Grizly Posted May 7, 2019 Share Posted May 7, 2019 The subject I am modelling with my Tamiya P-51D carried underwing 5 inch rockets and there lies my problem - where to find the zero length rails. I purchased the Isradecal rails but, unfortunately, they are of a different pattern from those normally installed on the Mustang (see below for the required type). Anybody out there have a suggestion as to where I might find six sets of rails (don't need the rockets)? Out2gtcha 1 Link to comment Share on other sites More sharing options...
Kagemusha Posted May 8, 2019 Share Posted May 8, 2019 Here Out2gtcha, R Palimaka and LSP_K2 3 Link to comment Share on other sites More sharing options...
Grizly Posted May 8, 2019 Author Share Posted May 8, 2019 Kagemusha, Many thanx. An order on the way. Link to comment Share on other sites More sharing options...
John1 Posted May 8, 2019 Share Posted May 8, 2019 You can also order the applicable sprues for the Tamiya F4U-1D kit. Those are probably the best looking HVAR’s out there. On that that drawing above, which Mustang version carried 10 HVAR’s? Link to comment Share on other sites More sharing options...
Grizly Posted May 8, 2019 Author Share Posted May 8, 2019 While I can't give an example of a Mustang loaded out with 10 HVARs, my particular interest is an RCAF 402 Squadron aircraft which had six mounts. R Palimaka 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted May 8, 2019 Share Posted May 8, 2019 While it was not common, it was an option. Here is an RCAF 417 Squadron Mustang sporting 10 launchers. LSP_K2 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted May 8, 2019 Share Posted May 8, 2019 (edited) 28 minutes ago, Grizly said: While I can't give an example of a Mustang loaded out with 10 HVARs, my particular interest is an RCAF 402 Squadron aircraft which had six mounts. While we're on the subject of later Mustangs (sort of...), note that on your 402 Squadron Mustang that the usual tail light on the trailing edge of the rudder is gone, replaced by a small light on either side of the vertical stab, just behind the "3" in the serial number. Edited May 8, 2019 by R Palimaka Link to comment Share on other sites More sharing options...
Grizly Posted May 8, 2019 Author Share Posted May 8, 2019 Once again, I learned something new. Thanx Richard. As an aside, it is not my intention to model aircraft 273 pictured above which has the vented panel aft of the wing. Instead, I'll pick an aircraft that didn't have the vents such as 297. R Palimaka 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted May 9, 2019 Share Posted May 9, 2019 Good plan. I'm not sure I could make myself slice into the Tamiya plastic to make the vents either. Link to comment Share on other sites More sharing options...
