docdodj 111 Posted July 7, 2019 Share Posted July 7, 2019 (edited) Having finished almost finished my revell P-51D, I decided to go for the Trumpeter Warhawk. Of course, the kit does have issues. After looking at the kit, 2 things strike me. One, the nose IS misshapen, already addressed is the side profile, with that huge bulge going front, but one thing no one seem to notice is that on top profile, the nose actually is wide. Second is the intake. Just. Ugh. Being a short tail, I needed to convert it to a long tail. So I got me a Grey Matter 1/32 Long Tail conversion, normally for the Hasegawa kit. I also got me the sprue for the exhaust panels from a 1/32 Hasegawa P-40E So I started by hacking off the exhaust panels, and grafted the hasegawa ones. Sanded the hell out of the nose. Literally paper thin. I placed in putty in the insides to strengthen up before I keep going. But I need your opinion guys. Here’s where I am now. Edited July 7, 2019 by LSP_Kevin Fixed image links KUROK, MikeMaben, Gazzas and 3 others 6 Link to post Share on other sites
D.B. Andrus 4,922 Posted July 7, 2019 Share Posted July 7, 2019 Looking pretty good from here. Cheers, D.B. MARU5137 1 Link to post Share on other sites
KUROK 658 Posted July 7, 2019 Share Posted July 7, 2019 MUCH better! Keep up the good work. MARU5137 1 Link to post Share on other sites
KUROK 658 Posted July 7, 2019 Share Posted July 7, 2019 Trumpeter also got the prop blades too thin. Grey Matter also has resin "paddle" blades that are the wider ones. I wonder if they are still available? MARU5137 1 Link to post Share on other sites
MARU5137 16,121 Posted July 7, 2019 Share Posted July 7, 2019 docdodj, EXCELLENT start. Following this one. Link to post Share on other sites
docdodj 111 Posted July 8, 2019 Author Share Posted July 8, 2019 Thanks guys! Anyways, sawed of the short tail, and test fitted the new long tail. Had to go at it carefully, but I think this is good enough. There’s still a small step, the resin tail being a little wider than the kit fuselage. corsairlada, Out2gtcha, Gazzas and 2 others 5 Link to post Share on other sites
docdodj 111 Posted July 8, 2019 Author Share Posted July 8, 2019 Here’s the fit up close. So it may mean that the trumpeter kit is a little too narrow, OR, the Hasegawa kit is a little too wide. Out2gtcha, Gazzas, LSP_Kevin and 1 other 4 Link to post Share on other sites
docdodj 111 Posted July 8, 2019 Author Share Posted July 8, 2019 At least tail looks centered and squared. :-) MikeMaben, Out2gtcha, LSP_Kevin and 1 other 4 Link to post Share on other sites
corsairlada 133 Posted July 8, 2019 Share Posted July 8, 2019 (edited) 4 hours ago, docdodj said: At least tail looks centered and squared. :-) what to try and the long tail of Hasegawa / Eduard p-40n ???? just such an idea I want to go this way, but there is no time yet Edited July 8, 2019 by corsairlada KUROK, MARU5137, LSP_Kevin and 1 other 3 1 Link to post Share on other sites
waroff 558 Posted July 8, 2019 Share Posted July 8, 2019 If you put the fishtail exhausts, the exhaust panel has not the gutter behind the last pipe, the panel is flat. Link to post Share on other sites
MARU5137 16,121 Posted July 8, 2019 Share Posted July 8, 2019 19 hours ago, docdodj said: At least tail looks centered and squared. :-) NEAT job.. Link to post Share on other sites
docdodj 111 Posted July 10, 2019 Author Share Posted July 10, 2019 A quick profile shot. Scribing up next! LSP_Kevin, Out2gtcha and Gazzas 3 Link to post Share on other sites
docdodj 111 Posted July 12, 2019 Author Share Posted July 12, 2019 Scribing done. Compared to an actual image. Out2gtcha 1 Link to post Share on other sites
docdodj 111 Posted July 12, 2019 Author Share Posted July 12, 2019 I removed the locating tabs for the for the cockpit so I can just drop it in from below. I also glued on the tail. Next step: sanding and fixing the joint. corsairlada, Out2gtcha and LSP_Kevin 3 Link to post Share on other sites
docdodj 111 Posted July 22, 2019 Author Share Posted July 22, 2019 After grafting the new tail, and rescribing the panel lines, I need to add to the length of the horizontal tail planes, as the trumpeter ones are shorter, since the resin tail was designed for the Hasegawa kit. So using plastic sheets I added the necessary length: checked if it matches the edges of the empennage: Filled in with epoxy putty, sanding, and viola! KiwiZac, daveculp, alain11 and 2 others 5 Link to post Share on other sites
