sandbagger
Fokker pair 2
Hi all,
Rigging has started now.
Difficult to make out some of the rigging as I had to tie back the flight control lines as they were getting in the way.
So far:
Double bracing across the top of the fuel tank.
Double bracing across the underside of the cockpit floor (2 sets).
Double bracing across the frame bays adjacent to the pilot's seat.
Double bracing across the rear of the pilot's seat support frame.
Double bracing across each vertical fuselage frame.
Done with 0.08 mm Mono-filament, 0.4 mm Nickel-Silver tube and 1:48th scale turnbuckles ('Gaspatch').
The same needs to done on each of the frame bays on each side of the fuselage as well as those under and on top of the fuselage.
Mike
Haven't heard the 'KooKoo' expression since the TV series '77 Sunset Strip' - the character 'Kookie' (Ed Byrnes) - that was his saying - 'KooKoo daddo' :D
Edited by sandbagger
Yep, Kookie Kookie lend me your comb .
He was a pretty hep cat   :speak_cool:
*snaps*........*snaps*..........*snaps*........
*snaps*..........*snaps*........*snaps*..........
:lol:
Hi all,
The fuselage bottom cross bracing is done, which completes the fuselage bracing.
Also the tail skis has been fitted, with 0.125 mm copper wire suspension springs and 0.2 mm lead wire retention cable.
Now it's onto making the cockpit surround padding and fit the two modified 'Gaspatch' machine guns with their synchronization cables,
Mike
Hi all,
I realized that the fuselage rear decking panel was incorrect.
I made it such that the front edge butted up against the rear of the pilot's seat support frame.
In fact the decking seems to have passed over the seat frame, forming the rear cockpit surround, then onto the top of the cockpit side frames.
After several tries and five broken bracing wires, I think it's just about there now.
Now onto making the padded rim to fit around the cockpit rear decking and after that, the machine guns,
Mike
Hi all,
Both machine guns are now fitted along with their synchronization flexible drives.
These drives are connected between the bottom of the gun breech blocks and the gun synchronization mechanism, fitted to the rear of the engine cam shaft,
Mike
