s_tringa Posted December 3, 2018 Share Posted December 3, 2018 (edited) Hello to all my name is Sebastiano from Italy and I'm new here. I'm came back to large scale after several years in the small and the quarter scale. 1/32 was my first love in my modeller carreer, so is time to go back home. My first here is a Messerschmitt-Bf-109F4-10.JG53(Jabo) in MTO (Sicily-1942) using the F4-trop Hasegawa kit and some parts from old Aires G-6->F-4 conversion set. So let's start. Criticisms and suggestion always appreciated. For first I'm start to rivets all the plane from the fuselage and to the wings. Using Kagero scale plane, Rosie the riveter and 3M blue tape and a lot of patience. I hate this kind of work!! completed the riveting process, I start to scratchbuilt the larger curved exhaust guard/deflector on the left side of the engine cowling, using the process showed in the following pics. The metal foil is molded after it is passing for few second on a candle flame to make the brass softer. It's all for now!! Sebastiano Edited May 30, 2019 by s_tringa update rafju, Kagemusha, 109 and 15 others 18 Link to comment Share on other sites More sharing options...
Kagemusha Posted December 3, 2018 Share Posted December 3, 2018 Sebastiano, fantastic start. nice choice too. Out2gtcha 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted December 3, 2018 Share Posted December 3, 2018 Great start, Sebastiano, and I have that kit - and conversion - in the stash somewhere myself. LSP_K2 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted December 3, 2018 Share Posted December 3, 2018 Ciao Seb!! Great start on the F... where in Italy are you? Welcome to LSP!! Ciao Alan Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 3, 2018 Share Posted December 3, 2018 Welcome aboard Sebastiano! Looks like you're off to a great start with this one. Kev Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 3, 2018 Share Posted December 3, 2018 Nice progress on this one. Of all the 109s, I've always liked the schemes based out of Italy and the Mediterranean best. Welcome to the forums BTW! Link to comment Share on other sites More sharing options...
MikeMaben Posted December 4, 2018 Share Posted December 4, 2018 Link to comment Share on other sites More sharing options...
John1 Posted December 4, 2018 Share Posted December 4, 2018 Looking good! Welcome to LSP! Link to comment Share on other sites More sharing options...
williamj Posted December 4, 2018 Share Posted December 4, 2018 (edited) The "109F" has always been my fav as well...can't go wrong with this kit either,with the minor changes Has. made to it. Welcome Sebastiano Edited December 4, 2018 by williamj Link to comment Share on other sites More sharing options...
SCRATCH BUILDER Posted December 4, 2018 Share Posted December 4, 2018 Welcome Sebastiano ! Very nice start, will have to watch your build........ Link to comment Share on other sites More sharing options...
s_tringa Posted January 15, 2019 Author Share Posted January 15, 2019 After a long time, I come back to update this post also thanks to work done in the Christmas holidays. I've started to paint the interior using the "black base" thecnique with Mr Surface1500 adding some sprayed spotted texture of light (raised parts) and medium grey and at last aome light layer of RLM66 until the result let me satisfyed. Tomorrow I will continue the painting adding the various details and with the weathering process I'we doing somethign on the wheel wells , openig the holes on the inner part. I'dont like too much the Hasegawa wheel wells because are no detail on the surface so probably I'll replache these with some aftermarket parts. In the meantime, I've take back the other Bf 109 that I've stopped some months ago for some problems to fit the Aires cockpit into the fuselage. It is the G-6 Revell that I would to backdate into a G-2/trop using the Alleycat set. The Revell is lovely and have very fine details. The camouflage I've chose is the standard desert scheme in RLM 78/79 but with an interesting field variation of an overpainted "wave mirror" in green RLM80. In this way I could go in tandem, saving a lot of time. I'dont have the decals for this G-2 but I think that not will be a big problem. I'll try to use self made mask for painting numbers and unit emblem. [/url] So I've started to detail the external surface adding rivets and emptying the inside of the exaust stacks and the air vents and scratchbuilding the exaust protection as doing on the F-4 model also I've added the sand filter from Quickboost. I painted the cockpit as described for the F-4, in the end the result satisfies me. Just a little touch of desert sand on the floor using pigments. and after the worst challenge.....put in the Aires cockpit. I think this is an adjustment of the old interior for G-2 hasegawa kits to use it in the new revell . At the end, after a lot of file and sandpaper work, I did it. In my opinion the set Aires is not essential because the Revell's interiors are beautiful and detailed, only the rear seat belts molded together with the seat back (5 minutes working with the round blade cutter). I do not know why I took this set. Now I can close the fuselage and glue the resin top of the engine cowling. To be able to assemble the two brass MGs after painted the model, I glued two small styrene tubes inside the cowling just in correspondence with the holes for the machine guns. Here is the two Bf109 togheter It's all for now, hope you like the progress. Sebastiano LSP_Kevin, rafju, Fanes and 12 others 15 Link to comment Share on other sites More sharing options...
Scale32 Posted January 15, 2019 Share Posted January 15, 2019 Awesome painting of the cockpits. Didn't know about the Allycat G2 conversion set. Cheers Bevan Link to comment Share on other sites More sharing options...
Fanes Posted January 15, 2019 Share Posted January 15, 2019 Fantastic work so far! I'll be watching closely since I plan to do a G-2 (photo recon) conversion too. One little thing jumped me: I think you have the dust filter rotated 90 degrees. The doors should open horizontally, or isn't it glued into place yet? Link to comment Share on other sites More sharing options...
dodgem37 Posted January 15, 2019 Share Posted January 15, 2019 Very nice. Sincerely, Mark Link to comment Share on other sites More sharing options...
Robthepom Posted January 15, 2019 Share Posted January 15, 2019 hello hello nice painting and detailing skills Link to comment Share on other sites More sharing options...
