Smokey Posted January 20, 2019 Share Posted January 20, 2019 greetings all. As the title says I am thinking of buying a Trumpeter Eurofighter. Looking at probably doing a Great Britain one. I was looking online and ran across Aires has two sets offered. 2118 is a late exhaust set and 2119 is a early exhaust set. I have been all over the internet and can't find what the difference is between them. The pictures of the sets on SB I can't tell what is the difference. Can someone help me with a answer to my question. Dan Dandiego 1 Link to comment Share on other sites More sharing options...
ringleheim Posted January 20, 2019 Share Posted January 20, 2019 Just looked at the 2 sets side by side at their website and it looks like the LATE exhaust veins are slightly more opened up. That's all I could see visually separating the 2. I'm sure someone can come up with a better answer. Link to comment Share on other sites More sharing options...
crobinsonh Posted January 20, 2019 Share Posted January 20, 2019 Have you considered the Revell EF-2000 - whilst not an easy build it is significantly more accurate than the Trumpeter EF-2000? Phartycr0c and Iain 2 Link to comment Share on other sites More sharing options...
LSP_Mike Posted January 20, 2019 Share Posted January 20, 2019 Sort of my question as well. IIRC, Revell came out ahead of the trumpy kit. LSP_K2 1 Link to comment Share on other sites More sharing options...
Iain Posted January 20, 2019 Share Posted January 20, 2019 As others have said - Revell is by far the better shape. As to jet pipes - I've wondered that myself! Iain Link to comment Share on other sites More sharing options...
AnthonyWan Posted January 20, 2019 Share Posted January 20, 2019 If you need the Aires sets... let me know! I have a couple of them and I can dig out to see which one they are! Smokey 1 Link to comment Share on other sites More sharing options...
Chek Posted January 21, 2019 Share Posted January 21, 2019 As others have said, there's little discernible difference between the Aires sets. In case there is, if you were doing an RAF Typhoon F2, say pre-2010-ish I'd use the early set. However all RAF Typhoon FGR4s with the ZK serial prefix have the most modern EJ2000 engines, and all those ex-F2s with ZJ serial prefixes that haven't been put out to grass were upgraded to tranche 5 standard and are indistinguishable from FGR4s. About the only foreign Air Force who probably haven't upgraded are likely the Austrians who bought their dozen jets as no-frills (but still 4th gen.) interceptors. While it's a bit more of a chore, the Revell Eurofighter results in a much better and more accurate looking model than the Trumpeter one. Smokey 1 Link to comment Share on other sites More sharing options...
Smokey Posted January 21, 2019 Author Share Posted January 21, 2019 Thanks guys for you input. Chek, the RAF Typhoon I want to do is a FGR4. Xtradecal X32048 has a colorful one on it. https://www.hannants.co.uk/product/X32048 Dan Link to comment Share on other sites More sharing options...
Dave Williams Posted January 21, 2019 Share Posted January 21, 2019 Just be aware, I have a couple of the sets, and it’s not uncommon to find one of the exhaust petals to be broken off. They seem unusually fragile in this particular set. Link to comment Share on other sites More sharing options...
Chek Posted January 21, 2019 Share Posted January 21, 2019 17 hours ago, Smokey said: Chek, the RAF Typhoon I want to do is a FGR4. Xtradecal X32048 has a colorful one on it. Dan Whilst I'm no expert Dan, I do take an interest in the Typhoon's evolution. So I'd basically counsel that if you're preferred subject has the IR seeker mounted below the port windscreen (which it does) then it's been upgraded to tranche 5 standard and "later" engines are appropriate. Link to comment Share on other sites More sharing options...
Stevepd Posted January 22, 2019 Share Posted January 22, 2019 If you google 1/32 typhoon exhaust early on one page then open another doing the same for late. The early exhaust on the inside of the feathers has horizontal ribs which the late one doesn’t. The early exhaust in the photo has the upside down Y actuators which have some V “thing” that is inside the Y which the late doesn’t. I’m not sure how much you will see when they’re constructed together......... Steve. Link to comment Share on other sites More sharing options...
Phartycr0c Posted January 22, 2019 Share Posted January 22, 2019 Dan, if you want any reference phots of the 1:1 scale, PM me iv'e got loads. Oh and +1 for the Revell kit. Cheaper and a lot more accurate. Smokey 1 Link to comment Share on other sites More sharing options...
Phartycr0c Posted January 22, 2019 Share Posted January 22, 2019 Soz to Clarify, Typhoons in general. not the 3 sqdn special tail aircraft Link to comment Share on other sites More sharing options...
Tony T Posted January 22, 2019 Share Posted January 22, 2019 (edited) The Aerocraft Models cast metal NLG strut is indispensible for the Revell Tiffie... https://aerocraftmodels.bigcartel.com/product/eurofighter-typhoon-nose-wheel-undercarriage-strut Cold War Studio do some interesting inlet, stabilator area and canopy etch. The archille's heel of the Revell is the ghastly inlet. If I could find a dirt cheap Trumpeter I'd use the inlet parts from that spliced into/onto the Revell. Here's hoping some suitable CAD-designed resin appears! Prefer the crimson tailed No.29 Sqn jet myself, which is also available from Xtradecal... https://www.hannants.co.uk/product/X32060 Tony Edited January 22, 2019 by Tony T the usual to-activate-link(s) rigmarole Smokey and Chek 2 Link to comment Share on other sites More sharing options...
Chek Posted January 22, 2019 Share Posted January 22, 2019 Second Tony on the Aerocraft nose gear - it's a beautiful casting and totally eliminates any concern about the fragility of the plastic part. Even drilling and steel pinning the kit provided leg would need great precision, and even then might not match the Aerocraft part for strength. The CWS etched intake splitter plate is also very highly recommended. Link to comment Share on other sites More sharing options...
