baffozac
IMAM Ro43 1/32 scratch-built
Masking to make fabric thicknesses. I used 7 mm tape spaced by 1 mm. I used the same narrow tape for  the four faces.
A template helps tu cut the tips form.
Black plastic card is a tester of thickness: I put a first layer of Surfacer 1500 diluted with AK extreme thinner on the wings and on the black card.
When it's dry, I pull the number 1 tape and check the thickness. If this is not enough, secon layer and so on.
So I don’t have to take the tape off the wings.
Three layers were required and a sanding with 2000 paper.
1 mm steel rods glued with Araldite. Still to cover the central part with plastic card.
Have a nice weekend !
4 hours ago, baffozac said:
Hello Clark, for the 38 louvers on the front of the plane, the merit is due to a marking gauge I made with a balsa stripper.
Here the link, sorry, in french:
http://www.master194.com/forum/viewtopic.php?f=4&t=103658&start=75
I just looked at how you did that - not only is it genius, but it is so well executed I don't actually believe what I am seeing :)
the result is PERFECT
quite incredible and a joy to watch :popcorn:
Peter
Hi Peter, the same process for this:
The two handles (black arrows) on the trailing edge of the upper wing made with a master (red arrow) used to thermoform these parts (blue arrow).
The hinges and bracket of the rudder are glued.
After a couple of days (putty, sanding, primer) the join is smooth. Anti-skid strips added.
Hinges for the flap allowing the folding of the wing and lot of drains have to be moulded using Milliput footprints and melted plactic.
