Mel Posted September 20, 2019 Share Posted September 20, 2019 Hi guys, I have only two questions What is the cockpit color of the Mitsubishi A6M5 Zero Fighter Model52, would the IJN XF-71 be correct? And the interior frames of the cockpit cockpit of this model are the same color of the cockpit, the color of the fuselage (in this case green) or black? The model that I have and for the moment I will build is the Mitsubishi A6M5 Zero Fighter Model52 (tamiya 1:32) Fred Jack 1 Link to comment Share on other sites More sharing options...
Kurfurst4 Posted September 20, 2019 Share Posted September 20, 2019 Are you building a Nakajima or Mitsubishi built machine. Your box top image shows a Nakajima machine with the up swooping camo demarcation line near the horizontal stabilizers. Mitsubishi's camo was a straight line to the tail cone, no "upsweep". The cockpit for the Mitsubishi was darker than the Nakajima ones. See here.-John http://www.j-aircraft.com/faq/A6M.htm#Mitsubishi 'cockpit color' on Type 22 Out2gtcha, Isar 30/07, LSP_K2 and 1 other 4 Link to comment Share on other sites More sharing options...
Mel Posted September 20, 2019 Author Share Posted September 20, 2019 (edited) 29 minutes ago, Kurfurst4 said: Are you building a Nakajima or Mitsubishi built machine. Your box top image shows a Nakajima machine with the up swooping camo demarcation line near the horizontal stabilizers. Mitsubishi's camo was a straight line to the tail cone, no "upsweep". The cockpit for the Mitsubishi was darker than the Nakajima ones. See here.-John http://www.j-aircraft.com/faq/A6M.htm#Mitsubishi 'cockpit color' on Type 22 Thank you for the answer, but in the box (the photo box is the same as my model) is the Mitsubishi A56M Zero (ZEKE), could it be that TAMIYA was wrong to name the model? by the way I don't see the 52 model in the link that happened to me And one last doubt, as I asked before, then the cabin being darker would be different from TAMIYA's Xf-71 color, right? and the interior frames of the cabin what color would they be? black, the same color of the cockpit or the same color of the fuselage? So this would be the right one for this model, right? Edited September 20, 2019 by Mel Link to comment Share on other sites More sharing options...
Mel Posted September 20, 2019 Author Share Posted September 20, 2019 (edited) 43 minutes ago, Kurfurst4 said: Are you building a Nakajima or Mitsubishi built machine. Your box top image shows a Nakajima machine with the up swooping camo demarcation line near the horizontal stabilizers. Mitsubishi's camo was a straight line to the tail cone, no "upsweep". The cockpit for the Mitsubishi was darker than the Nakajima ones. See here.-John http://www.j-aircraft.com/faq/A6M.htm#Mitsubishi 'cockpit color' on Type 22 Sorry to quote you again, I have searched other sites too and on this website the Mitsubishi A6M5 type 52 the color matches as in the box and the instructions http://www.j-aircraft.com/walk/walkarou.htm Edited September 20, 2019 by Mel Link to comment Share on other sites More sharing options...
Juggernut Posted September 20, 2019 Share Posted September 20, 2019 (edited) Your image from above is painted as a Mitsubishi built A6M5. Notice the demarcation line between the green and the grey under the horizontal stabilizer. Below is an A6M5 painted (poorly) as a Nakajima built A6M5 Notice the upward sweeping demarcation line between the green and the grey from the trailing edge of the wing to the leading edge of the horizontal stablilier. This "swoop" as we call it, is indicative of all Nakajima built A6M5's. No, XF-71 is not correct, it's not even close...I really don't know where Tamiya got that color from to be honest. The cockpit color for a Nakajima manufactured A6M5 will be a grayish-yellow-green similar to but distinctly more yellow than RAF interior green. The cockpit color for Mitsubishi built A6M5's will be closer to US Interior green but darker. If you let me know what paint line you're planning on using, I might be able to let you know if they have these colors already available of if you'll need to mix them. For ease of painting, everything structural behind the rollover bulkead (behind the pilot's seat) would be painted aotake. In all reality, there was a floatation bag at frame 7 so everything that Tamiya has behind there would not have been able to be seen on an A6M5 during it's time in service. Here's Ryan Toew's tweak list for the Tamiya A6M5 kit...it's worth your time if you want to be as accurate as possible. https://www.largescaleplanes.com/articles/article.php?aid=3332 Also, there's a top notch article by Jim Lansdale here: http://www.j-aircraft.com/research/zeroclr.htm Edited September 20, 2019 by Juggernut Alain Gadbois, Mel and MikeMaben 2 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted September 20, 2019 Share Posted September 20, 2019 As far as I know the floatation bags disappeared during the A6M3 production (probably from the type 32). Link to comment Share on other sites More sharing options...
Juggernut Posted September 21, 2019 Share Posted September 21, 2019 1 hour ago, thierry laurent said: As far as I know the floatation bags disappeared during the A6M3 production (probably from the type 32). Can you provide me a reference for that information? Everything I'm finding indicates (visually...the inflation control and tubing are in the cockpit, the mushroom-ended hand holds that retracted into the fuselage) indicates that the wing and fuselage floatation bags were installed at least through the A6M5 production. Every reference I can find shows the inflation control on the left side of the cockpit behind the trim wheels. I could be mistaken but I don't believe those items would be there if the bags weren't installed... Link to comment Share on other sites More sharing options...
Mel Posted September 21, 2019 Author Share Posted September 21, 2019 (edited) 15 hours ago, Juggernut said: Your image from above is painted as a Mitsubishi built A6M5. Notice the demarcation line between the green and the grey under the horizontal stabilizer. Below is an A6M5 painted (poorly) as a Nakajima built A6M5 Notice the upward sweeping demarcation line between the green and the grey from the trailing edge of the wing to the leading edge of the horizontal stablilier. This "swoop" as we call it, is indicative of all Nakajima built A6M5's. No, XF-71 is not correct, it's not even close...I really don't know where Tamiya got that color from to be honest. The cockpit color for a Nakajima manufactured A6M5 will be a grayish-yellow-green similar to but distinctly more yellow than RAF interior green. The cockpit color for Mitsubishi built A6M5's will be closer to US Interior green but darker. If you let me know what paint line you're planning on using, I might be able to let you know if they have these colors already available of if you'll need to mix them. For ease of painting, everything structural behind the rollover bulkead (behind the pilot's seat) would be painted aotake. In all reality, there was a floatation bag at frame 7 so everything that Tamiya has behind there would not have been able to be seen on an A6M5 during it's time in service. Here's Ryan Toew's tweak list for the Tamiya A6M5 kit...it's worth your time if you want to be as accurate as possible. https://www.largescaleplanes.com/articles/article.php?aid=3332 Also, there's a top notch article by Jim Lansdale here: http://www.j-aircraft.com/research/zeroclr.htm Hi Jugernaut, thank you very much for your answer and your help, I am very happy that you tell me that, I was planning to use Tamiya, Mr hobby,AK,MRP... or at least know what mix of paint I have to use, it would be appreciated to help with the paint of the cockpit . Another thing, the bottom fuselage is not white right, it has gray, right? I was looking and I've seen this, I don't know if it's right, what do you think? http://www.aviationofjapan.com/2008/06/zero-interior-colours.html?m=1 in theory Mr. Hobby has the color Edited September 21, 2019 by Mel Fred Jack 1 Link to comment Share on other sites More sharing options...
Kurfurst4 Posted September 21, 2019 Share Posted September 21, 2019 Mitsubishi cockpit is Mr Hobby 126. Nakajima cockpit is Mr Hobby 127. Fuselage bottom is gray not white.-John Mel 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted September 21, 2019 Share Posted September 21, 2019 6 hours ago, Juggernut said: Can you provide me a reference for that information? Everything I'm finding indicates (visually...the inflation control and tubing are in the cockpit, the mushroom-ended hand holds that retracted into the fuselage) indicates that the wing and fuselage floatation bags were installed at least through the A6M5 production. Every reference I can find shows the inflation control on the left side of the cockpit behind the trim wheels. I could be mistaken but I don't believe those items would be there if the bags weren't installed... Sorry, I checked and indeed my memory failed. The type 32 still had it. At least TM said it. Regarding the A6M5, I do not know why they removed it. This was possibly linked to the relocation of components in the rear fuselage, the fact they were now using zeros ashore, the fact they possibly realized this was not that useful, the intention to simplify production? Mel and Out2gtcha 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted September 21, 2019 Share Posted September 21, 2019 By the way, as far as I know, no A6M5 wreck was found with them. However this does not mean this was not used on some of such planes. Information about that topic is elusive to say the least! Mel 1 Link to comment Share on other sites More sharing options...
nmayhew Posted September 21, 2019 Share Posted September 21, 2019 This is very useful info, so thank you all and esp to Juggernut as many will know MRP do not (yet) make any designated Japanese colours, but they do have a very large selection of colours it it may be easier for us to match to what they already make if we have credible colour swatches to work from so what do you think of those offered by Mel thanks again to all Mel and Out2gtcha 2 Link to comment Share on other sites More sharing options...
John1 Posted September 23, 2019 Share Posted September 23, 2019 That tweak list is fantastic. Kudos to Ryan for the meticulous research he put into this. Mel 1 Link to comment Share on other sites More sharing options...
ringleheim Posted September 23, 2019 Share Posted September 23, 2019 It's weird that the Tamiya call-out for "interior green" on their zero kits is so far off either of the 2 interior choices. This is a Japanese company making a Japanese icon. You would think they would have access to the right resources or information to get the color more or less exactly right. I know they have many different gray colors for their 1/700 and 1/350 IJN ship models...representing the differing grays used at the different ship building arsenals in Japan. Maybe those are off too! Mel and CATCplSlade 2 Link to comment Share on other sites More sharing options...
Fred Jack Posted September 23, 2019 Share Posted September 23, 2019 All Zeros were called Mitsubishi even when built by Nakajima. This practice is true with a lot of planes built by many manufactures to keep demands. We are fortunate with the Zero in that the manufacturer can be identified by the paint job. Mel 1 Link to comment Share on other sites More sharing options...
