dutik Posted April 4, 2019 Share Posted April 4, 2019 21 hours ago, blackbetty said: panel lines are not rescribed, its just stuck together Well, LEM demonstrates a really high casting standard with every kit. Good thing - dutik blackbetty and Martinnfb 2 Link to comment Share on other sites More sharing options...
blackbetty Posted April 10, 2019 Author Share Posted April 10, 2019 a coat of silver... upor, Shawn M, Trak-Tor and 11 others 14 Link to comment Share on other sites More sharing options...
Shawn M Posted April 10, 2019 Share Posted April 10, 2019 smoooooth finish blackbetty and Martinnfb 1 1 Link to comment Share on other sites More sharing options...
blackbetty Posted April 10, 2019 Author Share Posted April 10, 2019 minimal filling and sanding, just squirted on, its a joy to work with a resin kit so perfect.... Martinnfb and Troy Molitor 2 Link to comment Share on other sites More sharing options...
Dany Boy Posted April 10, 2019 Share Posted April 10, 2019 Love it! This accessory may be good addition to some diorama! 5013 (1/32)He 162 A-2 Engine 27.50 http://www.cmkkits.com/en/detail-sets-accessories/bmw-003e-ww-ii-german-jet-engine-1-32/ blackbetty and Martinnfb 2 Link to comment Share on other sites More sharing options...
LSP_Ray Posted April 11, 2019 Share Posted April 11, 2019 Purty in silver! Whose paint did you use? blackbetty and Martinnfb 1 1 Link to comment Share on other sites More sharing options...
blackbetty Posted April 11, 2019 Author Share Posted April 11, 2019 (edited) this is gunze metallizer silver Edited April 11, 2019 by blackbetty Martinnfb, LSP_Ray and Dany Boy 3 Link to comment Share on other sites More sharing options...
blackbetty Posted April 12, 2019 Author Share Posted April 12, 2019 some more paint and decals. the lightning bolt and number are self made. the stars are from the kit sheet. it would have been nice to know that these are printd on a solid sheet and have to be cut out. i damaged one because i had to cut the wet decal. BradG, Trak-Tor, Alain Gadbois and 9 others 12 Link to comment Share on other sites More sharing options...
Dany Boy Posted April 12, 2019 Share Posted April 12, 2019 Looking Splendid! Airfield operational Mig-9 jetfighters been described as outside looked like “peeled “ It is because the heights speeds overpressure. Даже внешне МиГ-9 выглядели облезшими, так как краска не выдерживала скоростных полетов. Martinnfb and upor 2 Link to comment Share on other sites More sharing options...
Dany Boy Posted April 12, 2019 Share Posted April 12, 2019 An interesting and unusual decoration of the leading Mig-9 Air parade Migs group 1st May 1947. upor, blackbetty and Martinnfb 3 Link to comment Share on other sites More sharing options...
Troy Molitor Posted April 13, 2019 Share Posted April 13, 2019 Wow this looks awesome as usual Karl. Just getting caught up on all your recent efforts. I certainly agree with the LEM kits. The fit is amazing and the close tolerance fit for a resin kit is a joy to work on. Your MiG is looking so late 40’s -50’s straight wing jet like. I saw saw one of these beast in the Chinese Aviation museum outside of Beijing. The massive cannons sticking out of the engine inlet will look the part soon enough. Thanks for sharing this with us. Regards Troy. blackbetty, upor and Martinnfb 2 1 Link to comment Share on other sites More sharing options...
Dany Boy Posted April 13, 2019 Share Posted April 13, 2019 Actually these massive canons positioned in the front, before the air opening nose part caused too many problems to Soviets. If Soviets keep sticks to original sketch plans of Focke Wulf J.P. 011 they won’t have so much troubles. As the reports says opening fire on 7000m by all 3 guns BMW engines (get choked ) and literally stop working. Even opening fire over then 3000m caused many troubles with engines, so it was strictly forbidden to the pilots to open fire from all guns at ones. Shooting with the 37-мм gun was allowed not higher then 3000m. “Большие проблемы возникали при стрельбе. При открытии огня на высоте более 3000 м силовая установка вела себя нестабильно (менялись обороты, температура газов, возникал помпаж), а во время залпа из трех пушек на высоте более 7000 м двигатели просто останавливались. Виновником отказов были пороховые газы, которые пушки в большом количестве отправляли прямо в воздухозаборник.” Для устранения этого серьезного недостатка от использования 57-мм орудия отказались и перешли на 37-мм калибр. Actually finally Mig’s engineers find the better gun position but it was too late, because Mig-15 rise. BradG, Martinnfb, Alain Gadbois and 4 others 7 Link to comment Share on other sites More sharing options...
blackbetty Posted April 29, 2019 Author Share Posted April 29, 2019 (edited) first try with the gearlegs. since these are reinforced with metal inserts, thes are sturdy enogh Edited April 29, 2019 by blackbetty dutik, Martinnfb, Trak-Tor and 4 others 7 Link to comment Share on other sites More sharing options...
dutik Posted May 1, 2019 Share Posted May 1, 2019 Really nice looking model! Regards - dutik Martinnfb and blackbetty 1 1 Link to comment Share on other sites More sharing options...
blackbetty Posted May 2, 2019 Author Share Posted May 2, 2019 oops, the number is wrong, it should be 01 Martinnfb 1 Link to comment Share on other sites More sharing options...
