Fencer-1 Posted June 18, 2019 Share Posted June 18, 2019 brahman104, Gazzas and Starfighter 3 Link to comment Share on other sites More sharing options...
brahman104 Posted June 18, 2019 Author Share Posted June 18, 2019 36 minutes ago, Fencer-1 said: Initially I intend to make true scale dimension 3D nose section till 3E station, because there is cylindrical section with the radius of 45" follow behind 3D station. Then I will scale up whole thing to match HK model fuselage diameter. Will see the result. Looking great! I'm still placing the cockpit section but your work is looking promising! Are you planning on printing a trail soon? Craig Gazzas, kkarlsen and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
brahman104 Posted June 18, 2019 Author Share Posted June 18, 2019 I've been playing around with the turtle deck contours. I need this to work properly so it blends into the existing fuselage. As you can see, once again there's differences in profile between HK and the drawing.... HK is in green here... Is it going to be that much of an issue? In the grand scheme of things probably not, but it is hard to nail down the exact fuselage reference lines when working between Boeing's drawings, my drawings and the kit. I think the profile of the Boeing drawing is sharper here and probably going to be easier to reference back to for window/windscreen placement, and it looks sharper overall, so I think I'll stick to that one Craig sandokan and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
Fencer-1 Posted June 18, 2019 Share Posted June 18, 2019 8 hours ago, brahman104 said: Are you planning on printing a trail soon? Yes, definitely. I will check how can the new nose be blended with HK fuselage. Link to comment Share on other sites More sharing options...
Fencer-1 Posted June 18, 2019 Share Posted June 18, 2019 Starfighter and sandokan 1 1 Link to comment Share on other sites More sharing options...
Fencer-1 Posted June 18, 2019 Share Posted June 18, 2019 There is some research I made. One tip in the beginning. Nowdays model producers making assembly guides just using 3D rendering for them. The side, top and bottom views are not an exeption. They are also direct renders from model 3D in the most of cases. So, to compare the model in general against some drawings you can just scan these projections and combine them with drawings using bunch of suitable graphic editors. So I did it. Red lines are from my 3D based on factory drawings. 1. The true size nose against model side view. Length matched here. Model is obviously too beefy. 2. The same, but true profile was moved up to match pilots enclosure. 3. True profile proportionally increased to match the height. There is some exessive length, but clear nose cutout has almost proper height for the model. 4. The true profile is not so true here, because it squeezed in length to match the model one. Besides the fact that HK B-17 is "fat boy" there is big field for thought how to deal with such inaccuracy. sandokan and Out2gtcha 1 1 Link to comment Share on other sites More sharing options...
TKB Posted June 24, 2019 Share Posted June 24, 2019 Craig, I first became aware of the B-17 when I was 9 years old. For the following 59 years that I have spent "absorbing" B-17 details, I was convinced I had to be in the top ten of "most B-17 obsessed persons." Between your work on the C and now this in depth research into "4 forward" ---- well, all I can say is my B-17 obsession pales to your obsession and dedication to "getting things right!" It's one thing to figure out what a problem is, but it's a whole new ballgame coming up with the fix, especially when you want to meld that fix into remaining kit componets! My hat is always off to both your research work and modeling work! As I've said many times, your tenacity is amazing and coupled with your skills, you are not only a talented modeler, but one talented person!! Terry brahman104 and Out2gtcha 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted June 24, 2019 Share Posted June 24, 2019 Does it look too fat because it is actually too short...? D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Juggernut Posted June 24, 2019 Share Posted June 24, 2019 I don't think so. I think it looks too fat because it's too fat...at least in the aft fuselage sections. Fencer-1 1 Link to comment Share on other sites More sharing options...
brahman104 Posted June 25, 2019 Author Share Posted June 25, 2019 7 hours ago, thierry laurent said: Does it look too fat because it is actually too short...? One could certainly feel that way when you look at the overall picture Thierry. One of the main reasons I decided to show my research here as a prelude to the build beginning, is to share the discoveries I have made everywhere, not just in the forward section. This certainly isn't a definitive "everything wrong with the HK kit," but it might help other understand and appreciate the subtle shape differences that make the B-17 what we all know and love! 5 hours ago, Juggernut said: I don't think so. I think it looks too fat because it's too fat...at least in the aft fuselage sections. Agreed mate! Haven't even begun looking at the back end yet, but as Kent has already shown, she's chubby all round...... 22 hours ago, TKB said: Craig, I first became aware of the B-17 when I was 9 years old. For the following 59 years that I have spent "absorbing" B-17 details, I was convinced I had to be in the top ten of "most B-17 obsessed persons." Between your work on the C and now this in depth research into "4 forward" ---- well, all I can say is my B-17 obsession pales to your obsession and dedication to "getting things right!" It's one thing to figure out what a problem is, but it's a whole new ballgame coming up with the fix, especially when you want to meld that fix into remaining kit componets! My hat is always off to both your research work and modeling work! As I've said many times, your tenacity is amazing and coupled with your skills, you are not only a talented modeler, but one talented person!! Terry Hahaha, I think many of us could feel we own that title, but yes, the B-17 is definitely my #1 favourite....... In fact, the main reason I got my scuba diving ticket was in the hope that one day I might dive on Blackjack, which will incidentally be the subject of my F model when I come to build it. Just one more box to tick in an ever expanding list! Craig Gazzas 1 Link to comment Share on other sites More sharing options...
Fencer-1 Posted July 5, 2019 Share Posted July 5, 2019 (edited) Almost perfect hi-res B-17 side view on Flickr from David Whitworth Edited July 5, 2019 by Fencer-1 Victor K2, D.B. Andrus and Gazzas 2 1 Link to comment Share on other sites More sharing options...
brahman104 Posted July 9, 2019 Author Share Posted July 9, 2019 Thanks Fencer! A good shot indeed. I head to Seattle tomorrow so I’m looking forward to seeing “Boeing Bee” in the flesh very soon! Craig Link to comment Share on other sites More sharing options...
brahman104 Posted July 13, 2019 Author Share Posted July 13, 2019 And here she is! I last visited MOF in Seattle when I was 9, and bitterly disappointed that I had come all the way to the US to see a B-17 and it was not on display but being restored! Luckily, 27 years later I could finally see her in all her glory! I won’t get to Dayton while I’m here, so at least I can put some F model photos up for reference..... I’m only putting up photos which specifically show the nose shape, as we all know what the back end of a B-17 looks like! And a very happy visitor! Cheers, Craig LSP_Kevin, Victor K2, Gazzas and 1 other 4 Link to comment Share on other sites More sharing options...
Neo Posted July 13, 2019 Share Posted July 13, 2019 Wow super nice pictures Link to comment Share on other sites More sharing options...
misha71 Posted July 13, 2019 Share Posted July 13, 2019 what a beauty. i wish i am there Link to comment Share on other sites More sharing options...
