sandbagger Posted January 7, 2020 Author Share Posted January 7, 2020 Hi all, As my build of the Austro-Hungarian Aviatik 'Berg' D.I is complete (apart from the display case), it's time for me to get back to the Macchi M.5 build. Thanks to input from other modellers I have more information that I'll need to include in this build, Mike RLWP 1 Link to comment Share on other sites More sharing options...
Aluxe Posted January 8, 2020 Share Posted January 8, 2020 I love this model, Link to comment Share on other sites More sharing options...
sandbagger Posted January 8, 2020 Author Share Posted January 8, 2020 Hi all, I thought I get back into the Macchi M.5 by hitting the beaching trolley and trestles first. The four tie rings on the corners of the beaching trolley are metal rings. The photo-etch parts supplied in the kit are flat and two-D. Therefore I cut away the 'rings' from the photo-etch parts and replaced them with rings of 0.5 mm diameter lead wire. I also modified the photo-etch tie ring holders to suit the replacement rings. Also in the photograph you can see protective padding, which I'll be adding to the trolley and trestles. Mike Alain Gadbois, RLWP and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
sandbagger Posted January 10, 2020 Author Share Posted January 10, 2020 Hi all, The beaching trolley and support trestles are done. The metal wheel rims were annealed to make them easier to bend and to give a better 'used' look. The wood beaching trolley and trestles were stained with 'AK Interactive' wood wash, then sealed with 'Alclad' Flat (ALC314). The top padding was represented with 'Tamiya' Rubber Black (XF85) and algae staining by water based ‘Derwent’ Inktense 24 pencils. Wear on the padding was from sponging 'Tamiya' weather set E (green) and dirt on the axle from 'Flory Models' dark dirt wash, Mike LSP_Kevin, Alain Gadbois, RLWP and 3 others 6 Link to comment Share on other sites More sharing options...
sandbagger Posted January 10, 2020 Author Share Posted January 10, 2020 (edited) Hi all, True to form this kit has already shown problems. The instructions indicate where the forward bulkhead and pilot's seat support should be located. The bulkhead locates on the hull bottom (effectively the cockpit floor). If the instructions are followed, it will result in the hull bottom not fitting into the fuselage as the bulkhead would be too far forwards. The pilot's seat support location is such that, when fitted, the pilot's seat is too far rearwards in the cockpit, so needs to be moved forwards on the seat support. This means the control column is then too close to the seat. The forward bulkhead is shown in the correct location. The pilot's foot boards assembly may need to be modified to move the control column forward and away from the pilot's seat Mike Edited January 11, 2020 by sandbagger Gazzas, RLWP and LSP_Kevin 3 Link to comment Share on other sites More sharing options...
sandbagger Posted January 11, 2020 Author Share Posted January 11, 2020 (edited) Hi all, I've cut away the centre foot board and rear cross member on the hull floor. This allows the control column to be positioned more realistically, otherwise it would be too close to the seat. Also allows fitting of the 'V' shaped seat support. A notch was cut into the centre cross member on the hull floor to allow the torque bar of the control column to be adhered to the hull floor (better support) These changes will allow the control column to be positioned further away from the front of the pilot's seat, Mike Edited January 12, 2020 by sandbagger LSP_Kevin, Rivas, thierry laurent and 1 other 4 Link to comment Share on other sites More sharing options...
sandbagger Posted January 12, 2020 Author Share Posted January 12, 2020 Hi all, I've modified the pilot's foot boards and seat support to: Cut away the centre foot board and rear cross member on the hull floor. This allows the control column to be positioned more realistically, otherwise it would be too close to the seat. Added more lightening holes in the seat back, as per the official drawing. Added the 'V' shaped support (made from thick paper) below the seat. This also housed the control column torque tube, aileron control bell crank and aileron control pulley and control cables. Added nail head indentations to the foot board to cross member joints. Mike thierry laurent, RLWP, Trak-Tor and 2 others 5 Link to comment Share on other sites More sharing options...
sandbagger Posted January 13, 2020 Author Share Posted January 13, 2020 Hi all, There's still a lot of detail to do for the cockpit area, including thinning and roll edging the seat as well as adding the bulk head seat fixing at the top of the seat. Also the seat needs to have the access for the seat belts to pass through, as the kit instructions show them positioned over the sides of the seat, not through it, Mike RLWP and USMC Herc 2 Link to comment Share on other sites More sharing options...
sandbagger Posted January 13, 2020 Author Share Posted January 13, 2020 Hi all, Pilot's seat modified: Thickness of seat back reduced. Seat belt slots added. Seat back rolled edge added (0.4 mm lead wire. Mike TorbenD, Out2gtcha, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
sandbagger Posted January 15, 2020 Author Share Posted January 15, 2020 Hi all, The rear edge of the cockpit rim was fitted with shoulder padding which is not in the kit. I represented this padding using 'Milliput' putty. Once it has fully cured I'll clean it up. The photo-etch supplied with the kit has part 19, which is intended to represent a curved support for the top of the pilot’s seat, although I could not find any references to this type of seat support. However photographs do show a fixture connecting the top, rear edge of the seat to the rear bulkhead of the cockpit. I represented this fixing using 0.5 plastic rod. The inlet and exhaust valves on the 'Isotta Fraschini' V4B engine are operated by an overhead shaft. The kit shaft is moulded as one shaft. The actual engine had three separate shafts. Also the shaft mounting to the engine do not align. I'll correct by cutting away the mountings from the shaft then drill out the three segments and insert brass tubes. Mike RLWP, LSP_Kevin and USMC Herc 3 Link to comment Share on other sites More sharing options...
Troy Molitor Posted January 15, 2020 Share Posted January 15, 2020 Great efforts going on here Mike. Troy Link to comment Share on other sites More sharing options...
sandbagger Posted January 16, 2020 Author Share Posted January 16, 2020 Hi all, The valve operation on the 'Isotta Fraschini' V4B engine is strange by comparison to other in-line engines of the period. Normally the inlet and exhaust valves on each cylinder would be operated from a single overhead 'camshaft'. However photographs and drawing for this engine show three separate shafts, each operating the valves for its cylinder bank. I can only assume the drive for the three shafts is located below them in the lower half of the overall housing, which is not represented on the kit part. The kit part, including the inlet manifolds seems to have been modelled more on that fitted, for example, on the Daimler-Mercedes in-line engines. I've modified the overhead operating shaft by cutting it into the three sections, removing the kit shaft and replacing it with 1.8 mm diameter tubing. This required some re-profiling of the operating shaft mountings at each end of the engine (radiator and propeller shaft ends), including 2 mm extension to fit to the end vertical drives. The tubes still need to be blocked at each end as the shafts were solid, not tubular. This has also shown up several other areas of the engine that require attention (so far): Both inlet manifolds and the two carburettors are incorrectly moulded - the manifolds too long and wrong shape - the carburettors are joined, but in fact were separately located. No spark plugs location. No water pump supplied in the kit. Mike RLWP, Lothar, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
sandbagger Posted January 18, 2020 Author Share Posted January 18, 2020 Hi all, The radiator assembly done. This needs to be done now and added into the radiator housing and engine bottom fairing. Then I can start to work on the missing components at the forward end of the engine, such as magnetos, pipes etc, Mike Wackyracer, LSP_Kevin and RLWP 3 Link to comment Share on other sites More sharing options...
sandbagger Posted January 18, 2020 Author Share Posted January 18, 2020 Hi all, Work continues on modifying the kit engine to represent what the engine actually looked like. I've now added a 'camshaft' below the 3 vale lever shafts from 1.8 mm diameter tube. Also added a pair of 'Taurus' magnetos and a drive shaft (from the spares box). Finally the drive at the rear end of the engine (1.0 mm tube and drive head modified from spares). It's all a bit rough at the moment and I still need to add water pump and if possible and oil pump, plus their associated pipes (where possible). Also the ignition lead support tube etc. Mike Wackyracer, LSP_Kevin and RLWP 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 18, 2020 Share Posted January 18, 2020 Very impressive work so far, Mike! Kev Link to comment Share on other sites More sharing options...
