10 hours ago, Out2gtcha said:
Wonderful Chris!
Thanks Brian!  Good to be back modeling!  Hope all is well in Nebraska.  Crazy stuff going on here.  Wondering if Nationals is going to happen...  Chris
17 hours ago, markiii said:
                ..., are you going to paint that line below the data placards?
Looks like it 'could' be the cockpit color ...
Yeah, it's a restoration .
Edited by MikeMaben
9 hours ago, Wolf Buddee said:
What Brian said.........
Wonderful Chris!
Cheers,
Wolf
Thanks Wolf!  Good to be back and hope you are well!  Chris
One of the first things I noticed was the plane in the picture is in a museum - I usually refer to a few different sources: esp Squadron's Walk Around which has period (some color) pics.  Page 48 seems to show that conduit attached to the fuselage panel is painted black, as is the panel itself and that the fastener does not have a rubber gasket attached.
For visual and scale effect sometimes I will either paint or do a wash on a feature such as that conduit just to give it a bit more visual differentiation.  I may do that here as well.  I was planning on attaching the throttle cables and the cables for the gunsight as well but have to consider what will actually be seen.
Now I'm annoyed I didn't see that picture sooner or I would have painted much more of the cockpit black.  Well, I DID see that picture but was looking for the color of various switches and such.  For all the Mustangs I've seen (and built),  everyone has had a predominantly interior green cockpit.  Something I will look into for future builds as I have two Revell 1/32 Mustang kits in the closet.
Live and learn!
Making a bit of progress, got the landing gear wheel well together but my compressor pressure regulator failed today so won't be spraying anything until I get a replacement.
Apologize for the poor lighting on the photography.  Just don't have that set up yet.
Found two more cockpit decals that I missed, however one will end up behind the seat so not doing that one.  I did put on the one for the map case.  I don't think I have ever seen that sign in a cockpitThe Barracuda sidewalls are really detailed and look terrific paired with the Barracuda cockpit stencils:
Also got the gun sight together, first time I've put all of this into the K-14 sight.  This is also the Eduard resin and PE sight.  The reflector glass is actually cut from the clear acetate sheet from the Barracuda instrument panel sheet.  There is plenty of clear sheet left and there is a black border around the sheet that makes measuring and cutting much easier.  Can't see that black line here though as I used it at the base. And actually, in the right light, the ''glass" really does reflect the image below it!
I have seen pictures that show 'No Handhold' on top of the gun sight sunshade so will look to see if I have a decal that will fit.  This is the first time I've used the PE adjustment chain on the left side of the sight - bottom picture.
Working on the elevators and wings tomorrow. I think I'm going to use the AMUR Reaver resin flaps.
Hope everyone is having a great weekend!
Chris
Latest update and tried something I have never tried before: Spraying Mr Surfacer.
Trying to replicate the puttied wings on the Mustang I thought I'd give spraying Mr. Surfacer 1500 a try.  Reading the thread on the topic on LSP, cutting it with 50% Mr Color Self Leveling Thinner seemed like the way to go.
Here is the prep:  I used Mr Hobby Mr Mask on the fuel caps and the inspection panel on the top of the wing as well as on the gun bay panels and the lights on the bottom of the wing.
The 'strakes' (for lack of the correct term for what they are called) were not puttied so covered them in Tamiya tape.
The Mr Surfacer went on heavy and wet but it leveled off amazingly well.  Maybe too well!!  Over three sessions I laid down about 20 coats of 50% Mr Surfacer 1500 and Mr Color Self Leveling Thinners.  When it was wet, the rivets were completely covered.  When it dried, I'm hard pressed to see that it made any difference.
Does not look too bad in the Mr. Surfacer gray - wait till you see it back in Gloss Black Primer.
I may have wasted half a bottle of Mr Surfacer...
I literally puddled Mr Surfacer on the leading edge and top chords of the wing!  No clue where it went off to.
AMUR Flap vs Tamiya Flaps
Next is working on using those terrific AMUR resin flaps.  In my Lou IV build I showed the difference between the Revell, Tamiya and AMUR flaps.  Both Revell and Tamiya have their issues but the AMUR flaps are amazing.
I wanted to see if I could get the resin flaps to articulate the same way as the Tamiya flaps but that meant getting some pins into the resin flaps.  (No clue why, but the photograph makes the resin flap look short, but it is perfectly the same size).
I tried using a pin vise to drill into the AMUR sprue and found the resin is actually pretty soft and was very easy to drill into. I was concerned that if the resin was brittle that it might not take the pin very well as it had to go in very close to the edge of the flap.
First I drilled a #64 hole, then used a larger drill for the final hole.  I found that a pin from an interface connector (remember the V.35 interface?) is exactly the same diameter as the pin on the Tamiya flap - and I have maybe 15 of those pins.
What I found is that I have the angle of the pin in the flap off by about 5 degrees so will have to see if I can finagle it into the slot.  Worst case I'll just glue it in place.  But thought I'd give this a try.
Barracuda Resin Wheels and Tires
Last up are those beautiful Barracuda wheels and tires.  Used a pointed punch push the flash out from between the spokes which worked really well, as well as around the tires.
First coat was Vallejo Gloss Black primer, followed by spraying the wheels in Vallejo Metal Flat Aluminum and then used my go-to color for tires which is Vallejo RLM66 Black Grey.
pnXLIK1Pj
Lots of building this weekend (and actually started a 1/144 B-58 Hustler as well!). Going to let this dry for a day and come back to it on Tuesday.  Hope everyone had a good weekend - be safe!
Chris
Hey Chris , looks like fun. I think the problem with the MS1500 is that it's too fine (particles very small).
I've thinned MS500 with 91% alcohol and used it as a primer / filler.
Give it a try on a mule to see if you like it.
cOqtYdN.jpg?1
Just don't fall off  ;)
Thanks Mike - I wondered about that too.  Just ordered the 500 from SprueBrothers.  I will give it one more go, thanks for the recommendation.
Says a lot that I can actually puddle the 1500 on the surface (with 50% self leveling thinner) and there are no streaks or runs or anything.  Perfectly flat and took a 12000 grid sanding pad to the wing and it polished up nicely.
In the meantime will work on closing up the fuselage and playing with the flaps and landing gear.  Still lots to do.
Cheers,
Chris
25 minutes ago, markiii said:
Hey Chris, just a reminder.
The decal for the sunshade is on the kit decal sheet.
Happy modeling! Keep cranking away.
Thanks Mark!  I actually had one from another Barracuda stencil set that I used - fit perfectly and same font/etc as the one on the pad on the front of the gunsight.
Cheers, Chris
