chrish Posted December 11, 2018 Share Posted December 11, 2018 Work has begun on the kit, it may be a long road... D.B. Andrus, scvrobeson, Gazzas and 3 others 6 Link to comment Share on other sites More sharing options...
Gazzas Posted December 11, 2018 Share Posted December 11, 2018 Oh my... Long indeed. Interesting shape. Looking forward to watching it come together. Gaz Link to comment Share on other sites More sharing options...
chrish Posted December 11, 2018 Author Share Posted December 11, 2018 Hi Gaz Thanks for looking in! Link to comment Share on other sites More sharing options...
SCRATCH BUILDER Posted December 11, 2018 Share Posted December 11, 2018 Looks like a decent kit for a 1/72 scale, Good Luke with your build. Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 11, 2018 Share Posted December 11, 2018 Very interesting model. I had to look up what a Casa 235M actually was! Actually an attractively shaped airplane, with some very cool paint options Do you know what livery you are going with yet? Link to comment Share on other sites More sharing options...
chrish Posted December 12, 2018 Author Share Posted December 12, 2018 Hi Brian, it'll actually be very close to the picture shown above! same scheme and markings...if I complete it This is the slope of the roof that should be flat, or it causes an anhedral angle of the wing the wing root is too thick. thinned a bit (both sides) fuselage built up sanding and filling in progress, radome attached and faired in Gazzas, scvrobeson, LSP_Kevin and 2 others 5 Link to comment Share on other sites More sharing options...
chrish Posted December 13, 2018 Author Share Posted December 13, 2018 clouds of sanding dust later, I've got the tail cone fitted and the previous gaps/bubbles sanded out. I made a bit of a splint to hold the tail cone "aligned" while gluing. the stab. being adjusted for fit... Anthony in NZ, Out2gtcha, ShelbyGT500 and 1 other 4 Link to comment Share on other sites More sharing options...
chrish Posted December 14, 2018 Author Share Posted December 14, 2018 work continues tonight, well, it continued tonight but stopped now. I've added shims and supports here and there to help hold the cargo doors in place, the bottom door is all but done, the upper door needs much more work. I also had a fuselage misalignment but that was possibly my fault. the upper door has been my biggest problem so far. LSP_Kevin, Out2gtcha, ShelbyGT500 and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 14, 2018 Share Posted December 14, 2018 Great progress chrish. I think fit of things like that cargo door, can be the bane of a lot of resin model kits. They do take some modeling skill for sure, and your doing well! Link to comment Share on other sites More sharing options...
chrish Posted December 14, 2018 Author Share Posted December 14, 2018 Thanks Brian with heading into the weekend I'm hoping to get some time at the bench and take a chunk out of this kit! Best laid plans... Test fits of the wings and empennage is encouraging though. So maybe these doors will be the tough spot? (he said in blissful ignorance) Still, it's quite an interesting kit and aircraft. Link to comment Share on other sites More sharing options...
SCRATCH BUILDER Posted December 17, 2018 Share Posted December 17, 2018 With all said, coming along nicely. Link to comment Share on other sites More sharing options...
chrish Posted December 17, 2018 Author Share Posted December 17, 2018 Thanks for looking at my build and the encouraging words! Some progress has been made but it's slow going, while fitting the engine nacelles to the wings I found the nacelles have airfoil curves to fit the wing but the airfoil seems to be on the wrong side of the nacelles, where the top should be curved to fit the top curve of the wing, the bottoms of the nacelles actually fit the tops of the wings better than the right way round. I sawed the nacelles in half made each half fit the wing then attach the engine component to the attached nacelles. Lots of super glue, filling sanding and repeating, primer will likely show more flaws needing work next, I attached the wings to the fuselage, an easy job compared to some of the work so far. Although the starboard wing is 3mm higher than the port wing at the tip so, my adjustments were not quite sufficient on one side or, too ambitious on the other side? In any case the model appears to have 0° dihedral viewed nose on (my ultimate goal) After all that I began fitting the horizontal stabs. a quick test fit found them to be not too good a fit, nor are they symmetrical in span chord or thickness. I briefly contemplated scratching my own from some .080" sheet plastic but just as quickly dismissed that idea, I began scraping and sanding the joining area of the stabs. to fuse. area to get the best fit (now attained) and will pin and glue them tomorrow. I already went the route with the vertical stab so I think it'll fit when the time comes and that's the last of the big airplane shaped bits that need to be fitted, next will be props spinners wheels and such, should be a cake walk right? here's a view of the nacelles viewed upside down attempting to fit a nacelle nacelle split and attached to the wing nose on view top view BiggTim, LSP_Kevin and Out2gtcha 3 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 17, 2018 Share Posted December 17, 2018 I like the shape and the high-shoulder look of the airframe very much. Link to comment Share on other sites More sharing options...
chrish Posted December 17, 2018 Author Share Posted December 17, 2018 Hi Brian My thinking as well, a neat looking design. I've pre -ordered his ATR's coming out early/mid next year. Similar design but unlimited civil livery. I have the Broplan vac kits already but they're rough... Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 17, 2018 Share Posted December 17, 2018 "rough" kits can really tend to sap your modeling will. At least they do with mine! Im almost really ready for a nice shake and bake kit chrish 1 Link to comment Share on other sites More sharing options...
