On 1/6/2019 at 12:35 AM, Out2gtcha said:
Some good progress Carl.
Are you leaving both engine panels open?
Thanks Brian ! I won't be leaving the cowls off as I find it usually spoils the lines of whatever plane it is. I may leave them loose though.
On 1/6/2019 at 3:16 AM, mozart said:
Blimey Carl, you don't hang about do you? I haven't seen the Eduard PE stuff fitted before but it looks like a worthwhile investment, though of course like many areas those magnificent rudder pedals won't sadly be visible, but what the heck, we're modellers!!
Thanks Max! This is the original Eduard PE set for the Dragon kit. They revised it later on so it'll be interesting to see how well it works. You're right in that the pedals most likely won't be seen once it's all finished though.
On 1/6/2019 at 6:42 AM, Troy Molitor said:
Loooking good Carl.
Troy
Thanks Troy!
On 1/7/2019 at 8:35 AM, Shawn M said:
very nice work
I too am adding PE rudder pedals.
Thanks Shawn! The pedals do look good don't they? Only we'll be the only ones to know they're there.
On 1/7/2019 at 9:02 AM, Rick Griewski said:
Nice job and very good photos.
Rick
Thanks Rick!
19 hours ago, MikeMaben said:
                     :speak_cool::popcorn:
Thanks Mike!
5 hours ago, R Palimaka said:
Very sharp clean build as usual Carl! I still can't get over how quickly you work, and how precise everything always is.
Keep up the amazing work.
Richard
Thanks Richard! Im lucky in that I usually get an hour or more each night after the boys are in bed to work on my stuff.
I've got the three sets of belts completed now.
I might give them a wash to bring out the details a bit more.
From here, there's the IP to finish and some other small details. Then I'll be able to close up the fuselage.
Carl
Carl
53 minutes ago, Out2gtcha said:
Nice!   The wash should make the detail really pop. Closing up the fuse is always a good step to get to.
Thanks! I think you're right on the wash making things pop a bit more.
50 minutes ago, Erwin said:
Nice progress.
BTW,is this the kit Revell will do this year ?
Thanks Erwin! Yes, this is the same kit that Revell will be releasing later this year.
