Wolf Buddee Posted October 20, 2021 Share Posted October 20, 2021 Fantastic Pete! I can’t imagine a more well deserved award. Just freakin’ awesome! Cheers, Wolf Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted October 20, 2021 Author Share Posted October 20, 2021 On 10/17/2021 at 3:58 PM, Juggernut said: Awesome and well deserved! I Googled Wings and Wheels Modelers and was pleasantly surprised that the show was very close to where I spent a lot of my childhood….Northampton, MA. Both of my parents grew up there and my Great Grandfather (Oscar Clark) used to craft violins in his shop as an understudy/successor of Andrew Hyde. Parents only moved away when Dad was commissioned a second Lt. in the USAF in 1959. Again, kudos on on a job well done and justified recognition. Thats awesome- it was just up the road from where I am- about an hour Harold 1 Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 On 10/20/2019 at 8:52 AM, Pete Fleischmann said: Hello All! While I was waiting for this kit to show up, I completed the Live Resin figures.. link to that here click me The first thing that jumped out at me with the kit was the cabin roof. The later block of Pavehawk has most of the fabric sound-proofing material removed. I considered scratchbuilding the entire affair, but decided it would take about the same amount of time to simply re-work the kit part. The cross-hatch areas are what needed to be removed. Many evenings with a drill and file and I was done with the basics. This will get detailed further- Cheers Pete Pete, that is an amazing amount of patience. Nice work. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 On 12/15/2019 at 9:05 PM, Pete Fleischmann said: Hello all! slow grind on this, but am chipping away at it! Might not look like much progress, but I have spent waaaayyy more time looking at obscure reference photos of the ceiling, (most shot at weird angles) than I have building components.. more to follow! Thanks for all the words of encouragement!! cheers Pete Have you ever taken a tour of the actual HH-60G Pave Hawk? You have captured an amazing amount of detail. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 On 1/29/2020 at 12:57 PM, Pete Fleischmann said: Hey all, fast rope assembly is done. It was a kitbash of Kitty Hawk parts, live Resin parts, and scratch. Thanks for for stopping by- Nice attention to detail to the H-Bar/FRIES. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 On 2/1/2020 at 10:19 AM, Pete Fleischmann said: Thanks G-dub and all for the encouraging words! Greatly appreciated friends! I needed a break from the ceiling work, so I thought I’d take a stab at the ALQ-144 IR disco light. First time using this Hasegawa irredentist film- It it was a little tricky to apply. It is adhesive backed and very thin, and somewhat stretchy..similar to BMF- cheers Pete What a great idea for the Disco Ball. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 On 2/13/2020 at 7:20 PM, Pete Fleischmann said: Hey all- here’s where I’m going with the overhead panel. Is it 100% accurate? Nope. About 90% though. Ordinarily I would say color photo etch is cheating..but in this case, I modified it quite a bit..adding knobs and switches from Anyz, a new APU fire handle, etc. I do not plan on using any other color photo etch on this build.. just sayin. I’ll get it to fit- likely will have to re-do the power lever/fuel lever quadrant. More to follow! The remaining kit parts for the overhead area will get some tweaking too- this panel will get a spray of flat coat for sure. The glossy finish bugs me- Edit: Here's a tip. Remember that black flexible super glue from Timmy! that I used for the wire harnesses? Well that stuff was perfect for attaching the knobs to the panel. just a dot applied with whatever small tipped tool you fancy to the panel, and then place the knob while holding it with a good tweezer. Expect to lose a few! cheers Pete The Power Control Lever (PCL) while labeled as such on all USAF MH & HH-60G aircraft (US Army Spec.) is referred to at the Throttle. Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 On 3/30/2020 at 9:10 AM, Pete Fleischmann said: Hey all- starting to get my head around the gear, clutter, etc that needs to fill the cabin- I have a ton of resin items and such..the trick is to match my references as close as possible while getting that haphazard look to the gear stowage. These medical bags are a “for sure”, the rest will hopefully come naturally- These are just set in place as a sanity check to see if they’ll work- basically the whole aft cabin bulkhead needs needs to be covered with “stuff”, and more “stuff” piled in front of it..”stuff” jammed between the cabin seats..etc- cheers Pete No Auxiliary Fuel Tanks in the cabin? We normally carried over 2,000 lbs of fuel in the Robinson Tanks attached to the bulkhead. We then attached a Rescue Board to the forward face of the fuel tanks and attached two litters and medical equipment to the Rescue Board. Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 (edited) On 2/2/2021 at 6:54 PM, Brett M said: Super nice work, Pete! Jealous....you should see my PAVE HAWK from a few years ago lol Second pic, above the plume detector, flash on the edge? I need to research my logbooks to see if I actually flew #206 Edited September 29, 2022 by Zorro Research Logbooks Brett M 1 Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 On 12/10/2020 at 8:13 PM, Pete Fleischmann said: Hello all- got the first colors down on the exhaust. More to do, but enough for tonight. cheers Pete Pete, did you build the complete 701 Engines? I did not see an photos of the engines... Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Zorro Posted September 29, 2022 Share Posted September 29, 2022 Overall this is the very best build I have witnessed of the HH-60G Pave Hawk. Job Well Done! Pete Fleischmann 1 Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted September 30, 2022 Author Share Posted September 30, 2022 56 minutes ago, Zorro said: Pete, did you build the complete 701 Engines? I did not see an photos of the engines... I did build them; but only painted the parts that would be visible- cheers Pete Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted September 30, 2022 Author Share Posted September 30, 2022 38 minutes ago, Zorro said: Overall this is the very best build I have witnessed of the HH-60G Pave Hawk. Job Well Done! Thanks! eventually I’ll get after an MH-60T too- I learned a lot about the -60’s with the Pavehawk build- appreciate the kind words! cheers Pete Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted September 30, 2022 Author Share Posted September 30, 2022 1 hour ago, Zorro said: Have you ever taken a tour of the actual HH-60G Pave Hawk? You have captured an amazing amount of detail. I have a friend who flew them with the Long Island Rescue unit in Afghanistan- he sent me a ton of pictures! P Link to comment Share on other sites More sharing options...
Pete Fleischmann Posted September 30, 2022 Author Share Posted September 30, 2022 1 hour ago, Zorro said: No Auxiliary Fuel Tanks in the cabin? We normally carried over 2,000 lbs of fuel in the Robinson Tanks attached to the bulkhead. We then attached a Rescue Board to the forward face of the fuel tanks and attached two litters and medical equipment to the Rescue Board. All the pics that Gemo sent me from downrange had the Robbie tank removed- cheers P Link to comment Share on other sites More sharing options...
