Harold Posted January 18, 2019 Share Posted January 18, 2019 2 hours ago, patricksparks said: AWESOME !!!! Thanks Patrick, but I have inform you I broke one of your parts. The IP cowling wouldn't release from the mold, something reacted to the rubber...I as carefully as I could pried the part out of the rubber, but the protruding section (part under the HUD bracket )stayed behind. It is an easy fix, but I hate anything to happen to your parts. HOWEVER, I was able to get a good casting from the mold and after removing the "slag" from the torn rubber, It is usable for a new mold. patricksparks 1 Link to comment Share on other sites More sharing options...
Harold Posted January 18, 2019 Share Posted January 18, 2019 Starfighter, patricksparks, AnthonyWan and 8 others 11 Link to comment Share on other sites More sharing options...
patricksparks Posted January 18, 2019 Author Share Posted January 18, 2019 20 minutes ago, Harold said: Thanks Patrick, but I have inform you I broke one of your parts. The IP cowling wouldn't release from the mold, something reacted to the rubber...I as carefully as I could pried the part out of the rubber, but the protruding section (part under the HUD bracket )stayed behind. It is an easy fix, but I hate anything to happen to your parts. HOWEVER, I was able to get a good casting from the mold and after removing the "slag" from the torn rubber, It is usable for a new mold. Not a problem !!! Thank you for all the effort !!! Harold 1 Link to comment Share on other sites More sharing options...
patricksparks Posted January 18, 2019 Author Share Posted January 18, 2019 26 minutes ago, Fvdm said: Wow, those fasteners are awesome. Stil a few more to go? Ohhhh yeah.... Link to comment Share on other sites More sharing options...
patricksparks Posted January 18, 2019 Author Share Posted January 18, 2019 (edited) A little more photo recon revealed an access panel that shouldn't be.. so have to fill, too bad I didn't notice until after I opened all the fastener holes for photo-etched parts, well at least I didn't glue all those in .... this panel is only on the left side of the cockpit. Edited January 18, 2019 by patricksparks Greg W, Anthony in NZ, LSP_Kevin and 4 others 7 Link to comment Share on other sites More sharing options...
A-10LOADER Posted January 19, 2019 Share Posted January 19, 2019 HobbyBoss and Trumpter are know for mirroring things. If there's something on one side it has to be on the other. This isn't always the case. Trumpeter's A-4M is a good example of this. Excellent work so far on the Harrier, keep it up. Steve patricksparks, Harold and Gazzas 2 1 Link to comment Share on other sites More sharing options...
patricksparks Posted January 19, 2019 Author Share Posted January 19, 2019 1 hour ago, A-10LOADER said: HobbyBoss and Trumpter are know for mirroring things. If there's something on one side it has to be on the other. This isn't always the case. Trumpeter's A-4M is a good example of this. Excellent work so far on the Harrier, keep it up. Steve I think this kit was actually made from the same electronic file as the Trumpeter 1:32 Harrier, I read some build articles a while ago about the Trumpeter kit's downfalls and I've been finding the identical issues on this kit. Harold and A-10LOADER 2 Link to comment Share on other sites More sharing options...
A-10LOADER Posted January 20, 2019 Share Posted January 20, 2019 21 hours ago, patricksparks said: I think this kit was actually made from the same electronic file as the Trumpeter 1:32 Harrier, I read some build articles a while ago about the Trumpeter kit's downfalls and I've been finding the identical issues on this kit. I'm not surprised. Steve Harold and patricksparks 2 Link to comment Share on other sites More sharing options...
patricksparks Posted January 21, 2019 Author Share Posted January 21, 2019 The forward fuselage has most of it's fasteners, still have to put some on the forward windscreen. Troy Molitor, Starfighter, F`s are my favs and 7 others 10 Link to comment Share on other sites More sharing options...
F`s are my favs Posted January 21, 2019 Share Posted January 21, 2019 These fasteners really look like real... Harold and patricksparks 1 1 Link to comment Share on other sites More sharing options...
Markjames1968 Posted January 21, 2019 Share Posted January 21, 2019 Awesome fasteners patricksparks 1 Link to comment Share on other sites More sharing options...
Starfighter Posted January 23, 2019 Share Posted January 23, 2019 Excellent progress so far - makes me think about getting one despite all the things to correct... please keep your updates coming, it's very a enjoyable read! Harold and patricksparks 1 1 Link to comment Share on other sites More sharing options...
Troy Molitor Posted January 23, 2019 Share Posted January 23, 2019 I can certainly agree. Most enjoyable to read up on all the improvements and updates. Troy patricksparks and Harold 1 1 Link to comment Share on other sites More sharing options...
patricksparks Posted January 23, 2019 Author Share Posted January 23, 2019 After looking at a ton of photos I decided to make a new intake trunk, The real Harrier's intake trunk has more of a tube shape where the front fan lives, the kit's trunk is flattened out too much where it meets the front of the engine, it's not cavernous enough. I also had to cut the rear of the cockpit at the second vertical panel line and added new sides that are smooth all the way back to the fan not all stepped and flats the way the kit is. Also I found that the back of the front wheel well is too wide, it doesn't allow the the forward fuselage walls to converge enough just in front of the fan, in my photos you can see the first fit where the center hub of the fan is not exposed, on the real aircraft you can see it with a bullet shaped fairing that is attached blends into the foward fuselage(still have to make that) the second photo of the intake installed shows the diffrence with the fan exposed more and the photos of the wheel wells shows how much narrower I made it in the rear, I left the front as is and cut about a 1/4" out of the width in the back and let it taper in, if you rotate the nose gear strut up into the well it just barely clears the side walls. Greg W, sandokan, mark31 and 5 others 7 1 Link to comment Share on other sites More sharing options...
Chris_B-1B Posted January 23, 2019 Share Posted January 23, 2019 Really amazing work, Patrick. patricksparks, A-10LOADER and Harold 2 1 Link to comment Share on other sites More sharing options...
