Jerry Crandall Posted May 31, 2019 Share Posted May 31, 2019 Reimund, thanks for posting the images of the new Sturmbock kit I'm excited someone is releasing it in 1/32 scale. I do see a few problems right off. For some reason they have an oval panel on the port side of the fuselage just behind the cooling flaps. It does not belong there. You are right about the colors. Undersurfaces RLM 76, Upper RLLM 75 and RLM 74 is correct. I don't see the armored windscreen triangular quarter panel it is not on the art work anyway. Most Sturmbock a/c had them. There is confusion about "Yellow 3". The A-8/R2 as shown is W.Nr. 680718 was never at Barth in May, 1944. It was built on 19 June ,1944 and Fw. Ottfried Baisch was killed in it on 18 July ,1844. There is only one known photo of it and the tactical number is not known and the unit emblem cannot be seen in the photo. Baisch's earlier Sturmbock was "Yellow 3" W.Nr. unknown and was mounted with the Krebs-Gerät rocket but it was not a A-8/R2, it was a standard A-8 with Sturmbock equipment(R7). It did have the unit badge on the Panzerplatten not on the engine cowling. Cheers, Jerry AlanG, Out2gtcha, David66 and 7 others 6 4 Link to comment Share on other sites More sharing options...
Jerry Crandall Posted May 31, 2019 Share Posted May 31, 2019 Oops, Baisch was not killed in 1844! But 1944. LSP_K2, Out2gtcha, AlanG and 3 others 4 2 Link to comment Share on other sites More sharing options...
nmayhew Posted May 31, 2019 Author Share Posted May 31, 2019 Thanks to you both for the pictures and subsequent info - much appreciated! alanash1963 1 Link to comment Share on other sites More sharing options...
HB252 Posted June 1, 2019 Share Posted June 1, 2019 Hello Isar, Thanks for sharing the photos My FW 190 is on way (I paint it whit Willy Moritz scheme) One question: In the sprues I do not see the pieces of the little bulges in undersurface MK´s 108 that is show in REVELL PHOTOS Can you show us the instruction sheet or say us If you see the pieces? Regards, Miguel nmayhew 1 Link to comment Share on other sites More sharing options...
Isar 30/07 Posted June 1, 2019 Share Posted June 1, 2019 Miguel, here are two pics (instruction sheet shows nothing helpful during construction process): http:// and after giving a quick shading http:// As you can see Revell took as with the former Fw 190 A-8/R11 the wing from the F-8 and inserted the specific parts for the R2. This creates some imperfections around this new part but a little sanding helps. I don´t know if the line around the ejector is correct - but sanding flat is no Major task. HTH Reimund rafju, Gazzas and alanash1963 2 1 Link to comment Share on other sites More sharing options...
Isar 30/07 Posted June 1, 2019 Share Posted June 1, 2019 Brian and Jerry, thanks for sharing your finished model and explanations! Reimund Link to comment Share on other sites More sharing options...
HB252 Posted June 2, 2019 Share Posted June 2, 2019 Thank Reimund for the photos What scheme will carry your FW 190? I think you must done big holes in the wings for the MK 108 barrels Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 2, 2019 Share Posted June 2, 2019 Indeed, Eagle Parts Mk 108 canon fairings, EagleParts cockpit, EagleParts Boss, EagleParts Prop and EagleParts Tail-wheel were all essentials for my build. Not sure how many AM parts, if any would be necessary on the Revell kit. Link to comment Share on other sites More sharing options...
AlanG Posted June 2, 2019 Share Posted June 2, 2019 And a mighty fine build it was too Brain. I have the thread saved in my faves so i can refer back for info/details for when i start my build alanash1963 1 Link to comment Share on other sites More sharing options...
Darren Howie Posted June 3, 2019 Share Posted June 3, 2019 On 5/31/2019 at 11:47 AM, thunderbolt1988 said: Was the Fw 190A-5/U12 ever modified to have the protective Sturmbock armor in addition to its lovely gun packs? The German innovations made in response to their desperate war situation fascinate me. I mean' look at those guns. It's as if they really wanted to shoot bombers down or something. . . No the U12 was never added to a Ramjager. The Ramjager/Sturmbock was already incredibly heavy with the armour making it vulnerable to roving allied fighters. Link to comment Share on other sites More sharing options...
Isar 30/07 Posted June 3, 2019 Share Posted June 3, 2019 20 hours ago, HB252 said: What scheme will carry your FW 190? I don´t know yet as there are some decal options out there and Eagle Strike has announced another sheet. I did this one some 15 years ago using Hasegawa and parts made scratch. http:// http:// http:// Reimund Gazzas, D.B. Andrus, David66 and 5 others 8 Link to comment Share on other sites More sharing options...
Thunderbolt Posted June 4, 2019 Share Posted June 4, 2019 On 6/3/2019 at 1:11 AM, Isar 30/07 said: I don´t know yet as there are some decal options out there and Eagle Strike has announced another sheet. I did this one some 15 years ago using Hasegawa and parts made scratch. Reimund Reimund wonderful build Link to comment Share on other sites More sharing options...
DeanKB Posted June 4, 2019 Share Posted June 4, 2019 On 6/2/2019 at 6:44 PM, Out2gtcha said: Indeed, Eagle Parts Mk 108 canon fairings, EagleParts cockpit, EagleParts Boss, EagleParts Prop and EagleParts Tail-wheel were all essentials for my build. Not sure how many AM parts, if any would be necessary on the Revell kit. You could possibly whip up a passable 190 just from the bits left over from the original kit. Link to comment Share on other sites More sharing options...
Isar 30/07 Posted June 5, 2019 Share Posted June 5, 2019 7 hours ago, thunderbolt1988 said: wonderful build Thank you - great start in this day! Reimund Link to comment Share on other sites More sharing options...
Thunderbolt Posted June 5, 2019 Share Posted June 5, 2019 9 hours ago, Isar 30/07 said: Thank you - great start in this day! Reimund Right, for 2004, it’s epic Link to comment Share on other sites More sharing options...
