LSP_K2
1:25 '40 Willys Coupe Gasser
I was finally able to find some of my Tamiya semi gloss acrylic clear, so spritzed the seats to give more of a sheen to them. I had to washout the photo with a flash, just to show them at all. They actually look much better in person.
1 hour ago, mustang1989 said:
Looks good so far Kevin!! Those headers look good. Glad you found some that worked out!
They're really not what I wanted, just what I ended up stuck with. I still may have to remove a pin mark near the bottom that I hadn't noticed until I painted them. Thanks for looking in, Joe.
I just acquired this in a swap for a car model that I bought rather compulsively, but really had no use for at all. I have about four of these kits right now, and will be adding more as well. It still annoys me no end that I had to pass on a fabulous opportunity to pick up a cherry '70 R/T convertible many years ago. That car, a numbers matching R/T convertible with a 440 Magnum, would be worth roughly $60,000 to $80,000 right now. I still can't believe I didn't buy it.
With hood opening now widened a tad (roughly 1/8"), blower and scoop fit just fine. Now I've noticed that the headers hit the fender well inserts, so those will now need to be "adjusted" as well. There's also a bit of crud stuck inside the scoop opening, but I'll get rid of that shortly enough.
I did something tonight that I had really dreaded doing, scribing the fender join lines on my Willlys. Once I figured out what to use as a straightedge, it was actually a snap. They still need to be cleaned up, but they are actually very straight right now. I'm a happy guy.
The Thunderbird is actually supposed to be quite nice, according to the fellas on the model car forum, and might just look quite excellent next to a 1:32 F-102 or some such.
29 minutes ago, D.B. Andrus said:
Really enjoying your passion for cars, Kevin. That will be one nice gasser when done.
Cheers,
D.B.
I certainly hope so, Damian. It's very important to me that I do a nice job on this for two local shows later this year. The paints and decals should be here in a couple days, then I can run some spoon tests to see what's what.
