PietvWdV Posted December 5, 2005 Share Posted December 5, 2005 Hi Jens Welcome to watercolor washes 101. This is they way I do it. There are many ways to do this but you will later find your own way. Here is a good place to start playing. First, we will put a coat of future on the model. Here is what you need : I use the smaller brush for items like the landin gear, and the bigger one for the skin. They are very soft brushes. Also you need some future (or what ever it is called in your country) Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 Next I take a brush that is clean and dry and I wipe the model to remove any little hairs and dust. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 Then I dip my wide soft brush in the future. I only dip the tip and use very very little. With future there is always more than you think on the brush. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 Now I put the brush on the model and I spread the future around. That one dip was enough for the whole side. I brush it until it is spread evenly. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 When it is done it is wet and shines like this. Now put it down and let it dry. Some will leave it for a day, but I find for watercolour washes and hour or two is enough. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 In this picture the first coat of future is dry. If you model was painted in a matt paint, then the first coat or two of future will have this dull shine. You can now put another coat if you want. When you ever want to start doing washes with oil paints, you will need more coats, but for me with watercolour I find one or two coats enough. The dull shine helps the watercolour stick. For this excersise I only put one coat. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 I now use the smaller brush to put future on this wheel strut. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 After a few hours it is dry enough and we proceed. Here is the watercolours. I use two brushes. One bigger cheap watercolour brush (I got it with the watercolour set) and one small fine tip brush. I also have some papertowel and cotonbuds and some water. Brush your teeth or eat and apple before proceeding. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 I use the dark brown and a little black. I mix them with water like I want. Sometimes you want a lot of water, sometimes very little with the paint. When you experiment you will find your own way. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 There are many ways to apply the paint. One is to follow the panellines closely. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 You can also mess over the lines a bit if you like. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 You can achieve various effects, dont be scared to try. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 Dont be afraid of my long fingernails! I play guitar for a living You can then take a dry cottonbud and roll it over the lines you painted while they are still wet or a bit dryer, to remove some paint and get an effect you like. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 Sometimes the results are very nice and heavily weathered. Be creative. Dont paint the whole panel line, vary the darkness and dirt amount. if you like. try different things. Link to comment Share on other sites More sharing options...
PietvWdV Posted December 5, 2005 Author Share Posted December 5, 2005 If it is too much, you can always dip a papertowel in a little water and wipe more away. You can even wipe it all away and start over! Link to comment Share on other sites More sharing options...
