Grunticus
Revell's 1/32 Spitfire IX - Too cheap?
A lot has been written about Revell's 1/32 Spitfire IX, and no review can help itself and HAS to compare it to Tamiya's, a four times more expensive kit. Well I do love Tamiya's kits, but can't pass up on this cheap Spit. Hence, my first build on LSP. I switched to 1/32 a while ago because my eyes need bigger things :D
It will be finished as one of these two, haven't decided yet but lean toward the bottom one with the larger roundels:
uc?export=download&id=1GZA5ZblBv_Q8CQ5q0
Starting with the cockpit, I added a few tidbits to make it look a tad more interesting (and expensive :D )
uc?export=download&id=1F84F9__ZSxEMPuuun
uc?export=download&id=1XLDnrgCE0iMpk3S9K
uc?export=download&id=1ljDFU5LJBfjlZnehr
Nice start - now I want to revisit my stalled Revell Spit build :D
Are you planning to add any aftermarket parts?
The seat cushion begs for a replacement seat!
Edited by Fanes
Welcome! Great way to introduce yourself, with a Spitfire that's a little bit different.
Enjoy it! The Revell kit still has lots to offer for the price, and builds up nicely.
...and I know what you mean about having eyes that no longer like the smaller scales. ;)
Richard
No aftermarket will be hurt in this build. The seat, while not perfect, looks okay enough I believe.
Some progress. The instrument panel's raised details do not correspond to the decal at all. Shame. Probably the Mk.II panel in the kit.
uc?export=download&id=183rXc8Gk3BeZmY-ch
Both sidewalls with some dirtying-up.
uc?export=download&id=1ej2ozsg9frF934jEL
But the end-result is passable after a bit of weathering. I still have to add the gunsight and compass.
uc?export=download&id=1i1d8MsknZL5HHdvB9
Wing fit leaves something to be desired (could be me of course), especially the right hand side. Not exactly putty-territory....
uc?export=download&id=1cYQqwpRpk0b9DM2ou
From sprue I made a spreader with small metal wire protruding a tiny bit in to the receiving plastic so it will not slip, secured with siper glue.
uc?export=download&id=1K3Jd_v5RV_aOU3Cwb
Much better and within putty territory:
uc?export=download&id=1b5HF9Pw9ZSY8OZRyv
Squeezing the wing dihedral in will also lessen it a tad more. So far, this Revell does not dissappoint me.
Edited by Grunticus
Added images
Did the dutch Spits have the armour plates behind the seat installed?
Revell simply forgot to include one in their kit..
The Revell seat depicts a post war seat cushion which may apply to your Spit.
Nice fix on the wings. I'm taking notes for my build!
 They most probably were delivered with them installed. I have no idea if MK632 had it while wearing this livery. I did think about adding it but reasoned it was just dead weight post WW2 and was removed.
Got a bit of work done on the wing seams. First I masked them off.
uc?export=download&id=1r5_oVWowG3mcl5uH_
Next I filled them with Vallejo acrylic putty. I never used this before and am quite impressed with the stuff so far. The tube has a tiny nozzle which helps to apply it precisely. It dries quickly but needs time to dry hard enough for sanding. Obviously I found that out by being too impatient :whistle:
uc?export=download&id=1q57GfS1QITGxlRgAM
Then I smoothed it out with a wet finger, let it dry, and lastly applie a final layer of good old Tamiya putty. I know for a fact it sands out ver smoothly, the Vallejo stuff I will test in that respect on another part of this Spit.
uc?export=download&id=1Fo4RKV8siWXBc6NND
uc?export=download&id=1NJrpedw2-ZUaaEQZ3
I also started on the lower engine cover. To get that to fit snuggly one needs to reserve an hour of their time, but I got it to fit nicely without the need of much putty as i do not like sanding. I still had to invest time, just not in sanding. Plus, the adjescent detail would be destoyed by sanding. That makes me lazy or efficient depending from point of view :D Pics will follow next time.
Still happy!
