Iain
HobbyBoss 1:32 Liberator GR Mk.VI - RAF Coastal Command
Twist - yes - mainspar no.
Need to keep the area around gear bay clear for one.
I'll be leaving the front part or the kits front/rear webs on place to support the front third of the wing - and leaving the root to tip webs in place.
Just add some airfoil 'formers' and bend the wing skins with a bit of force should be most of the way there I reckon.
But, yes, some trimming will be needed to the rear of the lower wing.
Hold my beer...  :beer4::rofl:
Iain
Hi Iain,
Good thinking!
Your solution to correct the wing airfoil is very promising.
It will also address the remark in the other B-24 thread that the trailing edge of the wing sits too high on the fuselage.
I will follow your thread, it surely will be as interesting  as your Revell He-219 thread
A 1/32 B-24 is too big for me, I will stick to the 1/72 Hasegawa one with Dutch markings. ;)
Cheers,
Peter
Ian I wonder if this issue could be helped by doing what others have done with the 1/144 757 from Minicraft.
On the 757 kit the engines angle downward too much, so the solution was to hog out the wing mounting slot and rotate the back of the wing down ward...in the 757's case raising the face of the engines.
Now on the 24, if one does that, it it would drop the rear wing but put the engines faces at an odd angle....
Hmmmmm.
Ryan
Hi Ryan,
Nope - won't work - you'd still have wrong wing cross section - and now have to 'correct' nacelle position.
Problem is two-fold - cross sectional shape - and angle of incidence.
I learned a long time ago - keep it simple!  :)
Have been thinking this through since I saw images of the built up model at a trade show a few months back - convinced the route I've planned is the easiest!
Iain
Yes of course you are right.
In my example you would retain the kit's wing shape and be forced to correct engine angle and landing gear mounting points perhaps.
Carry on sir, please excuse my diversion.
Ryan
Edited by Ryan
Probably helps if I show the direct overlay of the Davis B-24 profile overlaid on the kit wing root for reference - you'll see why adding a few degrees of incidence made all the difference and caused me to go my planned route:
And with a few degrees of incidence added:
You can see how this simplifies the 'correction' and covers the two areas of concern in one hit!  :)
The root angle of incidence on the B-24 wing is, I believe, 3° 26' (the kit is less - a quick measure with a protractor gives about 1° - dictated by the angle of the cut-out in the fuselage) - so that fits roughly with what I've found above.
Just sometimes the Planets align - this *may* be one of those times - but jury's out until we make it happen!
EDITED to correct angle of attack to incidence - an important difference!
Iain
Thanks for chiming in Ryan - keep it coming - I make no guarantees on anything I come up with - extra thoughts and input are *always* appreciated!!
Often, you think you've found a solution to a problem, then an extra pair of eyes will throw something into the mix that causes a re-think...  :)
Iain
50 minutes ago, Iain (32SIG) said:
 you'll see why adding a few degrees of angle of attack
Being pedantic, it would be the angle of incidence, as the angle of attack is a function of velocity. as in relative wind etc.
This looks very promissing. I'm afraid I can't help you but I will follow closely. Good luck and have fun.
Looking like more master modelling, will follow with great interest, I'd love to build and RAF B-24 but even the He 219 maxed out my display space.
Cheers
Dennis
