RLWP Posted December 16, 2019 Share Posted December 16, 2019 (edited) So, I want to model this aeroplane: As found on this excellent website: http://albindenis.free.fr/Site_escadrille/escadrille003_02.htm and present it like this: Also from the same website (highly recommended!) To that end: There are new longerons at the front: and the empty belt spool got smartened up in my lathe: Richard Edited December 16, 2019 by RLWP Sepp, Alain Gadbois, Kagemusha and 6 others 9 Link to comment Share on other sites More sharing options...
RLWP Posted December 16, 2019 Author Share Posted December 16, 2019 (edited) Just to add confusion, these two pictures were apparently taken on the same day (27th August 1916): So, the stork is only on one side*! I wonder what colour that dorsal triangle is? Richard Source: http://albindenis.free.fr/Site_escadrille/escadrille003_02.htm *MORE: I notice the mirror is missing in the left image, and the windshield appears to be different Edited December 16, 2019 by RLWP Out2gtcha, Uncarina, Alain Gadbois and 1 other 4 Link to comment Share on other sites More sharing options...
Uncarina Posted December 17, 2019 Share Posted December 17, 2019 Great start and choice of subject Richard! Cheers, Tom Link to comment Share on other sites More sharing options...
MikeMaben Posted December 17, 2019 Share Posted December 17, 2019 What kit is this Richard ?? Link to comment Share on other sites More sharing options...
RLWP Posted December 17, 2019 Author Share Posted December 17, 2019 24 minutes ago, MikeMaben said: What kit is this Richard ?? It's the Roden SPAD VII If you are 'in' to SPAD VIIs it's an interesting kit. There are a lot of parts in it to make different manufacturer's SPADs, a feed drum and ammunition boxes and a variety of engine cowls. Most are labelled 'do not use' in the instructions You'll notice I have avoided the notorious kit problem - the engine won't fit under all the panels - by leaving the panels off Richard Gazzas and MikeMaben 1 1 Link to comment Share on other sites More sharing options...
quang Posted December 17, 2019 Share Posted December 17, 2019 Richard, There were four Spad VII assigned to Guynemer: S115, S132, S254 and S413 between August 27,1916 and June 1917. The plane on your photos was S115 received on August 27,1916 and destroyed a month later by French artillery (!). The dorsal triangle was black. All these info come from your source, the albindenis site, very informative indeed. HTH Cheers, Quang Gazzas 1 Link to comment Share on other sites More sharing options...
RLWP Posted December 17, 2019 Author Share Posted December 17, 2019 24 minutes ago, quang said: Richard, There were four Spad VII assigned to Guynemer: S115, S132, S254 and S413 between August 27,1916 and June 1917. The plane on your photos was S115 received on August 27,1916 and destroyed a month later by French artillery (!). The dorsal triangle was black. All these info come from your source, the albindenis site, very informative indeed. HTH Cheers, Quang Thank you for that, Quang. My schoolboy French is enough to give me a rough idea of what is on that site, not enough to read details correctly. And Google Translate can just be confusing! Richard Link to comment Share on other sites More sharing options...
RLWP Posted December 18, 2019 Author Share Posted December 18, 2019 Not much to see here. A comparison of the cockpit openings - the etch is thinner, the plastic has the brackets ahead of the instrument panel On the right, I have reprofiled the bulge in the ammunition drum. That bulge covers the rear of the engine including the magnetos. Must have been a pain for the fitters I'm making a new firewall, so I have salvaged the foot bulges Richard Landrotten Highlander, Gazzas, Kagemusha and 1 other 4 Link to comment Share on other sites More sharing options...
RLWP Posted December 20, 2019 Author Share Posted December 20, 2019 The empty belt drum in place, with the lower fuselage halves joined together. I like this open topped fuselage construction, I did this with my Nieuport X build. Richard LSP_Kevin, Out2gtcha, Landrotten Highlander and 5 others 8 Link to comment Share on other sites More sharing options...
Gazzas Posted December 22, 2019 Share Posted December 22, 2019 Very interesting! I'm hooked! Link to comment Share on other sites More sharing options...
RLWP Posted December 22, 2019 Author Share Posted December 22, 2019 I have fallen into a photo-etch rabbit hole. I blame PART of Poland There's a weird, logical insanity to their designs that looks impossible and just works. Take the magneto - supplied as flat etch, there's probably nine parts in there soldered together. The seat on the other hand is Eduard, I prefer their woven base Richard Landrotten Highlander, Kagemusha, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
RLWP Posted February 6, 2020 Author Share Posted February 6, 2020 Whoops, looks like I haven't updated this thread for a while! I have been messing around with the instrument panel and cockpit for ages, at last I have some of them fixed in place The sun shining across my workbench makes for some interesting effects: This image got missed, I'll put it in now: Richard chrish, jimbo, Brett M and 5 others 8 Link to comment Share on other sites More sharing options...
Brett M Posted February 6, 2020 Share Posted February 6, 2020 Very interesting subject and great work. Thanks for sharing the update, looking forward to seeing it progress. RLWP 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 6, 2020 Share Posted February 6, 2020 For sure, looking forward to more on this one, as like Jennings, I'm hoping this may put good WnW Spad vibes out there........ RLWP 1 Link to comment Share on other sites More sharing options...
RLWP Posted February 6, 2020 Author Share Posted February 6, 2020 With the panel and cockpit combing in place, I can get on with the empty belt run: Richard jimbo, Brett M, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
