BloorwestSiR Posted January 14, 2019 Share Posted January 14, 2019 Ugh, that's a tough break. The one thing I've taken away from building this kit is that the instructions as definitely not to be trusted. There's too many errors and not all of them are on the E&O posted on Hyperscale. Hopefully you'll be able to salvage the gear for your second kit. Carl Link to comment Share on other sites More sharing options...
Shawn M Posted January 14, 2019 Author Share Posted January 14, 2019 Thanks gang, luckily my second '110 will be in flight so I got lucky! Assembled the other set last night, this time correctly! Time to start detailing the legs then hit'em with some primer Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 14, 2019 Share Posted January 14, 2019 Super nice work Shawn! I too made a similar mistake on my SU-30, but used JB Weld, and afterword it too was very unusable. No doubt you will get around this one. Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted January 14, 2019 Author Share Posted January 14, 2019 had I have used CA instead of Tamiya Extra Thin, I could have debonded it. Not so lucky in either of our cases huh Brian lol Link to comment Share on other sites More sharing options...
Shawn M Posted January 14, 2019 Author Share Posted January 14, 2019 landing gear sorted and almost ready to prime, still need to add the oil bars but THESE are correct! since I'd already cut the pour blocks off of and hollowed the inside of the drop tanks, I glued the halves together tonight and while that dried I glued the vertical stabs onto the horizontal and while those dried, I cut, fit and glued in some scrap resin to start shaping and filling the elevator mass balances thats all for tonight MikeMaben, BloorwestSiR, Out2gtcha and 5 others 8 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 14, 2019 Share Posted January 14, 2019 Good to hear you won't be short landing gear Shawn. Since you're working on the tailplanes, don't glue on the tailwheel until after the tailplanes are attached to the fuselage. The tail assembly slides onto the fuselage, then the tailwheel fork goes through the end piece and into the fuselage. It's another error in the instructions as they have you install the complete tail as a subassembly. Carl Shawn M and Out2gtcha 2 Link to comment Share on other sites More sharing options...
monthebiff Posted January 14, 2019 Share Posted January 14, 2019 Some seroius progress Shawn if not a little thwarted by the rally crappy Dragon destructions! Not sure if you are aware but you can leave the MLG off until final construction if yo so wish, check my G-4 build and make your own mind up. Nice work on those flame dampers by the way!! Regards. Andy BloorwestSiR, Shawn M and wmoran 2 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted January 15, 2019 Share Posted January 15, 2019 Looking good, even with the 'oops'! You have downloaded the corrections from the Hyperscale site, haven't you? Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted January 15, 2019 Author Share Posted January 15, 2019 Andy I JUST went back through your build as I recalled you had done this, Im going to as well! Hi Ray, yes I downloaded them and have them at my bench, this was a user error more then a Dragon error, although lets face it the instructions could be WAY clearer as to which parts are left and right. Thanks Carl, I need to check on that still as I have the rear fuse "cone" assembled as a unit already since its on tracks that engage with the main fuse. I have Johns resin tailgear as well as the correct dragon one, I have options LOL Link to comment Share on other sites More sharing options...
LSP_Ray Posted January 15, 2019 Share Posted January 15, 2019 Dragon has never been known for their brilliant instructions, AFV or aircraft. Don't think anyone ever goes back and tries a build from them as a check. Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted January 15, 2019 Author Share Posted January 15, 2019 sounds like a lot of full size assembly drawings I've worked from too lol Link to comment Share on other sites More sharing options...
Shawn M Posted January 21, 2019 Author Share Posted January 21, 2019 got some more work done over the weekend, I will get some pics shot tonight. Elevators and landing gear are done. I started detailing the MG151's and conversion work for them, got the wheels drilled out for the landing gear legs, cut the resin tail wheel and gear free. We had no power on saturday (had to toss and entire fridge of food) so that made modeling a little difficult as it was a balance of letting in light and letting out heat. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Azgaron Posted January 21, 2019 Share Posted January 21, 2019 Very nice work so far! Håkan Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted January 21, 2019 Author Share Posted January 21, 2019 thank you Hakan! Azgaron 1 Link to comment Share on other sites More sharing options...
Henry 1951 Posted January 21, 2019 Share Posted January 21, 2019 That is off to a great start. Link to comment Share on other sites More sharing options...
