Troy Molitor Posted April 10, 2020 Share Posted April 10, 2020 Well done Dan. I can certainly agree with the rest. Fascinating to see a one of a kind come together. Great efforts going on here. Troy Dandiego 1 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted April 10, 2020 Share Posted April 10, 2020 Wow, this is massive...ly cool! Curious about your next scratch build! Alain Dandiego 1 Link to comment Share on other sites More sharing options...
Gazzas Posted April 12, 2020 Share Posted April 12, 2020 Totally impressive! Link to comment Share on other sites More sharing options...
R Palimaka Posted April 12, 2020 Share Posted April 12, 2020 I haven't checked in on this project for a while, I'm so glad I did this morning. Your work always gives me a "wow!!". Great progress Dan. Goodness what a beast she is!! Richard Link to comment Share on other sites More sharing options...
Dandiego Posted April 12, 2020 Author Share Posted April 12, 2020 Thanks for all of the positive comments. Most of the construction is finished. Details and paint still to go. One holdup right now is the canopy. I cracked the one that came with the kit. So I will need to reverse engineer it and make a male pattern and make a new one. Can't really go forward until this is done. Dan R Palimaka 1 Link to comment Share on other sites More sharing options...
Dandiego Posted June 12, 2021 Author Share Posted June 12, 2021 Time to finish this beast......stay tuned. Dan Anthony in NZ, Derek B, adameliclem and 3 others 6 Link to comment Share on other sites More sharing options...
Lee White Posted June 12, 2021 Share Posted June 12, 2021 Yes, I need to get my ass in gear. I ended up giving up, I could not get a good canopy. I think the oven on my dental machine was too hot, I bought an $80 machine from Michael's to try and finish the job, hopefully that will do the trick. Derek B 1 Link to comment Share on other sites More sharing options...
Dandiego Posted June 12, 2021 Author Share Posted June 12, 2021 Lee, not to worry. I have sourced the canopy from another vac kit. The canopy from the Tigger models F-11F is just perfect for this kit. Dan Greg W, LSP_Kevin and daveculp 3 Link to comment Share on other sites More sharing options...
Dandiego Posted June 19, 2021 Author Share Posted June 19, 2021 (edited) A small amount of work has been completed. After sitting on the SOD for a year I have actually made a little progress. The original gloss black ALCLAD base coat was still a little tacky after sitting for a year. Also upon close inspection I decided that there were many small blemishes across all areas of the fuselage and wings. So I sanded everything back down and applied Rustoleum Gloss black out of the rattle can. It has a very glossy appearance and dries rock hard in 30 minutes. A definite improvement over the ALCLAD gloss. Biggest task completed was to install all cockpit components. Next was to fit the canopy into position. The small bulkhead at the rear was added and the back end was filled with Bondo. This will give a larger gluing surface when installing the canopy. Stay tuned, hope to have this completed by mid-August for Vegas. Dan Edited June 19, 2021 by Dandiego LSP_Kevin, Landrotten Highlander, Starfighter and 10 others 13 Link to comment Share on other sites More sharing options...
Oldbaldguy Posted June 19, 2021 Share Posted June 19, 2021 Wow! If the USAF had bought this thing back in the day, it would have been spectacular painted gloss black with red lettering like some of the early ANG B-57s. Now that you’ve plundered the F11F kit, what are you going to do with it? Link to comment Share on other sites More sharing options...
Dandiego Posted June 20, 2021 Author Share Posted June 20, 2021 Tigger gives you 2 canopies in his kits. Dan 1 hour ago, Oldbaldguy said: Wow! If the USAF had bought this thing back in the day, it would have been spectacular painted gloss black with red lettering like some of the early ANG B-57s. Now that you’ve plundered the F11F kit, what are you going to do with it? daveculp 1 Link to comment Share on other sites More sharing options...
Dandiego Posted June 24, 2021 Author Share Posted June 24, 2021 (edited) Small progress. I have designed and 3d printed the forward landing bay doors. These will have a thin piece of sheet plastic glued on to serve as the outside of the door. Next.....since the base coat for the Alclad is black, I have added vinyl tape onto the black. This way when I spray the metal colors the walkways will already be taken care of. Top of wing with USAF given the same treatment. Thanks Brian! Canopy faired in. Almost ready. Later, Dan Edited June 24, 2021 by Dandiego Rocat, scvrobeson, denders and 14 others 17 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 25, 2021 Share Posted June 25, 2021 Looks awesome Dan! Dandiego 1 Link to comment Share on other sites More sharing options...
Rocat Posted June 25, 2021 Share Posted June 25, 2021 Wow. Great. Dandiego 1 Link to comment Share on other sites More sharing options...
Gazzas Posted June 26, 2021 Share Posted June 26, 2021 Fantastic work, Dan! Dandiego 1 Link to comment Share on other sites More sharing options...
