent said: Hi Quang. Some metal colors are actually slightly transparent and in that case using a gloss black layer improves the light reflection of the metal layer. I once saw a P-51 for which the modeller had used gloss black for the fuselage and a fine grey surfacer for the wings before spraying alclad. I was surprised by the intensity of the difference between both painted areas. Thierry Thanks for that explanation Thierry. Your tale about the P-51 isn't too far removed from my cunning plan!! Link to comment Share on other sites More sharing options...
monthebiff Posted July 8, 2020 Share Posted July 8, 2020 2 hours ago, mozart said: Thanks Andy. I use the MRP black primer which works pretty well so I'll probably stick with that for the moment. I'm going to test the whole process on the 1/48th Lightning first to get a feel for it all, including how the NMF reacts to masking tape etc. OK, a little further research and it seems the prices quoted were pretty general.......so I've ordered a tin Andy!! It says that there is no need for a further black "top coat" for metallics but a little experiment will soon prove whether this is true or not, watch this space! (I have a cunning plan.....) I used Mr Surfacer Black as the base coat on my Honda RC213V followed by various Vallejo Mettalics and turned out very nicely with a really good depth to the colours. Regards. Andy Fanes, Anthony in NZ and mozart 3 Link to comment Share on other sites More sharing options...
mozart Posted July 8, 2020 Author Share Posted July 8, 2020 Fabulous finish!! Link to comment Share on other sites More sharing options...
