BiggTim Posted September 10, 2019 Share Posted September 10, 2019 This is very cool, Bruce! Nice to see something so different. Link to comment Share on other sites More sharing options...
alaninaustria Posted September 10, 2019 Share Posted September 10, 2019 Amazing work so far - nice to see such a different subject!! Cheers Alan Link to comment Share on other sites More sharing options...
ringleheim Posted September 11, 2019 Share Posted September 11, 2019 I'm enjoying the build. Looks very clean and precise. Link to comment Share on other sites More sharing options...
Bruce_Crosby Posted September 11, 2019 Author Share Posted September 11, 2019 The story so far: I got some primer and then a home brew pale blue on the 262 flying bomb and that was that. Progress: Ailerons for the He-162 were delivered in RLM82 top and bottom to the assembly plants. Paint is Mission Models throughout. Untitled by Bruce Crosby, on Flickr I started with a modified 8-162 scheme promulgated in February 1945, my time frame for the model is a whole year later, 1946. Untitled by Bruce Crosby, on Flickr It's a combination of plain RLM82 Hellgrun on the port wing, the fuselage too. The starboard wing and engine casing get RLM81 Braunviolet. This scheme is often reversed in books and colour plates. I added mottling, making it up as I go along and as it's a fictitious 1946, who can tell me its wrong? Untitled by Bruce Crosby, on Flickr Back to the 262: I went for the official colour scheme on this one, it's meant to be an old (by 1946 standards) airframe. So its late real war colours of RLM 81/82 just like the He-162. Here I've blocked in the Hellgrun ready to mask up for the Braunviolet. Untitled by Bruce Crosby, on Flickr And here's the masking: Untitled by Bruce Crosby, on Flickr Some considerable time later, I took the masking off the nose and some two day old paint had pulled up. My bad, I had used that useless white flexible tape from Tamiya. I had forgotten how lousy it is! Untitled by Bruce Crosby, on Flickr But here we are with some main cammo and some mottle, applied with different airbrushes but the same mix of paints. Main areas with the Badger Krome, the mottle with Gunze's PS-770, a super detailing airbrush. Untitled by Bruce Crosby, on Flickr And bang up to date, a view of the two fuselages mated together in glorious Technicolor! Untitled by Bruce Crosby, on Flickr Mustel by Bruce Crosby, on Flickr Hope you approve! Regards, Bruce Crosby patricksparks, Out2gtcha, Greg W and 5 others 8 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 11, 2019 Share Posted September 11, 2019 Most definitely approve! The colors and paint work look amazing. This is such a cool build! I have to say though I have 4 or 5 roles of various sizes of the flexible Tamiya tape and love it. I dont think I've ever had any issues with it, and I've used it without fail on my last 4 builds. I've use the flexible Tam tape for everything from canopies with Future on them, to bare MRP over resin, to MRP over primer, and early on I used it over MM enamel. Since I've found MRP I really haven't tried many other paints with it though. Is the nose its painted on resin? Link to comment Share on other sites More sharing options...
Bruce_Crosby Posted September 11, 2019 Author Share Posted September 11, 2019 38 minutes ago, Out2gtcha said: Is the nose its painted on resin? No, its standard Polystyrene, cleaned carefully. Primer has been on for a week, paint for a couple of days. The main fuselage was painted blue a few days ago but the greem and brown both went on today, masking a few minutes after spraying, normal tape and no lifting at all. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Bruce_Crosby Posted September 12, 2019 Author Share Posted September 12, 2019 (edited) Hi Guys, A busy day at the spray booth, trying to sort out the lifted paint on the Me-262 Flying Bomb part of the Mistel. Here's the damage on one side, about the same on the other side. Untitled by Bruce Crosby, on Flickr I masked up the fuselage already painted, laying up with Aizu Micron Masking Tape back filled with odds and ends from yesterday's session, then applied a mix of MMP's Grey Primer in thin layers, building it up with the judicious use of a hair dryer to harden each layer. Untitled by Bruce Crosby, on Flickr After some minor sanding and smoothing with Micro Mesh pads I applied the base colour of RLM76 again, smooth as a baby's posterior. Untitled by Bruce Crosby, on Flickr Then on with a scribble and mottle of MMP RLM 82, lightened with a touch of White. Untitled by Bruce Crosby, on Flickr Then a few squirts of RLM66 over the blue and green. Yes, it's not a "real" external colour but as this is a fictitious item that never flew and the war stopped in 1945 not 1946, I can more or less dictate my own conditions! Untitled by Bruce Crosby, on Flickr And the result of a few hours work. Untitled by Bruce Crosby, on Flickr Untitled by Bruce Crosby, on Flickr Untitled by Bruce Crosby, on Flickr Tomorrow I hope to mask and paint some panels on the port engine, specifically the rear end will be black, the intake ring might be bare metal and the panel behind it might get the same cammo as the nose. Then again, it might not. Could be Primer or plain old aluminium. Plus the markings might get cut on the Silhouette and sprayed, depends how the day goes. Hope somebody likes it. Regards, Bruce Crosby Edited September 12, 2019 by Bruce_Crosby LSP_Kevin, Out2gtcha, Fvdm and 9 others 12 Link to comment Share on other sites More sharing options...
Bruce_Crosby Posted September 13, 2019 Author Share Posted September 13, 2019 Today I spent a while changing some stuff on the mask design for the He-162 and the Me-262 in AutoCAD, then cut a new sheet on the Silhouette. here it is in the Silhouette program ready to cut. Untitled by Bruce Crosby, on Flickr Placing the masks. Untitled by Bruce Crosby, on Flickr Untitled by Bruce Crosby, on Flickr Untitled by Bruce Crosby, on Flickr Obviously it all went wrong and this is the second attempt on the starboard upper wing. Lots of repainting required, plus a lot of swearing and cursing. Untitled by Bruce Crosby, on Flickr But eventually it started to look better. Untitled by Bruce Crosby, on Flickr Then onto the underwing crosses in black and the stencil type swastikas on the rudder. Untitled by Bruce Crosby, on Flickr Untitled by Bruce Crosby, on Flickr Untitled by Bruce Crosby, on Flickr Tomorrow I'll be putting the stencils on the He-162. Regards, Bruce Crosby TorbenD, Out2gtcha, Kagemusha and 5 others 8 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 13, 2019 Share Posted September 13, 2019 Fantastic work, Bruce! I really must try to use my Silhouette Portrait some day. Kev Gazzas and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 13, 2019 Share Posted September 13, 2019 Woah that looks amazing! Link to comment Share on other sites More sharing options...
Neo Posted September 14, 2019 Share Posted September 14, 2019 Wow amazing work Link to comment Share on other sites More sharing options...
Fvdm Posted September 14, 2019 Share Posted September 14, 2019 Nice work with the stencils. Link to comment Share on other sites More sharing options...
Bruce_Crosby Posted September 14, 2019 Author Share Posted September 14, 2019 (edited) Back with today's work on the Mistel. First up this morning was to get masks and paint onto the He-162. Untitled by Bruce Crosby, on Flickr Untitled by Bruce Crosby, on Flickr Untitled by Bruce Crosby, on Flickr Some RLM04 yellow; Untitled by Bruce Crosby, on Flickr Then Back and White to get this: Untitled by Bruce Crosby, on Flickr Then this afternoon, after some talking with Klaus Herold, I mixed up some RLM02 and went over the plated over cockpit, oversprayed onto the cammo, not clean lines. This was after all, a last flight! Untitled by Bruce Crosby, on Flickr Here with the support struts for the He-162 and the access panel on the port Jumo in RLM02 as well. Untitled by Bruce Crosby, on Flickr And that's today's work over. May not look much but lots of masking and mixing, cleaning up, etc. I used the Gunze PS-770 a lot today, it produces a very tight spray pattern, great for close-in work. Regards, Bruce Crosby Edited September 14, 2019 by Bruce_Crosby Greg W, Fanes, LSP_Kevin and 2 others 5 Link to comment Share on other sites More sharing options...
misha71 Posted September 14, 2019 Share Posted September 14, 2019 great project Link to comment Share on other sites More sharing options...
Gazzas Posted September 14, 2019 Share Posted September 14, 2019 That's really some great results, Bruce! Link to comment Share on other sites More sharing options...
