LSP_K2 Posted July 16, 2019 Author Share Posted July 16, 2019 On 7/8/2019 at 4:41 PM, MARU5137 said: Are you still on with this Kevin... Yep, still plugging away, Maru, though not too much in the last couple of weeks. To that end, I was preparing to order the relevant paints for the air-frame tomorrow, but decided to check my "inventory" first. Good thing I did too, as this entire bag is nothing but Luftwaffe colors; mostly Model Master, but also some old Floquil; and Aeromaster paints as well, so I'm covered now. Gazzas 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 16, 2019 Author Share Posted July 16, 2019 In an effort to see if I could close up the fuselage before adding the IP, I taped the fuselage halves together to check. IP will most definitely not be able to be added "after the fact", so I've moved on to the IP itself. I'm hoping to have the fuselage all zipped up in a week or so, but I guess we'll see about that. Biggles87, R Palimaka, LSP_Kevin and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 16, 2019 Author Share Posted July 16, 2019 Here the IP has now had some paint slopped on and is awaiting clear coat and Airscale decals. Admittedly not the best bit of painting, but I think I can live with it. LSP_Kevin, Alain Gadbois, R Palimaka and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 17, 2019 Author Share Posted July 17, 2019 I figured this was a good time to check the rear cowl fit, and sure enough there are some serious fit issues. Here the gun tray is set temporarily in place. A little grinding here and there of the cowl interior and guns, makes for an almost perfect fit. MikeMaben, LSP_Kevin, D.B. Andrus and 3 others 6 Link to comment Share on other sites More sharing options...
alain11 Posted July 17, 2019 Share Posted July 17, 2019 (edited) hi it's a very nice kit , I will follow this thread with interest , , I did mine with the same paint scheme a while ago , it would be funny to see how yours will turn at the end ...happy modelling !!!! Alain Edited July 17, 2019 by alain11 LSP_K2 1 Link to comment Share on other sites More sharing options...
The Dude Posted July 17, 2019 Share Posted July 17, 2019 Looking good! Make sure you glue the engine in the fuselage before you glue in the gun cover, otherwise it will be a PITA to get the engine mounts into the firewall. LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 17, 2019 Author Share Posted July 17, 2019 16 hours ago, alain11 said: hi it's a very nice kit , I will follow this thread with interest , , I did mine with the same paint scheme a while ago , it would be funny to see how yours will turn at the end ...happy modelling !!!! Alain Do you have a link to your completed model? I'd really like to see it. 15 hours ago, The Dude said: Looking good! Make sure you glue the engine in the fuselage before you glue in the gun cover, otherwise it will be a PITA to get the engine mounts into the firewall. Oh yes, I'm aware. Fitting the four bearer contacts, will absolutely be done before I add that real cowling piece, as it would be near impossible otherwise. Thanks for the reminder though, I appreciate it. Gazzas 1 Link to comment Share on other sites More sharing options...
alain11 Posted July 19, 2019 Share Posted July 19, 2019 hi Kevin here is my 109 ( from Eduard )..note the Fieseler supercharger intake on this plane Alain LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 21, 2019 Author Share Posted July 21, 2019 New Airscale instruments for this effort (1:48 scale). Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 21, 2019 Author Share Posted July 21, 2019 A somewhat darkish wash of RLM 02 now added to the interior components. After adding instruments to the IP, I'll be ready to zip up the fuselage. nmayhew, Alain Gadbois, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 22, 2019 Author Share Posted July 22, 2019 The box stock seat with P.E. belts is terrible, at least as far as I'm concerned, so I received a replacement seat today. Perhaps not technically 100% correct, but it's perfectly OK with me, and will dress up the 'pit rather nicely, I think. Martinnfb and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
G-Man Posted July 23, 2019 Share Posted July 23, 2019 Can this be built without the engine? I have 2 in my stash. Martinnfb 1 Link to comment Share on other sites More sharing options...
1to1scale Posted July 23, 2019 Share Posted July 23, 2019 On 6/20/2019 at 4:12 PM, LSP_K2 said: I've already made some preliminary work, but not all that much so far. This will be a mostly OOB effort, hopefully to be completed before a local show here in September. Necessity forced me to order replacement wheel well inserts, as those in the kit were warped and very, very brittle. Here are the replacements, already installed. I had the same issue with my inserts, where did you find new ones? Martinnfb 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 23, 2019 Author Share Posted July 23, 2019 54 minutes ago, G-Man said: Can this be built without the engine? I have 2 in my stash. I suppose it could, but never really checked. 12 minutes ago, 1to1scale said: I had the same issue with my inserts, where did you find new ones? I ordered them from Dragon USA. Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 26, 2019 Author Share Posted July 26, 2019 Replacement seat, now with pouring block ground off and cleaned for a primer coat, sits a bit high, but I think I can live with it. LSP_Kevin, Gazzas and Martinnfb 3 Link to comment Share on other sites More sharing options...
