ericg
RAAF Bristol Bulldog
This one  shows it better as it's controlled from the ground /cameras.
Watch "GIANT HALF SCALE RC BRISTOL BULLDOG - 425 cc AT LMA RAF ELVINGTON MODEL AIRCRAFT SHOW - 2014" on YouTube
Cheers for the comments guys.
On 6/30/2019 at 1:05 PM, ScanmanDan said:
Excellent advice on building resin kits.  Pin everything :)
I bet that drilling that engine centre was a stressful moment.  Is that an x/y table you mounted the vice to?
Thank you for sharing your hard won experience with resin kits in such a clear manner.
Dan, yes, it is a compound table. Each wheel that adjusts X/Y axis movement is the size of a 50c piece and one revolution equals 1mm. It is an essential part of the drill press.
Some more work.
I made up some spark plug leads and attachments from .3mm lead wire and plastic rod.
these were then attached to the spark plugs and ran down each side of the intake tubes. Only the top half of each cylinder will be visible.
I fitted brass rod for pushrods on each cylinder. There are 4 per cylinder.
I just love watching you work your magic Eric - it's my kind of modelling, take what you are given and use it as a canvas for making a miniature where most of the fun is in researching and recreating what you find
excellent stuff
Peter
excellent stuff
Peter
Very well put Peter. :)
