reconspit Posted February 5, 2019 Share Posted February 5, 2019 Beautiful..., absolutely inspiring EricF 1 Link to comment Share on other sites More sharing options...
EricF Posted February 5, 2019 Author Share Posted February 5, 2019 The pics here below are dry fit Hybridation between Aires and Avionics is successful Honestly, it was my main worry. Now since everything goes as expected, I am going to focus my attention to the second aircraft to bring her at the same level of progress With the nose gear bay in place but not attached yet. Thanks for your supportive comments Eric Starfighter, johncrow, Anthony in NZ and 2 others 5 Link to comment Share on other sites More sharing options...
EricF Posted February 5, 2019 Author Share Posted February 5, 2019 Here is a pic of the wheels set from AMS that will replace the basic one we find in the kit. Special mention goes for the brake disc. I tried to insert the Avionics MB Mk5, version that we found on the Crusader in the mid sixties. If I'm right a retrofit program to instal the Mk7 started from 1968. This seat is beautiful even if I find it a bit oversized in hight. The Aires one is a Mk7 which is not appropriate for the period and it is undersized anyway. I have to remove additional 1 to 2 mm at the bottom and the compromise will be satisfactory to me to compensate for the hight. Marcel111, Durangokid, Starfighter and 4 others 7 Link to comment Share on other sites More sharing options...
EricF Posted February 6, 2019 Author Share Posted February 6, 2019 The work on the exhausts was pending. So I finished up the painting. They have to be ready before closing the fuselage. I usually use Humbrol Polish Steel that I don't polish at the end The color looks very realistic I sprayed acrilic colors highly diluted at 80%. Final effects are done with pigments. LSP_Kevin, Derek B, Hetstaine and 5 others 8 Link to comment Share on other sites More sharing options...
F`s are my favs Posted February 6, 2019 Share Posted February 6, 2019 Very nice looking nozzles! Kinda remind me of the intake screens of an old Orenda (if I'm not mistaken) engine. Link to comment Share on other sites More sharing options...
EricF Posted February 7, 2019 Author Share Posted February 7, 2019 On 2/5/2019 at 8:50 AM, Starfighter said: Great job, very neat! And the best is, almost all of it will be visible at the end. Keep the pics coming! On 2/5/2019 at 9:03 AM, reconspit said: Beautiful..., absolutely inspiring Thank's a lot ! Cheer's Eric Link to comment Share on other sites More sharing options...
EricF Posted February 7, 2019 Author Share Posted February 7, 2019 17 hours ago, F`s are my favs said: Very nice looking nozzles! Kinda remind me of the intake screens of an old Orenda (if I'm not mistaken) engine. Thank's ! Honestly, these are not the good engine version for the type They should be nozzles of the J-57 p13 /p20 Here we have nozzles of the p8. Aires propose this only version. Building the late version from scratch would be a long process. So I accepted myself this deviation. Cheer's Eric F`s are my favs and Lee White 2 Link to comment Share on other sites More sharing options...
EricF Posted February 9, 2019 Author Share Posted February 9, 2019 Hi, After the exhaust I have painted the wheel well for the two birds and started detailing. As usual, all the karts had been washed with soapy water before painting. This is mandatory otherwise the paint will adhere even using airbrush. I used Tamiya flat white sprayed in successives sprays until obtaining a clean uniform white surface. For the varnish, my fav goes to the X-22 Wash is Tamiya brown panel line accent color used diluted. Dry brushing is ending the process using white XF-2 Fvdm, Hetstaine, Marcel111 and 5 others 8 Link to comment Share on other sites More sharing options...
EricF Posted February 10, 2019 Author Share Posted February 10, 2019 (edited) Today, still in the scope of closing the fuselage in a near future, I adjusted the main wheel wells inside. I show on the here below pics the depth of plastic to be removed for a good fitting of the Aires part. A black pencil mark shows the difference between two fuselages. The one without the wheel well is not corrected. Next pic, still dry fit for now with the F8-E (FN) above and and the F8-E below. I made the french one cleaner than the Marines one Stay tuned, Eric Edited February 10, 2019 by EricF MikeMaben, Madmax, LSP_Kevin and 6 others 9 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 10, 2019 Share Posted February 10, 2019 Nice progress, Eric! Kev Link to comment Share on other sites More sharing options...
crobinsonh Posted February 10, 2019 Share Posted February 10, 2019 Really nice - this and Barry's thread are great for a super detailed Crusader timvkampen 1 Link to comment Share on other sites More sharing options...
Squizzy 78 Posted February 13, 2019 Share Posted February 13, 2019 Those Aires bays really do come up nicely with a bit of paint and weathering. I think that the weathering is done just right too, it's very easy to over do it. Great work! Link to comment Share on other sites More sharing options...
timvkampen Posted February 14, 2019 Share Posted February 14, 2019 Great job! I like the way you attacked the recessed panelling on this jet. I am going to try it on the TF-104G by Italeri which suffers from the same issue. Will take time and patience but looking at your effort, it seems worth it. Great Franken-cockpit also by the way! Link to comment Share on other sites More sharing options...
EricF Posted February 15, 2019 Author Share Posted February 15, 2019 On 2/10/2019 at 8:37 PM, LSP_Kevin said: Nice progress, Eric! Kev On 2/10/2019 at 10:53 PM, crobinsonh said: Really nice - this and Barry's thread are great for a super detailed Crusader On 2/13/2019 at 9:02 AM, Squizzy said: Those Aires bays really do come up nicely with a bit of paint and weathering. I think that the weathering is done just right too, it's very easy to over do it. Great work! On 2/14/2019 at 10:08 AM, timvkampen said: Great job! I like the way you attacked the recessed panelling on this jet. I am going to try it on the TF-104G by Italeri which suffers from the same issue. Will take time and patience but looking at your effort, it seems worth it. Great Franken-cockpit also by the way! Thanks a lot for your comments ! Link to comment Share on other sites More sharing options...
EricF Posted February 15, 2019 Author Share Posted February 15, 2019 To start the week end the second aircraft is at the same level of progress regarding the cockpit. The ejection rails are removed to be repositioned. The space in between is too narrow as it is. All the details ahaed of the LOX bottle have been removed. They are not reflecting the doc. In fact, the surface is a little bit bending down. This is why we can see grey putty. Otherwise, another Crusader is on the way. I'm waiting for an order with new exhaust representing the J-57 P20 to correct my mistake for the F-8E and the F-8E (FN) which are currently in progress, and resin kits (wheel bay and cockpit) for a RF-8G. I will open a new dedicated thread very soon. johncrow, LSP_Ray, timvkampen and 4 others 7 Link to comment Share on other sites More sharing options...
