DonH Posted April 12, 2019 Share Posted April 12, 2019 Has anyone tried to use Artool FX templates to do a similar thing? Link to comment Share on other sites More sharing options...
KitmodellerNZ Posted April 12, 2019 Author Share Posted April 12, 2019 On 3/29/2019 at 2:42 AM, Colin said: Do you have to up the air pressure when sraying to force the paint through the pad. Will definitely give it a go as like you say the normal way seems to take for ever and my hand starts to get painful Colin, I just spray through the pad with the pressure set to around 20psi. You could give it a go though. I guess the main factor is how much you have pulled at the Scotch Brite. Link to comment Share on other sites More sharing options...
Gazzas Posted April 14, 2019 Share Posted April 14, 2019 I was going to do this then I realized my lap was covered with tiny green flecks of scotch pad. No way I was going to blow that into my paint. How do your avoid that? Gaz Link to comment Share on other sites More sharing options...
SapperSix Posted April 14, 2019 Share Posted April 14, 2019 (edited) 9 hours ago, Gazzas said: I was going to do this then I realized my lap was covered with tiny green flecks of scotch pad. No way I was going to blow that into my paint. How do your avoid that? Gaz Gaz, I washed mine in the sink with soap and water. Then made a few passes with compressed air at about 25 PSI. No problems yet. I have tried both the Scotch Brite Industrial pad (larger holes) and the Heavy Duty. I also used scissors to "shave" off and thin the pad as to get the right thickness for this technique. What I have come up with appears to be madness but is working wonderfully. Edited April 14, 2019 by SapperSix KitmodellerNZ, Gazzas, nmayhew and 1 other 4 Link to comment Share on other sites More sharing options...
KitmodellerNZ Posted April 14, 2019 Author Share Posted April 14, 2019 14 hours ago, Gazzas said: I was going to do this then I realized my lap was covered with tiny green flecks of scotch pad. No way I was going to blow that into my paint. How do your avoid that? Gaz I didn't do anything except give mine a good shake and a high pressure blast with the airbrush. coogrfan, SapperSix and Gazzas 3 Link to comment Share on other sites More sharing options...
dashotgun Posted April 17, 2019 Share Posted April 17, 2019 On 4/11/2019 at 10:08 PM, DonH said: Has anyone tried to use Artool FX templates to do a similar thing? hmm that looks like a workable idea Out2gtcha and SapperSix 2 Link to comment Share on other sites More sharing options...
DonH Posted April 18, 2019 Share Posted April 18, 2019 (edited) 10 hours ago, dashotgun said: hmm that looks like a workable idea Yep, that was my thinking. I've seen some stuff on tinterweb where these are used for weathering/post shading but I don't see why they can't be used for black basing. More expensive than ScotchBrite, of course! Edited April 18, 2019 by DonH Link to comment Share on other sites More sharing options...
KitmodellerNZ Posted April 25, 2019 Author Share Posted April 25, 2019 (edited) The Scotch Brite idea came about as a cost saving technique for me. I'd be paying around NZ$50 to get a set of the Artool FX Mini templates sent to me here in Auckland, NZ from an airbrush store in Australia. Edited April 28, 2019 by KitmodellerNZ maamold, coogrfan and SapperSix 3 Link to comment Share on other sites More sharing options...
Sabre F-86 Posted May 24, 2023 Share Posted May 24, 2023 I've ordered some scotch brite pads, expect them tonight. Have to see how thick they are. I think I can whittle them down with a heavy duty Olfa cutter. Link to comment Share on other sites More sharing options...
Woody V Posted May 25, 2023 Share Posted May 25, 2023 This thread started in 2019 and based on the number of builds I've seen using this method, I'd say we have a winner. chukw, coogrfan and Daniel Leduc 3 Link to comment Share on other sites More sharing options...
Neo Posted May 27, 2023 Share Posted May 27, 2023 (edited) On 4/17/2019 at 2:54 PM, dashotgun said: hmm that looks like a workable idea I Have couple of these, work great for weathering and post shading, buti think the scorchbrite is more efficient because it contour with the model. I have the metal and paper version and unless the surface is flat uta a PITA to use. Also price wise, scotchbrite is unbeatable and dont have to fight to clean it. Thanks for the rip im definately gona use this. I have some super corse brown ones for sanding wood that will do great as they are very porous Edited May 27, 2023 by Neo Daniel Leduc and chukw 2 Link to comment Share on other sites More sharing options...
Bstarr3 Posted May 29, 2023 Share Posted May 29, 2023 Honestly, I’ve tried this a number of times but can never thin the scotch brite pad down enough without tearing it into little bits. Link to comment Share on other sites More sharing options...
KUROK Posted July 31, 2023 Share Posted July 31, 2023 On 5/29/2023 at 7:21 PM, Bstarr3 said: Honestly, I’ve tried this a number of times but can never thin the scotch brite pad down enough without tearing it into little bits. You know those slicers at the grocery story to thinly slice the deli meat? Perhaps we can try that with scotchbrite? They won't mind eh? Link to comment Share on other sites More sharing options...
ulvdemon Posted August 7, 2023 Share Posted August 7, 2023 I know this is an old thread, but if I am reading this correctly, people are using scissors or blades to thin down the scotch-brite pads? Link to comment Share on other sites More sharing options...
Woody V Posted August 8, 2023 Share Posted August 8, 2023 15 hours ago, ulvdemon said: I know this is an old thread, but if I am reading this correctly, people are using scissors or blades to thin down the scotch-brite pads? I can't speak for everyone, but I tear it and it's not easy. Link to comment Share on other sites More sharing options...
