John1
How to replicate heavily faded NMF?
Title says it all.    I'm building a Korean War F-51D and these aircraft had the crap kicked out them.   Here's an example of what I'm trying to replicate:
What are your suggestions for something like this?  Keep in mind, if it's a flat aluminum paint, will I be able to gloss it for decals and then overcoat to restore it's dull finish?
I would try adding Tamiya Clear Blue to whatever version of Aluminum paint you are going to try and use. HTH
   Mike Horina
Looks to me like a very pale grey paint with a touch of aluminium added would be good for this. The clear blue is a good idea.
If you are foiling, some egg shells in with some pre-grained foil in water (shiny side down of course), for just a few minutes then a quick blast of flat or semi-flat. Works like a charm.
12 hours ago, Neo said:
Correct me if im wrong but that plane looks like its painted gray and bot nmf
I could be wrong too, but it actually does appear to be NMF, just heavily dulled by time and weather. You can see areas where the stars and bars/codes have been scratched off, and the same gray looking surface is perfectly represented under them, with no change in color or wearing of the gray color.
I've used Gunze Surfacer 1200 and added various shades of their metallic paints
for contrast for this (not LS of course but 1/48):
Touched up a few areas with Alclad. Worked for me.
Lothar
Just paint it flat aluminum.  Make a slurry of brown mixed with yellow and thinned heavily, and mist over the whole plane. Then, like suggested above, go back with a brush and add brown, tan, and rust washes to parts of the aircraft.
I've been playing with Indian Ink it's water based a bit like concentrate wash you thin to what you want.
Bob
