Eenyweeny Posted January 10, 2019 Author Share Posted January 10, 2019 I need a better camera... the Iphone doesn't work in my lighting conditions! Middle wing is complete, oil coolers fitted and an attempt made to use cunning painting to make them look a little more real. I painted both coolers black, then highlighted the fins with silver, to make them appear slimmer. The rest of the oil cooler assemble was painted the main navy blue colour, then the detail picked out in matt black. Looks better in real life and far closer to reality than trumpeters suggestion of painting them matt white!. I then filled around them with Tamiya putty, watered down. Then fixed the middle wing to the fuselage. Very pleasantly surprised at how little filling and sanding required at the joints. Question... How on earth do I mask the cockpit, oil coolers, wheel wells... I can't figure out how to mask something that opens into the structure, any help hugely appreciated! MikeMaben, LSP_Kevin, Gazzas and 2 others 5 Link to comment Share on other sites More sharing options...
LSP_Ron Posted January 11, 2019 Share Posted January 11, 2019 Make-up remover foam cut to fit. Eenyweeny and Out2gtcha 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted January 11, 2019 Share Posted January 11, 2019 chilly beeny ! Eenyweeny 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 11, 2019 Share Posted January 11, 2019 13 hours ago, LSP_Ron said: Make-up remover foam cut to fit. For sure. If you got to your local Walgreens /pharmacy, you can pick up a big bag of makeup sponges that will probably last you years. The makeup sponges are much more dense feeling than your average sponges, and are also excellent for dabbing on masking fluid for chipping, and also are great for dabbing on paint for chipping too. Eenyweeny and LSP_Ron 2 Link to comment Share on other sites More sharing options...
Eenyweeny Posted January 11, 2019 Author Share Posted January 11, 2019 (edited) 14 hours ago, MikeMaben said: chilly beeny ! Definitely chilly at the moment, its -13C outside.... I've never seen it that cold outside, living in England until last May!!! Edited January 11, 2019 by Eenyweeny Out2gtcha 1 Link to comment Share on other sites More sharing options...
Eenyweeny Posted January 11, 2019 Author Share Posted January 11, 2019 I've ordered some make up sponges and another close cell type sponge that's cheaper, that I can experiment with. Thanks for the heads up! LSP_Ron and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Eenyweeny Posted January 11, 2019 Author Share Posted January 11, 2019 So... mixed results with my first time spraying something large with my airbrush! 1. The colour isn't right... I mixed 3 tamiya acrylics as researched somewhere, but I'm not happy with the colour, it's too green and not dark enough... that I can fix! 2. the line running along the top of the fuselage from the cockpit to the engine, I thought was a panel line... clearly not! I can fix that too! 3. I forgot to glue on the front of the windscreen... again, I can fix it... Positives were the paint finish! I guess that called learning! LSP_Kevin, MikeMaben, Out2gtcha and 1 other 4 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 11, 2019 Share Posted January 11, 2019 Its ALL about the learning process.....................in this case I think it can be beneficial. I think its a bit too light myself, but again lighting is everyting, and Im not necessarily seeing the green tint. Good natural lighting while airbrushing is key IMHO. Eenyweeny 1 Link to comment Share on other sites More sharing options...
dennismcc Posted January 12, 2019 Share Posted January 12, 2019 The paint finish looks good which is a huge plus, with that mastered the rest can be fixed easy enough. Cheers Dennis Eenyweeny 1 Link to comment Share on other sites More sharing options...
Gerhard Posted January 12, 2019 Share Posted January 12, 2019 From my point of view, it looks very good. End of the day , you build models for your own satisfaction, and not for others approval. Eenyweeny and Fvdm 2 Link to comment Share on other sites More sharing options...
Eenyweeny Posted January 12, 2019 Author Share Posted January 12, 2019 Thanks again for the kind comments. Gerhard, wise words indeed. I'll add some more photos when this current coat of the correct blue has dried. As it turns out, Model Masters do a colour called Dark Sea Blue, which is exactly the right colour and saves making a mess mixing paints. I am discovering the drawback of air brushing. My surface preparation isn't good enough. I can see tiny scratches from sanding, which means that 320 grit is too coarse? Which grade of sand paper should I be finishing with? 1000 grit? Also dust... I cleaned the model down with a paper towel moistened with thinner, but I can't do that once the first coats gone on, so what should I use after that? I'm sure I'm being too over critical! but any tips would be greatly received! Thanks for looking Link to comment Share on other sites More sharing options...
Eenyweeny Posted January 12, 2019 Author Share Posted January 12, 2019 This time sprayed a closer colour. This is slightly darker than the Tamiya colour AS8, however, it looks fine to me and much better than the previous attempt. Annoyingly the cockpit has a scratch running down the front pane. It was like that when I removed it from the protective bag and despite dipping it in Johnson's floor gloss (future), no improvement. Starting to look like a corsair now, sat on it's own wheels! Nearly there! Just need to decide on the decals and weapons load out now. HVAR's will definitely be going on her, but I can't decide between drop tanks or bombs! LSP_Kevin, coogrfan and Fvdm 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 12, 2019 Share Posted January 12, 2019 Looks great! Kev Eenyweeny 1 Link to comment Share on other sites More sharing options...
SCRATCH BUILDER Posted January 13, 2019 Share Posted January 13, 2019 (edited) As far as sandpaper, I don't think i have ever gone over 600 grit, most the time 400 grit works just fine for me (that's also wet sanding) some times if you get the plastic to gloss you could have issues with the paint being able to get a bite and you could end up peeling the paint off if you do any masking. Edited January 13, 2019 by SCRATCH BUILDER Eenyweeny 1 Link to comment Share on other sites More sharing options...
Eenyweeny Posted January 13, 2019 Author Share Posted January 13, 2019 I have a question regarding decals. Do I need to use a softening solution or can I just apply them using water? Any tips, greatly welcomed. Link to comment Share on other sites More sharing options...
