AnthonyWan Posted June 11, 2019 Share Posted June 11, 2019 Title says it all. Anyone done resin wheels in replacement of the kit's rubber? Reason for asking...seems like most wheels include wheel and hub cast together, kit's setup has you screwing hub and then fitting tire. Curious what creative solutions y'all have seen or done. Thanks! Link to comment Share on other sites More sharing options...
timvkampen Posted June 11, 2019 Share Posted June 11, 2019 GT Resin Link to comment Share on other sites More sharing options...
Luca Posted June 11, 2019 Share Posted June 11, 2019 GT Resin (A/B/C/D/E) RES-IM (A/B/C/D) NorthStar (E) Link to comment Share on other sites More sharing options...
AnthonyWan Posted June 11, 2019 Author Share Posted June 11, 2019 5 hours ago, Luca said: GT Resin (A/B/C/D/E) RES-IM (A/B/C/D) NorthStar (E) I have the Northstar set. The hubs, tires are molded as one - I was looking for a solution to attaching them to the kit's metal gear since the kit parts require a screw. Link to comment Share on other sites More sharing options...
AnthonyWan Posted June 11, 2019 Author Share Posted June 11, 2019 7 hours ago, timvkampen said: GT Resin Have you used these before? I'm curious how your experience was. Looking at the photos - it looks like the hub is separate to make installation more like the kit parts. Link to comment Share on other sites More sharing options...
timvkampen Posted June 11, 2019 Share Posted June 11, 2019 3 hours ago, AnthonyWan said: Have you used these before? I'm curious how your experience was. Looking at the photos - it looks like the hub is separate to make installation more like the kit parts. no, also pondering whether to get them actually... Link to comment Share on other sites More sharing options...
MOJO Posted June 11, 2019 Share Posted June 11, 2019 you can also try http://partsrparts.homestead.com/F15parts.html. They have 1/32 f-15 parts, including wheels. Link to comment Share on other sites More sharing options...
GusM Posted June 11, 2019 Share Posted June 11, 2019 Used the GT Resin wheels and they fit very easily and look great. Would heartily recommend. Link to comment Share on other sites More sharing options...
EricF Posted June 12, 2019 Share Posted June 12, 2019 The RES-IM kit in pictures for the F-15 ABCD Link to comment Share on other sites More sharing options...
ghatherly Posted June 12, 2019 Share Posted June 12, 2019 (edited) Her is the results of my research a few years back: Parts R us wheels are resin copies of the Revell F-15 kit wheel. The are to small in diameter and to narrow. RES-IM wheels are for a C/D. A/B wheels are different. Tires markings are to large and not accurate for the actual tires used. NorthStar F-15E wheel are much to large in profile and diameter and the wheel lightening holes are the wrong size. F-15 E's use two styles of wheels, one with small and one will large holes. GT Resin wheels are made from CAD drawings based on input from the manufacturers drawings and the actual wheels and tires. Both Michelin "Aviator" tires and Goodyear tires are available. Wheels, brakes, and tires are separate for ease of assembly and painting. You can also drill a hole in the brake drum and id a screw to attached them to the main gear just like the kit gear. They are a little more expensive, but the look is worth it even is I am a little biased. Chuck Sawyer used the GT Resin set on his F-15C build a year or so back. Several others have used them on their builds. the oval holes I the Wheels are designed to be easily removed so you get the realistic look of the brake drum behind it. Pics are courtesy of Chuck Sawyer form his build thread. Hope this helps. Edited June 12, 2019 by ghatherly AnthonyWan, Darren Howie, Kagemusha and 4 others 7 Link to comment Share on other sites More sharing options...
timvkampen Posted June 13, 2019 Share Posted June 13, 2019 16 hours ago, ghatherly said: Her is the results of my research a few years back: Parts R us wheels are resin copies of the Revell F-15 kit wheel. The are to small in diameter and to narrow. RES-IM wheels are for a C/D. A/B wheels are different. Tires markings are to large and not accurate for the actual tires used. NorthStar F-15E wheel are much to large in profile and diameter and the wheel lightening holes are the wrong size. F-15 E's use two styles of wheels, one with small and one will large holes. GT Resin wheels are made from CAD drawings based on input from the manufacturers drawings and the actual wheels and tires. Both Michelin "Aviator" tires and Goodyear tires are available. Wheels, brakes, and tires are separate for ease of assembly and painting. You can also drill a hole in the brake drum and id a screw to attached them to the main gear just like the kit gear. They are a little more expensive, but the look is worth it even is I am a little biased. Chuck Sawyer used the GT Resin set on his F-15C build a year or so back. Several others have used them on their builds. the oval holes I the Wheels are designed to be easily removed so you get the realistic look of the brake drum behind it. Pics are courtesy of Chuck Sawyer form his build thread. Hope this helps. Hi Gary, thanks. One question: how does one find out whether a particular Eagle flew with Michelin or Goodyear? For instance the Soesterberg AB, NL F-15s (C/D models and A/B were flown there). Same for Bitburg, germany. Link to comment Share on other sites More sharing options...
ghatherly Posted June 13, 2019 Share Posted June 13, 2019 Look at pictures of the airframe you are modeling. In reality both are used... they get replaced often, so your choice. Link to comment Share on other sites More sharing options...
