richardchapman5 Posted January 12, 2019 Author Share Posted January 12, 2019 Thanks Lancman I have been all over Jeroens review and just waiting for part 2. I have also found a number of areas that are missing and will postthem post Jeroens next instalment so I am not covering the same issue. Even with these minor problems I think this is a fantastic kit. Link to comment Share on other sites More sharing options...
Cees Broere Posted January 13, 2019 Share Posted January 13, 2019 Richard, part two has been posted two weeks ago. We are working on part three at the moment. Cees Link to comment Share on other sites More sharing options...
Madelf75 Posted January 13, 2019 Share Posted January 13, 2019 Very nice I use a silhouette 3 cutter for my mask .Does the machine the machine you are using does it come with it's own drawing software to use? Link to comment Share on other sites More sharing options...
dennismcc Posted January 13, 2019 Share Posted January 13, 2019 As I cannot afford or have the room for one of these I will have to tag along and watch you do the magic, looks like you have all the elements in place for a fine build, as a 100% fan of painted on markings I am pleased that is the route you are taking, so carry on !! Cheers Dennis Link to comment Share on other sites More sharing options...
richardchapman5 Posted January 13, 2019 Author Share Posted January 13, 2019 Hi Cees. When you say part 2 do you mean the update that was added to part 1 or is there another part 2 that I have missed have looked but can't find? Hi Madelf yes the Cricut comes with a program called design space. regards Richard. Link to comment Share on other sites More sharing options...
Cees Broere Posted January 14, 2019 Share Posted January 14, 2019 The update added to part 1. Link to comment Share on other sites More sharing options...
richardchapman5 Posted January 14, 2019 Author Share Posted January 14, 2019 Thanks Cees looking forward to the next instalment Link to comment Share on other sites More sharing options...
richardchapman5 Posted January 22, 2019 Author Share Posted January 22, 2019 Used the Cricut machine to cut some map /document holders that are missing from the kit. Used .25 evergreen plastic card. this shot just shows the front. Thanks for looking LSP_Kevin, Trak-Tor, Azgaron and 4 others 7 Link to comment Share on other sites More sharing options...
richardchapman5 Posted January 23, 2019 Author Share Posted January 23, 2019 Today I started to cut up my Lancaster by removing the raised floor that the seat is placed on. I then cleaned up the hole and filled it with .5 plaster card. I then got stuck into the raised floor. I first removed 2.5mm to lower it. I then removed the rear and front walls of the raised floor as per my reference shots. I the worked on the radio operators seat. The seat cushion that rests on the wing spar needs some added definition between them and I rounded off the edges of the cushion. Before. After. Hope these mods work or I just wasted $359.00 Thanks for looking guitarlute101, Anthony in NZ, Whitey and 6 others 9 Link to comment Share on other sites More sharing options...
Azgaron Posted January 23, 2019 Share Posted January 23, 2019 Nice work so far! Håkan Link to comment Share on other sites More sharing options...
dennismcc Posted January 23, 2019 Share Posted January 23, 2019 Looking good. Cheers Dennis Link to comment Share on other sites More sharing options...
mgunns Posted January 26, 2019 Share Posted January 26, 2019 It looks like so far you and I are the only ones doing the HK Lanc. Your approach is more robust than mine as I am going to do it pretty much OOB, save for barrels, I.P., and a few other details. I doubt tha tyou wil be ruining your model, but only enhancing. it. I will be following along to see how you are progressing. Link to comment Share on other sites More sharing options...
richardchapman5 Posted January 27, 2019 Author Share Posted January 27, 2019 (edited) Thanks mgunns. I’m planning on using the R side of the clear fuselage so I will be trying to add as much of the missing interior as possible. This will include a lot of the plumbing that runs along the L side of the interior. Not planning on adding in R side plumbing as that will block the view of the clear side and I think joining this plumbing to the clear plastic would look quite messy Also planning to detail one of the engines. What do you mean when you say running your model?Are you talking about adding real motors? Regards Richard. Edited January 27, 2019 by richardchapman5 Link to comment Share on other sites More sharing options...
richardchapman5 Posted February 2, 2019 Author Share Posted February 2, 2019 I have just been on the Eduard web site and they have added PE interior set seatbelts and masks coming in March. Link to comment Share on other sites More sharing options...
chrish Posted February 2, 2019 Share Posted February 2, 2019 Whoo hoo! I cant wait to see this come together! Link to comment Share on other sites More sharing options...
