Pascal Posted November 11, 2019 Share Posted November 11, 2019 I want to try to vacuform a windshield and side windows of a +/- 1/50 scale car. The master is from the kit and is styrene. Can I vacuform directly onto the styrene master ? Will the vacuformed plastic stick to the master ? All help is welcome. Sincerely Pascal Link to comment Share on other sites More sharing options...
themongoose Posted November 12, 2019 Share Posted November 12, 2019 Hey Pascal you'll have fun at this for sure! I learned last year to make a canopy. I put quite a bit into my post but honestly alot came from a fellow hobbyist at our local club. Simple tools, I learned it's alot about watching the p[lastic and knowing when it droops just enough to indicate it's ready to form. In your case you will need to make a mold from the styrene part you have otherwise you will ruin it. Check out what I have here... and this one from BiggTim has alot in it... I'm sure others will chime in as well. Looking forward to seeing what you do :-) Pascal 1 Link to comment Share on other sites More sharing options...
BiggTim Posted November 27, 2019 Share Posted November 27, 2019 (edited) Any luck so far, Pascal? I finished my vacs with some success, see here... Edited November 27, 2019 by BiggTim Link to comment Share on other sites More sharing options...
blackbetty Posted November 28, 2019 Share Posted November 28, 2019 i used kit parts as a master a couple of times, but fill them with carputty before pulling the vac and get them smooth. i had no sticking problem. if you have a vac part that you want to dupilcate, i also fill it with carputty, but remove the original part if it is thin enough. then i pull over the carputty master. all done with a selfmade box and vacuum cleaner Link to comment Share on other sites More sharing options...
