Sign in to follow this
wmoran
Doped fabric patches covering bolt heads?
While perusing Mike Maben's images in his response to Alan's question about Fw 190 landing gear electrical harness images, I noticed this image:
I've often noticed red primer circles in these locations on photos and profiles.  In this photo, they look like doped fabric patches, which would explain the use of red primer.  Can anyone confirm?
Thanks (particularly to Mike for the great photos),
Bill
4 hours ago, MikeMaben said:
Looks like fabric patches to me Bill.
Don't know that they were 'always' primed red tho.  :shrug:
Don't think you can use terms like "always" when it comes to German WW2 camo because you will always find exceptions.  That being said it was very common to see fabric like this primed with a darkish red color.
When I built my version of "blue 12" (Fw190D-9) almost 20 years ago now, I had the same question.  I eventually learned and can confirm that those circles are indeed fabric patches covering the attachment hardware for the landing gear doors.
The red primer is not a constant but I'll speculate that it is the result of the landing gear cover being removed and reinstalled (or replaced) and the patches hastily covered with the primer/dope/paint.  Normally these would be the underside color.
I don't have a written reference for it at this point, just what I remember from what I learned along the journey.
Edited by Juggernut
Why would they have done that, are they projecting bolt heads or similar?
Richard
1 hour ago, Jennings Heilig said:
They’re bolts in a depression in the surface of the door. Covered to improve aerodynamics and prevent gunk building up in them.
I guess that makes sense, although I'm not sure a fixing full of glue is much better than a fixing full of oily crap (technical term)
Perhaps this was to prevent corrosion?
Richard
52 minutes ago, Juggernut said:
The fabric patches covered the recess.  The recess itself wasn't filled in, just covered over.
Perhaps I don't understand the size of the recess then
Richard
Richard
Big enough to hold the bolt and the wrench required to install it.  The patch was a good bit bigger than the hole.  It had to have an edge to adhere to.  You can see the actual hole under the patches in the photo at the top of the thread.
Edited by Jennings Heilig
Ahh, now that makes sense. A bolt head sitting in a circular hole.
Thank you
Richard
Mike,
I didn't mean to imply that they were always seen in the red primer, just that I had seen numerous photos/profiles where they were shown that way.  I was of the understanding that the red primer was primarily for fabric surfaces, even though it was often used on other surfaces as seen in numerous photos.  I had just never seen such a close-up shot that showed that there were fabric patches.  Juggernaut explains the presence of the red primer the way I surmised it came to be visible.
Bill
That's great, Kevin. I tried googling for an image and failed
It looks a bit like there was a 'correct' size of patch that would fit in the recess - bet that was a fiddly job!
Richard
