KitmodellerNZ
Rapid Black Basing... using a Scotch Brite
6 hours ago, nmayhew said:
I do agree - I will definitely be giving this a whirl, if only for the fact it seems way easier than fiddling around trying to do a random squiggle myself!
Agreed, I think this will not only be easier, but create more widely varied looking panels than I would naturally do myself.
Im about to start painting my Do-335 in the multi-engined GB, and will report back. I have already torn up the Scotch brite pads (harder than it seemed), and am ready to press forward.
Some questions:
does the wire wool stuff just rest on the model surface whilst you spray?
Doesn't it blow around once you start spraying?
Any movement of the ‘mask’ would cause a dragging / scratching of the paint and ruin the effect...
so so how do get around that, and how do do upright surfaces?
Doesnt work well without the "black". I tried "gray basing" using this, and I really didnt have enough paint either. I needs the black, and not light colors like I was using, a light blue over gray.
I think I will try it again with the black base, as I think it will work well that way.
7 hours ago, nmayhew said:
Some questions:
I just hold the Scotch Brite lightly against the model's surface. No issues with it moving whilst spraying. I lift it and reposition the Scotch Brite as I go, so no issues with scratching
Thanks for sharing your observation. I've only tried it over black so far. I'm looking forward to trying it over topcoats instead of using salt.
I agree, I think with a similar but darker/lighter, the subtle look will do well, without the effort and mess of the salt treatment.
AAMOF, I may try this on the top RLM 79 on my build, and mix a bit of white in to fade things out a bit.
On 3/14/2019 at 3:57 AM, Shawn M said:
so you spray through the thinned shredded pad or just on the edge?
Solid results no matter what!
I will give it a whirl when I get back to building
Hi Shawn, I spray through both the pad and the edges.
Do you have to up the air pressure when sraying to force the paint through the pad.
Will definitely give it a go as like you say the normal way seems to take for ever and my hand starts to get painful
