Lothar Posted May 14, 2019 Share Posted May 14, 2019 Looking fantastic, you'll be rewarded with a superb model when finished. Your hard work will pay off Lothar Gazzas 1 Link to comment Share on other sites More sharing options...
Gazzas Posted May 16, 2019 Author Share Posted May 16, 2019 Now to an area that nobody seems to be talking about: The wing edges. (the following two images for discussion only) In researching I found two types: One on this Fokker D.VII where rib tapes are used: For this to be an option, your upper and lower rib tapes need to meet up perfectly both front and back. Then there is this Pfalz D.XII: Here, wing material in a strip more broad than the rib tapes is used. Since my rib tapes don't line up perfectly, and because I'm building a pfalz... I chose this method. I took this steep angle shot and discovered a step in my wraparound. I think it's gonna be there for posterity. The Lower wing. Ugh... macro shots show just how un-straight my rib tapes are. This small area hasn't been done yet. I took the picture to illustrate the fragility of the decals that don't wrap around the wing edge. Dirtied up the wheels with a couple of washes. Thanks for looking! Gaz MikeMaben, sandokan, wmoran and 6 others 9 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 16, 2019 Share Posted May 16, 2019 The learning curve on lozenge decals is actually a bit steep. I think it looks good from what I can see! Gazzas 1 Link to comment Share on other sites More sharing options...
Gazzas Posted May 19, 2019 Author Share Posted May 19, 2019 HI Everyone, I started the rigging today. My main goal was to get as much done as possible before putting the struts and upper wing on. I used Bob's Buckles, but they're very hard to see since my phone doesn't like to take close up photos. For the wires I'm using 1.5Lb test. I blackened the 'wires' with a Sharpie before attaching them to the model. I use a lot of light, and a light colored background to improve my ability to see through the eyelets once the upper wing is on. And I used a box to elevate the jig and inter-wing area to eye-level. But back to work tomorrow... so I probably won't get it all rigged before the end of the week. Cheers! Gaz sandokan, elanlane13, Lothar and 3 others 6 Link to comment Share on other sites More sharing options...
Gazzas Posted May 23, 2019 Author Share Posted May 23, 2019 Hi everyone! I finished this one today after devoting many of my free hours that would normally be spent web surfing and watching TV. It was an educational build, and I had a good time, even the rigging which I made four separate efforts to ruin while I was heat shrinking the lines. You can see the RFI here: Cheers! Gaz Greg W, LSP_Kevin and Kagemusha 3 Link to comment Share on other sites More sharing options...
