Ryan Posted January 2, 2019 Share Posted January 2, 2019 This will be my entree in the GB. Pics to follow. BloorwestSiR, BradG, spacewolf and 3 others 6 Link to comment Share on other sites More sharing options...
Ryan Posted January 2, 2019 Author Share Posted January 2, 2019 The postman cometh! Wow that is a lot of plastic, pics up soon. Ryan BloorwestSiR 1 Link to comment Share on other sites More sharing options...
Ryan Posted January 3, 2019 Author Share Posted January 3, 2019 This is my first experience with a 1/32 prop twin, my goodness! (first B-25 too) B-25J by The 3rd Placer, on Flickr And the decal sheet. B-25J by The 3rd Placer, on Flickr Just wow. Ryan BloorwestSiR, guitarlute101, Lenny320 and 9 others 12 Link to comment Share on other sites More sharing options...
machine_marty Posted January 3, 2019 Share Posted January 3, 2019 Good choice Ryan, I have the B25H on the bench for this group build so will be interested to compare notes on how you tackle this beast. I'll be starting my thread off as soon as I find a suitable online photo upload/sharing site. Martin BloorwestSiR 1 Link to comment Share on other sites More sharing options...
Ryan Posted January 3, 2019 Author Share Posted January 3, 2019 Good deal Martin, may I suggest Flickr? Just click on one of my pics and it will take you to my photo stream and the site. I like it because I can upload pics right from my phone via the Flickr app. its also easy to use. Ryan Link to comment Share on other sites More sharing options...
machine_marty Posted January 3, 2019 Share Posted January 3, 2019 Thanks Ryan, will take a look and hopefully will be up and running soon Link to comment Share on other sites More sharing options...
Ryan Posted January 3, 2019 Author Share Posted January 3, 2019 To others that have built this kit OOB, are the metal gear sets a must for this kit, or will the plastic stems do the job? Ryan BloorwestSiR 1 Link to comment Share on other sites More sharing options...
Iain Posted January 3, 2019 Share Posted January 3, 2019 Great kit, of a brilliant subject - enjoy! Iain Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 4, 2019 Share Posted January 4, 2019 8 hours ago, Ryan said: To others that have built this kit OOB, are the metal gear sets a must for this kit, or will the plastic stems do the job? Ryan I would say the nose gear definitely but since you can only get them as a set, might as well use them all. One reason for this is the nose gear goes in early on in the assembly and with it being metal, it's less likely to be snapped off. Carl BradG 1 Link to comment Share on other sites More sharing options...
Ryan Posted January 4, 2019 Author Share Posted January 4, 2019 Thanks for the info Carl, nice assembly line going on there! Ryan BloorwestSiR 1 Link to comment Share on other sites More sharing options...
kkarlsen Posted January 4, 2019 Share Posted January 4, 2019 21 hours ago, Ryan said: To others that have built this kit OOB, are the metal gear sets a must for this kit, or will the plastic stems do the job? Ryan The finished build is quite heavy, with the added nose weight. I drilled mine and reinforced them with 1.5 mm brass wire, it seems to have done the job! Haven't had any issues with the landing gear... Cheers: Kent Ryan 1 Link to comment Share on other sites More sharing options...
Gerhard Posted January 4, 2019 Share Posted January 4, 2019 You can also use postimage.io , upload the pic and it gives you a direct link. Free also. Bill_S and Ryan 2 Link to comment Share on other sites More sharing options...
Ryan Posted January 4, 2019 Author Share Posted January 4, 2019 16 minutes ago, kkarlsen said: The finished build is quite heavy, with the added nose weight. I drilled mine and reinforced them with 1.5 mm brass wire, it seems to have done the job! Haven't had any issues with the landing gear... Cheers: Kent Now that I had not considered, good idea! Ryan Link to comment Share on other sites More sharing options...
Ryan Posted January 14, 2019 Author Share Posted January 14, 2019 Here are some sub assemblies I managed to stick together. Generally I like to put as much together as I can before painting. B-25J by The 3rd Placer, on Flickr B-25J by The 3rd Placer, on Flickr I found the whole rear gunner station could be built without the machine guns and they could be slipped on after detail painting the parts. Simply cut off the pins as shown below. B-25J by The 3rd Placer, on Flickr The forward upper turret station and pedestal were also completed....that seat looks uncomfortable. B-25J by The 3rd Placer, on Flickr B-25J by The 3rd Placer, on Flickr Ryan Daniel460, BloorwestSiR, BradG and 4 others 7 Link to comment Share on other sites More sharing options...
Daniel460 Posted January 14, 2019 Share Posted January 14, 2019 Great start so far. Dan Ryan 1 Link to comment Share on other sites More sharing options...
