Sign in to follow this
Bruce_Crosby
Special Hobby V-1
This is Special Hobby's 1/32 scale V-1.  A lovely little kit, the usual lo-run moulding features, a bit of etch and a good decal sheet.  All paint by Mission Models with a final wash of Flory Black Weathering fluid.  Very fast and easy to build and paint.  The rear end of the fuselage and engine was assembled and painted in one factory, the explosive section in another and the nose guidance system at a third, all painted where manufactured. Like most munitions, they would only come together as a complete unit prior to launch, being assembled and adjusted in the local bomb dump.  Hence the mottle cammo on the back end, the linear colour demarcation on the explosive section and a freehand wavy colour separation on the nose.  Some areas were treated to a very thin wash of Mission Models Tyre Black to change the RLM83 and 76 on some sections to emphasise the disparate part manufacturing.
Edited by Bruce_Crosby
delete texts
Very nice, Bruce! Love the paint work. Did you have to thin the Mission Models paint much for the mottling? I have noticed its pretty thin right out of the bottle.
:clap2::clap2::clap2::goodjob::clap2::clap2::clap2:
Hi Ray,
It's the mix recommended by Mission Models with a base of 10 drops paint, 3 drops thinner and 2 drops of Poly, scaled up as required.  I've been using Mission's paint for 2 years now and absolutely rate it.  The Poly levels the paint, I never have any tip drying on the airbrush and you can spray that mix thru an Infinity 0.15 all day long.  I used the same mix on my recent Me 262 from Revell and its consistently good.
Regards,
Bruce Crosby
On 3/8/2019 at 9:28 AM, Bruce_Crosby said:
Hi Ray,
Regards,
Bruce Crosby
Thanks for the tip. Just to clarify, what is Poly? Not sure I have that.
Hi Ray,
MM does a bottle of Polyurethane Additive.  Most paint already has it in the mix but Mission Models has you add the amount you want.  It makes a real difference to the finish, it comes out really smooth but still flat.  Hardly ever get any tip drying. Just check out their web site, have a read of the mix instructions.  It soon becomes second nature.  None of that rubbish about adding Thinners until you get the consistency of milk.  Use the formula I suggested above, maybe add another drop of thinner if you’re using a real fine nozzle.  You end up with consistent, dependable, reuseable mixes.  They scale up in direct proportions.  Just don’t add Poly to their primers, just Thinners.
Also be aware the wet colour in the bottle won’t be what you get on the model.  As the paint dries, it changes shade as the poly levels it out and the carrier flashes off.  It’s partucularly noticeable on the late Luftwaffe colours. I usually mix and spray then go have a cup of coffee while the paint cures a bit.  You come back to a different, level, no runs colour. Plus it’s rock hard with the poly.
Regards,
Bruce Crosby
Fantastic V1!  I especially like the base.  The tracks left behind by the trolley wheels are a great touch.
Jeff
Hi Jeff,
That’s actually a standard Zoukei-Mura base, straight out of the packet!  Pre-painted, just open the packet and drop a model onto the base.  Easy!
Regards,
Bruce Crosby
