Subodai Posted March 13, 2021 Share Posted March 13, 2021 I would imagine the 'easy' way would be to drill all the rivet holes just enough that if you were to 'submerge' the part in the box of solder balls, then pull it out, they would self-find the holes.. then.. just.. wipe on some glue and hey presto, rivet holes filled... right? Uncarina, Pete Fleischmann and Starfighter 3 Link to comment Share on other sites More sharing options...
scvrobeson Posted March 14, 2021 Share Posted March 14, 2021 Or you could go completely crazy and drill out every rivet hole, and insert MasterClub plastic rivets into them. I've also seen car guys do that, that is a level of detail-freak I think I'll avoid for now. Matt Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Starfighter Posted March 15, 2021 Share Posted March 15, 2021 I think I personally will go for a combination of both techniques - Archer rivets for the large surfaces and soldering balls for complicated patterns on small panels. Derek B, Pete Fleischmann, scvrobeson and 1 other 4 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 15, 2021 Author Share Posted March 15, 2021 (edited) Hey all- after jigging-up the blades 3 separate times, I finally got them to a pitch/thrust angle that is believable- not over done..I looked at a lot of photos- a little more twist would be good, but if I can’t get there from here, I’m good with this- not a great photo, but you get the idea- Because each blade is slightly different, and is matched to a specific spot on the rotor head, they are numbered and kept in a rack so I don’t confuse them- cheers Pete Edited March 15, 2021 by Pete Fleischmann Uncarina, scvrobeson, johncrow and 15 others 18 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 15, 2021 Author Share Posted March 15, 2021 Here’s a better look- cheers Pete Renegade, Derek B, Harold and 19 others 22 Link to comment Share on other sites More sharing options...
Yordy Posted March 15, 2021 Share Posted March 15, 2021 That f-5 looks cool also, is that in 1/18? Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 15, 2021 Share Posted March 15, 2021 Wow, that looks amazing Pete!! Pete Fleischmann and Harold 1 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 15, 2021 Author Share Posted March 15, 2021 29 minutes ago, Yordy said: That f-5 looks cool also, is that in 1/18? That’s actually an AT-38B in1/16th scale- Derek B, Out2gtcha and Yordy 3 Link to comment Share on other sites More sharing options...
Timmy! Posted March 15, 2021 Share Posted March 15, 2021 Looks like the real thing caught with a high speed shutter. Well done bro!! Starfighter and Pete Fleischmann 1 1 Link to comment Share on other sites More sharing options...
Mr Matt Foley Posted March 15, 2021 Share Posted March 15, 2021 Amazing work Pete! Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Oldbaldguy Posted March 15, 2021 Share Posted March 15, 2021 Mind is thoroughly blown. Are you going to paint the brass or leave it -uh- brass? Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 15, 2021 Author Share Posted March 15, 2021 32 minutes ago, Timmy! said: Looks like the real thing caught with a high speed shutter. Well done bro!! thanks brother. You’ve been keeping me straight the entire build- couldn’t do this without your expert input my friend- Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted March 15, 2021 Author Share Posted March 15, 2021 11 minutes ago, Oldbaldguy said: Mind is thoroughly blown. Are you going to paint the brass or leave it -uh- brass? ...thinking I’m gonna leave it. There is no hiding the fact that it’s on a stick, so I’ll just polish the brass and embrace it! Out2gtcha 1 Link to comment Share on other sites More sharing options...
brahman104 Posted March 15, 2021 Share Posted March 15, 2021 Yep, gotta say you've nailed the rotor look. It's nice to see one without the "saggy banana" look! Brilliant work Pete! Craig Harold and Pete Fleischmann 1 1 Link to comment Share on other sites More sharing options...
Derek B Posted March 15, 2021 Share Posted March 15, 2021 This just gets better and better Pete. Derek Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
